Line 2 Not Answering
With VG for Dialogic 6.0.3179 line two is currently not answering and the VoiceGuide display is showing "State display disabled" for all lines. Line 1 is answering and working fine, but line 2 setup seemingly the same does not answer or create a log file to give us a clue as to why.
We are using the sample config.xml file for the 16 port DMV160LS card though we do have the DMV160LP.
Can you point us in the right direction.
Thanks.
ConfigLine.zip
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=0
TapiWrapOcx=10
SapiWrapOcx=0
Please post the traces.
Log files attached. We also tried plugging the line directly into a phone and confirmed that it is ringing correctly.
We had a quick look in the log file and it appears that the system is seeing line 1 as line 4? But line 2 does not appear in the log file as it never answers.
Thanks.
1127tw.zip
Further testing has revealed that every second port in the card is working so we believe this may be a cabling issue.
However do you have a solution for the "State display disabled" message as outlined earlier.
Thanks.
Refer to the 'Quick Install' quide for the DMV160LP whch came with the card for cabling instructions. The RJ connectors on the DMV160LP card can take two (up to three?) lines.
The two centre cable connectors take one port, then connectors on the 'outside' of them carry signal for another line.
