Error When Run Script
When i run scrip error:
ActiveX component can't create object :'VoiceGuide.CommandLink'
VoiceGuide needs to be started before you can call scripts which try to use it.
If you are getting error "ActiveX component can't create object :'VoiceGuide.CommandLink'" then sounds like VoiceGuide is not even installed on that machine, or is not visible to the process which is running that script.
What script/program are you running that is giving you this error?
