normbuddy Report post Posted 11/28/2006 05:10 AM Hello, I ahve no problem using Voice Guide with canadian analog phone lines and Dialogic D/4PCIU. But when I try to use it with Varphonex's VoIP lines and Linksys PAP2-NA phone adapter, The Get Numbers Module does not work properly. It only gets one number out of 10. What might be the cause of this problem and could I solve it ? Is it a Dialogic configuration problem ? Is it a Voice Guide configuration problem ? Shoud it try with another Voip provider ? Can you recommand some ? Shoud it try with another VoIP phone adapter ? Can you recommand some ? Thank you, Normand Share this post Link to post
SupportTeam Report post Posted 11/28/2006 06:52 AM Looks like the DTMF tones do not get transmitted by your VoIP carrier or the Linksys PAP2-NA adapter. We see people using Vonage and reporting any problems... Share this post Link to post
