Replay Recorded Message
I have recoreded a message and i want the user to listen to the recoreded message and given an option to delete the recorded message if he wants to and re-record the message .What do i do for this
Thank You
Anju
Basically you want to play the just recorded sound file. The filename of the just recorded sound file is stored in a Result Variable. Use that RV in a Play module to play back the sound file.
VBScript module would be used to do file deletion.
The voicemail scripts also provide good samples if this kind of functionality, although it's a bit more complicated example.
