Guest Jennifer Report post Posted 11/16/2006 05:24 PM Hi, I tried to set the hook flash for my dialogic card. How must I set the parameter for the card? I open the Config.xml file to set the hook flash. First it looks like this: <Channel> <Name>dxxxB1C1</Name> <NetworkIf>dxxxB1C1</NetworkIf> <Protocol>pdk_na_an_io</Protocol> <RingsBeforeAnswer>2</RingsBeforeAnswer> <script>C:\Program Files\VoiceGuide\System\Myscript\MY_IVRKLS.vgs</Script> <ConfigLine></ConfigLine> <AllowDialOut>1</AllowDialOut> <PopupCallerId>0</PopupCallerId> <RV></RV> </Channel> I insert the folowing but I don't know if I am on the good way. <Channel> <Name>dxxxB1C1</Name> <NetworkIf>dxxxB1C1</NetworkIf> <Protocol>pdk_na_an_io</Protocol> <RingsBeforeAnswer>2</RingsBeforeAnswer> <script>C:\Program Files\VoiceGuide\System\Myscript\MY_IVRKLS.vgs</Script> <ConfigLine></ConfigLine> <AllowDialOut>1</AllowDialOut> <PopupCallerId>0</PopupCallerId> <RV></RV> <SetParm> <Description>Flash time during dialing (10ms units)</Description> <Key>DXBD_FLASHTM</Key> <Value>10</Value> <Default>10</Default> </SetParm> </Channel> Can you help me please? Thank you in advanced Share this post Link to post
SupportTeam Report post Posted 11/16/2006 08:48 PM No need to move the DXBD_FLASHTM related <SetParm> node around. (It will not do anything within the <Channel> node anyway). Leave the DXBD_FLASHTM related <SetParm> node where it is and just change the values... The current value of 10 specifies a 100ms long hookflash. What length hookflash do you want the card to issue? Share this post Link to post
Guest Jennifer Report post Posted 11/16/2006 09:08 PM Hi Support, >>No need to move the DXBD_FLASHTM related <SetParm> node around. (It will not do anything within the <Channel> node anyway). Leave the DXBD_FLASHTM related <SetParm> node where it is and just change the values... I don't kwow what that key is. I only insert: <SetParm> <Description>Flash time during dialing (10ms units)</Description> <Key>DXBD_FLASHTM</Key> <Value>10</Value> <Default>10</Default> </SetParm> </Channel> to <Channel> <Name>dxxxB1C1</Name> <NetworkIf>dxxxB1C1</NetworkIf> <Protocol>pdk_na_an_io</Protocol> <RingsBeforeAnswer>2</RingsBeforeAnswer> <script>C:\Program Files\VoiceGuide\System\Myscript\MY_IVRKLS.vgs</Script> <ConfigLine></ConfigLine> <AllowDialOut>1</AllowDialOut> <PopupCallerId>0</PopupCallerId> <RV></RV> </Channel> 1) Am I on the right way? I am using a D/4PCIUF card and the test line is connected to a Meridian 1 pbx. 2)What could the hook flash time be? Share this post Link to post
SupportTeam Report post Posted 11/16/2006 09:26 PM 1) Am I on the right way?No. As said before: don't rearrange the Config.xml file structure - just change the settings within it... 2)What could the hook flash time be?Speak with Meridian 1 pbx support people. They should advise you what length hookflash their PBX expects. The default value of 100ms usually works for most PBXs. Share this post Link to post
