Vb Script Questions
Jacobo Husnin wrote:
Dear Sers
We are corently evalutin you IVR program it is realy wonderfoul , is one of the most easy and powerfoul programas I ever see , one of the features we tink is very iportant for us is the VBscrip , I have a question in the scipt of he Internet Portal,
Dim Shell, IE, readWwwHtml, readWwwText
Dim iIndexDow, iIndexNasdaq, iIndexSP500
Set Shell = CreateObject("Wscript.Shell")
Set IE = CreateObject("InternetExplorer.Application")
With IE
.RegisterAsDropTarget = False
.Visible = False
.Silent = True
.Navigate("finance.yahoo.com")
While .Busy
WScript.Sleep 100
'DoEvents
Wend
With .Document.Body
readWwwHtml = .InnerHTML
readWwwText = .InnerText
End With
End With
IE.Quit
Set IE = Nothing
iIndexDow = GetIntegerAfterLabel("Dow")
iIndexNasdaq = GetIntegerAfterLabel("Nasdaq")
iIndexSP500 = GetIntegerAfterLabel("S&P 500")
strResultVariables= "[MarketDow]{" & iIndexDow & "}" & _
"[MarketNasdaq]{" & iIndexNasdaq & "}" & _
"[MarketSP500]{" & iIndexSP500 & "}"
iRet = WriteResultFile(strResultVariables)
function GetIntegerAfterLabel(strLabel)
'it is assumed that the integer terminates
'with a decimal point
iLblPos1= Instr(readWwwText, strLabel)
iValuePos1 = iLblPos1 + len(strLabel)
iValuePos2 = Instr(iValuePos1, readWwwText, ".")
GetIntegerAfterLabel = mid(readWwwText, iValuePos1, iValuePos2-iValuePos1)
end function
function WriteResultFile(strResult)
const ForReading=1, ForWriting=2, ForAppending=8
Dim filename, fso, ts, outdata, outdata2, outdata3
filename = "VGRUNRESULT_$RV_DEVICEID.TXT"
set fso = CreateObject("Scripting.FileSystemObject")
set ts = fso.OpenTextFile(filename, ForWriting, True)
ts.WriteLine(strResult)
ts.Close
WriteResultFile = 0
end function
What mean ?
.Visible = False
.Silent = True
1)is the . a sub rutine idication or what ?
2)what mean RegisterAsDropTarget , Visible , Navigate this are not Vbscript orders or are they ? where I can see more ifo for this orders,
Tank you
Jacobo Husni A.
Telesoluciones s.a.
Mexico
I'd recommend getting a book on VB Script, and/or going to:
www.microsoft.com/scripting
and selecting "VB Script Documentation" section:
Users Guide: http://msdn.microsoft.com/library/en-us/sc...ml/vbstutor.asp
Reference: http://msdn.microsoft.com/library/en-us/sc...vbscripttoc.asp
VBScript is not hard to learn and lets you do just about anything - v5.0 of VoiceGuide uses extensive VB Scripting in it's Voicemail system - you may want to look at it for some examples as well.
