Hookflash For Dialogic Card. Vg For Dialogic
I tried to set the hook flash for my dialogic card.
How must I set the parameter for the card?
I open the Config.xml file to set the hook flash.
First it looks like this:
<Channel>
<Name>dxxxB1C1</Name>
<NetworkIf>dxxxB1C1</NetworkIf>
<Protocol>pdk_na_an_io</Protocol>
<RingsBeforeAnswer>2</RingsBeforeAnswer>
<script>C:\Program Files\VoiceGuide\System\Myscript\MY_IVRKLS.vgs</Script>
<ConfigLine></ConfigLine>
<PopupCallerId>0</PopupCallerId>
<RV></RV>
</Channel>
I insert the folowing but I don't know if I am on the good way.
<Channel>
<RV></RV>
<SetParm>
<Description>Flash time during dialing (10ms units)</Description>
<Key>DXBD_FLASHTM</Key>
<Value>10</Value>
<Default>10</Default>
</SetParm>
</Channel>
Can you help me please?
Thank you in advanced
No need to move the DXBD_FLASHTM related <SetParm> node around. (It will not do anything within the <Channel> node anyway).
Leave the DXBD_FLASHTM related <SetParm> node where it is and just change the values...
The current value of 10 specifies a 100ms long hookflash.
What length hookflash do you want the card to issue?
Hi Support,
I don't kwow what that key is.
I only insert:
<SetParm>
<Value>10</Value>
</SetParm>
</Channel>
to
<Channel>
<RV></RV>
</Channel>
1) Am I on the right way?
I am using a D/4PCIUF card and the test line is connected to a Meridian 1 pbx.
2)What could the hook flash time be?
No.
As said before: don't rearrange the Config.xml file structure - just change the settings within it...
Speak with Meridian 1 pbx support people. They should advise you what length hookflash their PBX expects.
The default value of 100ms usually works for most PBXs.
