How To Play Another File Vgs
but vg is not stop main.vgs
What do you mean by "not stop main.vgs" ? When a jump to another script is made that is exactly what happens on the line - the new script starts to be executed on that line. Have you tried using the path to branch to another script as described in http://www.voiceguide.com/vghelp/html/Paths.htm?
If you are still having problem please post the script's which you are using and a more detailed description of what you mean by "not stop main.vgs".
