I Can't Play Multi Sound File
As you have a Dialogic card installed on this system you should be using VoiceGuide for Dialogic.
Why are you using v5.x of VG and not VoiceGuide for Dialogic?
I use win 2000 pro, and i haven't net framework 2.0. And why i can't play multi file in vg5.x
Trace shows that call was ended as there was no Success path specified leaving the module [so du], not due to any problems with playing multiple files.
002606.56 6 state [so du] Running VB Script...
002607.03 6 state Hanging up call... [Run_ResultReturn - no path match (same vgm)]
