jeru Report post Posted 12/14/2006 09:45 PM I've tried ComISDN TSP with SIP support, I have a solution with and Eicon Diva Pro 2 ISDN adaptor and ComISDN. Voiceguide version trial 5.2.5042. The ISDN works and SIP works I can do blind transfer as long as I want to do a blind transfer fra ISDN to ISDN or SIP to SIP I can't do a ISDN to SIP or a SIP to ISDN. Actually I would like to transfer based on a rule setting, a prefix or something like that. Is that possible ? Share this post Link to post
SupportTeam Report post Posted 12/14/2006 10:20 PM can do blind transfer as long as I want to do a blind transfer fra ISDN to ISDN or SIP to SIP I can't do a ISDN to SIP or a SIP to ISDN.Have you spoken to ComISDN about this? Share this post Link to post
jeru Report post Posted 12/15/2006 06:06 AM Yes I have spoke with ComISDN and they say . " If the IVR system can specify the line they can". ComISDN will in near comming future be lauching a gateway between SIP and ISDN. Share this post Link to post
ktruk Report post Posted 12/19/2006 12:11 PM Jesper: To operate ISDN blind-transfer with VG & ComISDN, you need: 1. v5.2.4047 TAPI VoiceGuide, earlier versions have issues with transfer 2. TansferControl_Modem=TAPI & TansferControl_TelBoards=TAPI in Vg.ini 3. Hardware mode setup in line features ComISDN properties (call hold, transfer, conf) 4. Explicit mode setup in line features ComISDN properties 5. ComISDN setup (and licensed) on every line-device you want to use. 6. VG setup (and licensed) on every line-device you want to use, ie: the VoIP line-devices too. 7. (You may also need Prof/Enterprise version of VG with dialler) Please report back when ComISDN deliver the SIP<>ISDN connectivity. Share this post Link to post
jeru Report post Posted 12/22/2006 12:37 PM Thanks, I've been told that the ComISDN Gateway for SIP ISDN is postponed to 11th. of January 2007 I'll look into your solution, and se if I get it working. Jesper Share this post Link to post
ktruk Report post Posted 03/06/2007 06:42 PM Jesper: Any news on this ISDB<>SIP link? Have you got a working system? Thanks - Tim. Share this post Link to post
jeru Report post Posted 04/26/2007 01:07 PM Jesper: Any news on this ISDB<>SIP link? Have you got a working system? Thanks - Tim. Hi Tim I havn't looked into that problem since January - haven't had the time :-( I will see if then comming weeks will change a little. Jesper Share this post Link to post
SupportTeam Report post Posted 04/26/2007 08:39 PM The Beta of "VoiceGuide for VoIP" is available. VoiceGuide for VoIP can control ISDN T1/E1 lines as well, so it's very straightforward to make a ISDN<->SIP connection using a "Dial and Conference" (ie. Tromboned) type transfer. (note that only T1 or E1 based ISDN is supported at this stage, not BRI ISDN) Contact support@VoiceGuide.com to obtain the Beta. Share this post Link to post
jeru Report post Posted 02/18/2008 09:36 AM Jesper: Any news on this ISDB<>SIP link? Have you got a working system? Thanks - Tim. Hi Tim and others I have tried this setup: a Sipura 3102 (FXS/FXO) PSTN to SIP, NCH.COM.AU Axon SIP PBX and UPLINK and Skype, So now I can call from a Skype account or SIP account directly into Voiceguide. To be honest, there are a lot of echo and using number choice doesn't work well. Jesper Share this post Link to post
SupportTeam Report post Posted 02/18/2008 09:41 AM If using SIP we would recommend using v7 of VoiceGuide, running in VoIP mode. And a Skype<->VoIP gateway if you use Skype as well. Share this post Link to post
