Hanges Up On Voip Unit
Hi
I'm using VG ver. 5.2.5012 with diallogic it was working fine.
now i hooked it up with a voip unit (packet8) and it hangs up after a secend.
any help please.
TIA_Yona
215554.16 5 rv ns add [Evaluate_ring_id_2_Input]{(3 > 2)}
215554.16 5 rv ns add [Evaluate_ring_id_2]{True}
215554.16 5 Eval Expr result:[True]
215554.16 5 timer clear
215554.16 5 state [Get_Numbers_id] Number Input
215554.17 5 lineAnswer(66099) => 66082
215554.70 5 tapi callstate start
215554.70 5 tapi callstate CONNECTED 66099 1 0
215554.70 5 callstate CONNECTED 66099,1,0
215554.70 5 WorkingModeTAPI@Connected=Answering
215554.72 5 WorkingModeScript@Connected=BeforeAnswerRun
215554.73 5 Inband detection not enabled
215554.73 5 tapi Reply (LineEvReply) ok 66082 0
215554.73 5 timer clear
215554.73 5 state [Get_Numbers_id] Number Input
215554.73 5 state [Get_Numbers_id] Playing ()
215554.73 5 ScriptEventCode 8001 iLineState=1300
215554.75 5 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
215554.75 5 timer set 10 EV_TIMEOUT_HANGUP
215554.75 5 timer set 2 EV_TIMEOUT_GOTOMODULE
215554.75 5 callinfo MONITORMODES
215556.92 5 timer fired EV_TIMEOUT_GOTOMODULE
215556.92 5 ScriptEventCode 9002 iLineState=1301
215556.92 5 LsGetNbrsRxDigits EV_TIMEOUT_GOTOMODULE
215556.92 5 rv lg add [Get_Numbers_id]{}
215556.92 5 rv ns add [Get_Numbers_id_PathTaken]{timeout}
215556.92 5 timer clear
215556.92 5 state [vb script:[AfterVM]
215559.88 5 After Hangup script not found: C:\Program Files\VoiceGuide\Scripts\transfer\AfterVM
215559.88 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
215559.88 5 tapi Reply (LineEvReply) ok 66065 0
215600.88 5 timer fired EV_TIMEOUT_TIMETOREINITLINE
215600.88 5 ScriptEventCode 9008 iLineState=900
215600.88 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
215600.88 5 ReinitTelephony due to IDLE
215600.88 5 tapic lineDeallocateCall(MainCall:66099) 0
215600.95 5 lineOpen(5)=>
215600.95 5 state Waiting for a call...
215600.97 5 LineHandle=66048
215600.97 5 amchk set AMdet=False in Reinit@idle
215600.97 5 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
215601.34 0 dial start any summary:|5:rdy=0|6:idx=0|7:idx=0|
215604.25 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
215604.25 5 ScriptEventCode 9013 iLineState=900
215604.38 0 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|
Trace shows that you have a Timeout path leaving module [Get_Numbers_id] which does not seem to point to any existing module - so the script hangs up the call when it times out awaiting input - after only 2 seconds - as that is what the Timeout path is set to be...
The script is not set to play any sound file in the starting module [Get_Numbers_id], so the timeout of 2 seconds starts immediately after answer...
Hi
Thank you for your help.
This is not the case it bomes me out at difrent times, and there is atimeout path.
The only thing changed is the phone hardware.
5 5 timer clear
163117.05 5 state [Evaluate_ring_id_2] Evaluate [($RV_RINGCOUNT > $RV[DBIS_RINGCOUNT])]
163117.05 5 rv replace start: [($RV_RINGCOUNT > $RV[DBIS_RINGCOUNT])]
163117.05 5 rv ns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\transfer\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\transfer}[$RV_STARTTIME]{1/4/2007 4:31:04 PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{}[DNIS]{}[sql_1_Input]{"select FRWRDNUM, RINGCOUNT, HI_PROMPT, WEEKDAYS,STIME, ETIME, TIMEOUT, rtrim(TIME_RUN), open from ivr_set IVS WHERE (Position('4' IN IVS.WeekDays)>0) AND '16:31' >= STIME AND '16:31' <= ETIME"}[sql_1]{select FRWRDNUM, RINGCOUNT, HI_PROMPT, WEEKDAYS,STIME, ETIME, TIMEOUT, rtrim(TIME_RUN), open from ivr_set IVS WHERE (Position('4' IN IVS.WeekDays)>0) AND '16:31' >= STIME AND '16:31' <= ETIME}[sET_SQL]{select FRWRDNUM, RINGCOUNT, HI_PROMPT, WEEKDAYS,STIME, ETIME, TIMEOUT, rtrim(TIME_RUN), open from ivr_set IVS WHERE (Position('4' IN IVS.WeekDays)>0) AND '16:31' >= STIME AND '16:31' <= ETIME}[Database_setings_RowCount]{1}[Database_setings_1_1]{9,1,866-619-4682 }[Database_setings_2_1]{2}[Database_setings_3_1]{c:\vgwav\computer.wav, c:\vgwav\message.wav, c:\vgwav\p2.wav }[Database_setings_4_1]{71234 }[Database_setings_5_1]{06:30}[Database_setings_6_1]{18:00}[Database_setings_7_1
{}[Database_setings_8_1]{Play_transfer_1}[Database_setings_9_1]{1}[DBIS_FRWRDNUM
{9,1,866-619-4682}[DBIS_RINGCOUNT]{2}[DBIS_HI_PROMPT]{c:\vgwav\computer.wav, c:\vgwav\message.wav, c:\vgwav\p2.wav}[DBIS_WEEKDAYS]{71234}[DBIS_STIME]{06:30}[DBIS_ETIME]{18:00}[DBIS_TI
EOUT]{}[DBIS_TIME_RUN]{Play_transfer_1}[DBIS_OPEN]{1}[MY_LINE_ID]{1}[Evaluate_ri
g_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}[Evaluate_ring_id_2_Input]{(2 > 2)}[Evaluate_ring_id_2]{False}
163117.05 5 rv replace end: [(3 > 2)]
163117.06 5 .Eval((3 > 2))
163117.06 5 rv ns add [Evaluate_ring_id_2_Input]{(3 > 2)}
163117.06 5 rv ns add [Evaluate_ring_id_2]{True}
163117.08 5 Eval Expr result:[True]
163117.08 5 timer clear
163117.08 5 state [Get_Numbers_id] Number Input
163117.08 5 lineAnswer(66407) => 66424
163117.61 5 tapi callstate start
163117.61 5 tapi callstate CONNECTED 66407 1 0
163117.63 5 callstate CONNECTED 66407,1,0
163117.63 5 WorkingModeTAPI@Connected=Answering
163117.63 5 WorkingModeScript@Connected=BeforeAnswerRun
163117.64 5 Inband detection not enabled
163117.64 5 tapi Reply (LineEvReply) ok 66424 0
163117.64 5 timer clear
163117.64 5 state [Get_Numbers_id] Number Input
163117.64 5 state [Get_Numbers_id] Playing ()
163117.64 5 ScriptEventCode 8001 iLineState=1300
163117.66 5 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
163117.66 5 timer set 10 EV_TIMEOUT_HANGUP
163117.66 5 timer set 2 EV_TIMEOUT_GOTOMODULE
163117.66 5 callinfo MONITORMODES
163119.83 5 timer fired EV_TIMEOUT_GOTOMODULE
163119.83 5 ScriptEventCode 9002 iLineState=1301
163119.83 5 LsGetNbrsRxDigits EV_TIMEOUT_GOTOMODULE
163119.83 5 rv lg add [Get_Numbers_id]{}
163119.83 5 rv ns add [Get_Numbers_id_PathTaken]{timeout}
163119.83 5 timer clear
163119.83 5 state [vb script:[AfterVM]
163131.03 5 After Hangup script not found: C:\Program Files\VoiceGuide\Scripts\transfer\AfterVM
163131.03 5 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
163131.03 5 tapi Reply (LineEvReply) ok 66373 0
163132.08 5 timer fired EV_TIMEOUT_TIMETOREINITLINE
163132.08 5 ScriptEventCode 9008 iLineState=900
163132.08 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
163132.08 5 ReinitTelephony due to IDLE
163132.08 5 tapic lineDeallocateCall(MainCall:66407) 0
163132.16 5 lineOpen(5)=>
163132.16 5 state Waiting for a call...
163132.16 5 LineHandle=66390
163132.16 5 amchk set AMdet=False in Reinit@idle
163132.17 5 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
163132.61 0 dial start any summary:|5:rdy=0|6:idx=0|7:idx=0|
163135.45 5 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
163135.45 5 ScriptEventCode 9013 iLineState=900
163135.63 0 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|
163144.58 0 sys cleanup Start
163144.58 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_5_1_0104152948.vbs
163144.59 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_5_1_0104152954.vbs
163144.59 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_5_1_0104153100.vbs
163144.61 0 sys cleanup deleting C:\Program Files\VoiceGuide\temp\vbs_5_2_0104153055.vbs
163144.61 0 sys cleanup End
This trace looks exacly like the previous one.
We can see in it that after answering the call nothing is played and script hangs up 2 seconds later:
Have you looked at your script, in the [Get_Numbers_id] module?
Hi.
I'm posting the part of the script you could see Timeout should go to VBS_CALL_ID
[Get_Numbers_id]
Type=Get Numbers
DispSize=69
Txt=Play a prompt asking the caller to enter a sequence of numbers, speak the sequence back to the caller and ask them to confirm it. Go down different paths depending on the numbers entered...
Replay=0,0
GetNbrLen_Min=0
GetNbrLen_Max=0
Confirm=OFF
VbScript=
VbsHoldPlay=
on {success} goto [vbs_call_id]
on {fail} goto [vbs_call_id]
on {timeout 2} goto [vbs_call_id]
Position=75,438
[vbs_call_id]
Type=Run VB Script
DispSize=69
Txt=Run a VB Script.
VbsFileToRun=
VbsWait=1
VbScript=
dim adsConTrn
dim adsRsCallId
dim iRet
dim strResultVariables
dim strWavFile
Set adsConTrn = CreateObject("ADODB.Connection")
set adsRsCallId = CreateObject("ADODB.Recordset")
adsConTrn.ConnectionString = "FILE NAME=C:\IVR_DATA\IVR.UDL"
adsConTrn.open
adsRsCallId.ActiveConnection = adsConTrn
adsRsCallId.open "select * from call_id where id='$RV[Get_Numbers_id]'", adsConTrn
'msgbox adsRsCallId.RecordCount
if not adsRsCallId.eof then
strResultVariables = "[CALL_NAME]{"& trim(adsRsCallId.Fields("TTS_NAME").value) &"}" '// before close
adsRsCallId.close
adsRsCallId.open "UPDATE call_id SET lastcall=curdate(),lasttime=curtime(),callcount=callcount+1 where id='$RV[Get_Numbers_id]'", adsConTrn
else
adsRsCallId.close
adsRsCallId.open "INSERT INTO call_id (id,lastcall,lasttime,callcount) VALUES ('$RV[Get_Numbers_id]',curdate(), curtime(),1)", adsConTrn
strResultVariables = "[CALL_NAME]{"& "UNKNOWN" &"}"
end if
iRet = WriteResultFile(strResultVariables,2)
Please .ZIP up and post the entire script (the .vgs file) which you are using.
Also please update your system to latest version of VG, as that's the version which we will use when looking at the script.
Thanks for the script. Please now update your system to latest version of VG (as you are using a Dialogic card then the version of the software you should be using is VoiceGuide for Dialogic) and post a trace (.ZIPed) capturing the entire VG startup and incoming call.
[Log]
VoiceGuide=10
I have put back the old BPX and it works fine now.
At the time i purchesed VG the dialogic verson was not around. Later i did not updated to the dialgic ver becouse it was new and i was not sure if it is stable, since the older version was around longer.
Is there any charge to update?
what version dose have fewer bugs ?
I realy like the fact how fast bugs are fixed, but if it anet broken y fix.
Thank you agen for the help
On Dialogic based systems using "VG for Dialogic" is the better choice. Many users run into TAPI layer problems if they do not use VG for Dialogic. (VG for Dialogic deos not use TAPI)
