No Action Module - Tts Support..
Hi there,
I am disecting the get price.vgs for a client scenario as part of my evaluation exercise. In the product.mdb found under the Customer Enquiry sample script folder, I plan to add a column named "ProDescription", and this new column will hold a free form product description text (100 words max). In the script designer on the query module I plan to add the fields to be retrieved by the SQL query (the other two fields in the return set exist in the .mdb), here is the SQL;
SELECT ProDescription, UnitsInStock, UnitPrice FROM Goods WHERE ProductID='$RV[Get Product Code]'
For the output flow, I would like to provide the caller the product description before they hear the Stock Count.
I fail to see an Action Module which would allow me to TTS back to the user the ProDescription field. When I look at the module titled 'Speak Number/Amount/Date etc.' the output is constrained to specific data formats, but there is no entry for free form text.
Questions:
*Could you please suggest a solution to use TTS back to the caller the product desciption (free form text)
within the flow of the Get Price.vgs script?
*How would you go about specifying/setting the name of the wav file to be played back to the user? i.e.: if
the user selects the product id = 0001, then the .wav file name would be 0001.wav (how is this name
progrmatically set?)
*I have been reading through you forums and it seems that the general rule is that where a sound file
(.wav) file is called for a developer instead specifies the .txt extension, the TTS engine will execute, is this
also true for the COM interface Dialer_OutDialQueAdd, specifically the sAnnounceMessage and
sAnswerMachineMsg parameters?
Regards,
Ralph
*Could you please suggest a solution to use TTS back to the caller the product desciption (free form text) within the flow of the Get Price.vgs script?
You need to add a Play module to the script. The TTS is done within a Play module.
*How would you go about specifying/setting the name of the wav file to be played back to the user? i.e.: if the user selects the product id = 0001, then the .wav file name would be 0001.wav (how is this name
Read about Result Variables in the VoiceGuide Help file.
*I have been reading through you forums and it seems that the general rule is that where a sound file (.wav) file is called for a developer instead specifies the .txt extension, the TTS engine will execute, is this also true for the COM interface Dialer_OutDialQueAdd, specifically the sAnnounceMessage and
Not sure, try it and see. If it doesn't wotk for sAnswerMachineMsg then three is an easy workaround - just pass the TTS text as an RV and in sAnswerMachineMsg specify a script which would TTS that RV.
That was a quick response! thanks.
Could you please be more specific? about this:
"Read about Result Variables in the VoiceGuide Help file."
There are a lot of variables (return value/evaluation type), are you making reference to the section under
"Where can Result Variables be used"? I want to make sure that I am chasing the correct path/solution.
Also with regards to the first suggestion:
>Could you please suggest a solution to use TTS back to the caller the product desciption (free form text) within >the flow of the Get Price.vgs script?
In order to read the SQL return set via TTS using the play modeule as suggested above;
Where in the play module should I place the return set variable, $RV[Access Query_1_1] ?
-OR-
Should it go on the box "Sound File to be Played"? OR under "Text to speak"?
thanks,
Ralph
-OR-
Under "Text to speak".
Have you read the Help file section on the Play module? There is an example in the Help file.
If I did I would not be bothering you with my pesky questions. As simple as VG might be the learning curve and discovery/understanding of all the information on the help file will be a challenge for users - that is why we are glad you are there! I need to make sure that my scenarios are supported before my team commits financially.
Regarding your earlier reply. Could you please be more specific? about this:
From: http://www.voiceguide.com/vghelp/html/modGetNumber.htm :
A Get Numbers module creates a Result Variable like this:
$RV[moduleTitle]
which holds the characters entered by caller.
you can use this RV later on in the script, eg: in a Play module when specifying the sound file to play.
eg. If caller enters 1234 in a Get Numbers module titled "Select Product" you could then specify this expression in a Play module:
$RV[selectProduct].wav
and the Play module would play sound file 1234.wav
