Help!
Hi i have 16 incoming lines.....and an EPABX system with 102 extensions.....
How can i make this work ....wat modems should i buy.... how can i get a 16 port input for my computer and how can i transfer my calls to the ebabx to an extension ......HELP...If it works ...Id like to buy a licence for 16 lines
Easiest way to setup these systems is to take 16 analog lines from the PBX and attach them to an analog Dialogic card. Then you would be able to transfer calls out of the IVR by doing a simple 'hookflash' type transfer.
The 16 port analog card is the DMV160LP.
Please let us know if you have any further questions.
