Can Vbscript Call External Functions And Procedures?
I use a lot of VBScript where I repeat the same functions (and procedures or subroutines?) again and again in each script.
Is it possible in VG to have a centralized place where I can put these often-used functions and call them from there?
Instead of placing them in each VBscript where I use them, I would like to keep them outside so if I need to modify them, I change only one.
I don't think VBScript has a "#import" type directive.
An option is to create a COM DLL containing your often used code and use that from within your VBScripts.
