magikdo Report post Posted 01/23/2007 12:14 PM Is it possible to detect a return of call or an internal call with a modem or a dialogical card, if so, how? With the end of our script, the PABX transfer on a telephone, if this one is already on line, at the end of some ringings, the call is turned over to the modem Very cordially, Yannick Share this post Link to post
SupportTeam Report post Posted 01/23/2007 10:31 PM This would then arrive back at the system as a new call. You should look into using monitored or announced transfers. You'll need a Dialogic card for these. Share this post Link to post
magikdo Report post Posted 01/23/2007 10:49 PM Thank you !!!! The dialogic D41E PCI support this function, and which module to use, or which function to supervise that, so that when a return of call is presented the chart has script acts differently Verry cordely Yannick Share this post Link to post
SupportTeam Report post Posted 01/23/2007 11:01 PM We'd recommend using current model Dialogic cards, so we'd recommend for you to use the D/41JCT card. Share this post Link to post
magikdo Report post Posted 01/23/2007 11:05 PM Thank you still for these invaluable answers. In do script by which means detect a return of call or an internal call? Share this post Link to post
SupportTeam Report post Posted 01/24/2007 12:31 AM You'd need to have the PBX send Inband Signaling information at call start time. See if the PBX you are using supports Inband Signaling. Alternatively, if the PBX has some sort of CTI port then information sent on this port can be used to determine if the call is new call or a returned transfer. If you are using monitored or announced transfers then the transfer would not be completed in the first place unless the destination extension answers the transferred call, so you'd never get 'returned' calls in the first place. Share this post Link to post
magikdo Report post Posted 01/24/2007 12:50 AM We have a PBX Adept telecom D100E and we do not think that it uses Inband Signaling. On the other hand, when this one make an internal call, the ringing is different from the external ringing of call. Can Voiceguide detect that? Share this post Link to post
SupportTeam Report post Posted 01/24/2007 01:27 AM VoiceGuide can do distinct ring detection. See the "Distinctive Ring" section of the VoiceGuide help file. Share this post Link to post
magikdo Report post Posted 01/24/2007 06:00 PM I have installed dialogic card D/41ESC-PCI but, the transfert call is not functionally. We hear well in the telephone the number of station which it composes, but nothing is to transfer, with a modem kortex, that functions Share this post Link to post
SupportTeam Report post Posted 01/24/2007 09:44 PM Are you doing a hookflash transfer? Maybe the hookflash length is incorrect length... Could you please post a copy of VoiceGuide's Trace Logs which captures the problem, this will allow us to see what happened. Enable logging by setting the log levels to 10 in VG.INI as per below: [Log] VoiceGuide=10 ktTel=10 Then restart VG and make a test call which demonstrates the problem. Trace files will be created in VG's \log\ subdirectory. Please post the traces and the VoiceGuide script used. When posting traces/scripts please .ZIP them up and post them as attachments. Share this post Link to post
magikdo Report post Posted 01/24/2007 10:11 PM Same script with a modem functions, but with the chart dialogic, we hear it well "!" and the number of the station to be composed in the telephone. With the modem, we do not intend this number of the station to be composed Share this post Link to post
SupportTeam Report post Posted 01/24/2007 10:16 PM we hear it well "!" and the number of the station to be composed in the telephone. So the caller hears the number being dialed, correct? Please read: http://www.voiceguide.com/vghelp/html/Dial...llTransfers.htm If using a Dialogic card then you really should be using "VoiceGuide for Dialogic". Share this post Link to post
magikdo Report post Posted 01/24/2007 10:34 PM Is exactly this : B. If the caller hears a click and then hears the DTMF that should be used to dial the number (and hence the number where the call is being transferred to doesn't ring), then the flash time is too short. This is because a hookflash which is too short will just not be noticed by the PBX and the PBX will not put the original caller on hold. we must thus use this procedure? Setting Hookflash length on Dialogic cards - VG for Dialogic When using VoiceGuide for Dialogic the hookflash length is set in Config.xml file. The Config.xml file is located in VoiceGuide's \data\ subdirectory. The following section of Config.xml should be edited: <SetParm> <Description>Flash time during dialing (10ms units)</Description> <Key>DXBD_FLASHTM</Key> <Value>10</Value> <Default>10</Default> </SetParm> A setting of 10 means 100ms. The setting is in 10ms units. Share this post Link to post
SupportTeam Report post Posted 01/24/2007 11:29 PM When using VoiceGuide for Dialogic the hookflash length is set in Config.xml file. Share this post Link to post
magikdo Report post Posted 01/24/2007 11:31 PM Yes, VG for dialogic! 50 is good value? Share this post Link to post
SupportTeam Report post Posted 01/25/2007 12:59 AM You should check what value your PBX expects. A setting of 10 usually works. A setting of 10 means 100ms. The setting is in 10ms units. Share this post Link to post
magikdo Report post Posted 01/25/2007 12:49 PM Hello, For the distinctive ringing With our log, can get information us the values has to enter the file configline.xml This is our last problem, your product will bring entièere satisfaction then to us 124421,05 1 ring time since last ring event (sec): 0,00 124421,05 1 rings=1, min rings before answer=4 (iCallerIdHasArrived=0) 124421,05 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 124421,05 1 event TDX_CST, iCode=134 state=0 124422,94 1 tw lev_CallerID [406,,], strWorkingModeScript=[] iPopupCallerId=0 124422,94 1 cid LastCidMessage values [406,,] 124422,94 1 cid CallerID vars set (in levCallerId) [406,,] 124422,94 1 dnis not defined in rv set 124422,94 1 not adding dnis to rv set 124422,94 1 rings=1, min rings before answer=4 (iCallerIdHasArrived=1) 124422,94 1 tw ring 2 124422,94 1 ring time since last ring event (sec): 1,89 124422,94 1 rings=2, min rings before answer=4 (iCallerIdHasArrived=1) 124422,94 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 124422,95 1 event TDX_CST, iCode=134 state=0 124423,91 1 tw ring 3 124423,91 1 ring time since last ring event (sec): 0,97 124423,91 1 rings=3, min rings before answer=4 (iCallerIdHasArrived=1) 124423,91 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 124423,91 1 event TDX_CST, iCode=134 state=0 124425,41 1 tw ring 4 124425,41 1 ring time since last ring event (sec): 1,50 124425,41 1 rings=4, min rings before answer=4 (iCallerIdHasArrived=1) 124425,41 1 should answer as number of rings reached 124425,41 1 rv clear all 124425,41 1 init LineState ResetAtStartOfNewCall. 124425,41 1 answering the call (406,,,1) 124425,41 1 timer clear Share this post Link to post
SupportTeam Report post Posted 01/25/2007 06:51 PM Could you please post a longer trace (let system ring at least 10 times) for each of the different ring patterns. Share this post Link to post
magikdo Report post Posted 01/25/2007 08:36 PM our log with the internal call attached log.zip Share this post Link to post
magikdo Report post Posted 01/25/2007 08:52 PM Now, attached file for external call log.zip Share this post Link to post
SupportTeam Report post Posted 01/26/2007 09:17 AM Trace shows that on internal call the time between successive rings is a pattern of 1, 1.5, 2.5 seconds : 213005,19 1 tw ring 1 213005,20 1 ring time since last ring event (sec): 0,00 213007,08 1 tw ring 2 213007,08 1 ring time since last ring event (sec): 1,88 213008,05 1 tw ring 3 213008,05 1 ring time since last ring event (sec): 0,97 213009,55 1 tw ring 4 213009,55 1 ring time since last ring event (sec): 1,50 213012,05 1 tw ring 5 213012,05 1 ring time since last ring event (sec): 2,50 213013,05 1 tw ring 6 213013,05 1 ring time since last ring event (sec): 1,00 213014,55 1 tw ring 7 213014,55 1 ring time since last ring event (sec): 1,50 213017,05 1 tw ring 8 213017,05 1 ring time since last ring event (sec): 2,50 213018,05 1 tw ring 9 213018,05 1 ring time since last ring event (sec): 1,00 213019,55 1 tw ring 10 213019,55 1 ring time since last ring event (sec): 1,50 and on external call the start of ring is every 5 seconds: 213751,48 1 tw ring 1 213751,48 1 ring time since last ring event (sec): 0,00 213753,39 1 tw ring 2 213753,39 1 ring time since last ring event (sec): 1,91 213758,34 1 tw ring 3 213758,34 1 ring time since last ring event (sec): 4,95 213803,34 1 tw ring 4 213803,34 1 ring time since last ring event (sec): 5,00 213808,34 1 tw ring 5 213808,34 1 ring time since last ring event (sec): 5,00 213813,34 1 tw ring 6 213813,34 1 ring time since last ring event (sec): 5,00 213818,34 1 tw ring 7 213818,34 1 ring time since last ring event (sec): 5,00 213823,34 1 tw ring 8 213823,34 1 ring time since last ring event (sec): 5,00 213828,34 1 tw ring 9 213828,34 1 ring time since last ring event (sec): 5,00 213833,34 1 tw ring 10 213833,34 1 ring time since last ring event (sec): 5,00 Try using this in your ConfigLine.xml file: <DistinctiveRings> <DistinctiveRing> <Name>RingInternal</Name> <ID>RingInternal</ID> <Description></Description> <Notes></Notes> <Cadence> <On>50</On> <OnDev>10</OnDev> <Off>50</Off> <OffDev>10</OffDev> </Cadence> <Cadence> <On>50</On> <OnDev>10</OnDev> <Off>100</Off> <OffDev>10</OffDev> </Cadence> <Cadence> <On>50</On> <OnDev>10</OnDev> <Off>150</Off> <OffDev>10</OffDev> </Cadence> </DistinctiveRing> <DistinctiveRing> <Name>RingExternal</Name> <ID>RingExternal</ID> <Description></Description> <Notes></Notes> <Cadence> <On>100</On> <OnDev>10</OnDev> <Off>400</Off> <OffDev>10</OffDev> </Cadence> </DistinctiveRing> </DistinctiveRings> After adding this to ConfigLine.xml please post the traces again. Have you read the Help file section covering Distinctive Ring? Share this post Link to post
magikdo Report post Posted 01/26/2007 09:57 AM Test after configfile, internal call 105151,13 1 event callstate OFFERING 1 2,0,0 105151,13 1 script interpretor: VgMulti v6.0.3243 105151,13 1 fired OFFERING event to listeners 105151,13 1 set LineState().hCall = 1 in LINECALLSTATE_OFFERING 105151,13 1 cid CallerID vars set (in 'offering' event) [,,] 105151,13 1 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 105151,13 1 rings=0, min rings before answer=10 (iCallerIdHasArrived=0) 105151,13 1 tw ring 1 105151,14 1 ring time since last ring event (sec): 0,00 105151,14 1 rings=1, min rings before answer=10 (iCallerIdHasArrived=0) 105151,14 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105151,14 1 event TDX_CST, iCode=134 state=0 105153,02 1 tw lev_CallerID [406,,], strWorkingModeScript=[] iPopupCallerId=0 105153,02 1 cid LastCidMessage values [406,,] 105153,02 1 cid CallerID vars set (in levCallerId) [406,,] 105153,02 1 dnis not defined in rv set 105153,02 1 not adding dnis to rv set 105153,02 1 rings=1, min rings before answer=10 (iCallerIdHasArrived=1) 105153,03 1 tw ring 2 105153,03 1 ring time since last ring event (sec): 1,91 105153,03 1 rings=2, min rings before answer=10 (iCallerIdHasArrived=1) 105153,03 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105153,03 1 event TDX_CST, iCode=134 state=0 105153,98 1 tw ring 3 105153,98 1 ring time since last ring event (sec): 0,95 105153,98 1 rings=3, min rings before answer=10 (iCallerIdHasArrived=1) 105153,98 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105153,98 1 event TDX_CST, iCode=134 state=0 105155,48 1 tw ring 4 105155,48 1 ring time since last ring event (sec): 1,50 105155,48 1 rings=4, min rings before answer=10 (iCallerIdHasArrived=1) 105155,48 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105155,48 1 event TDX_CST, iCode=134 state=0 105158,00 1 tw ring 5 105158,00 1 ring time since last ring event (sec): 2,52 105158,00 1 rings=5, min rings before answer=10 (iCallerIdHasArrived=1) 105158,00 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105158,00 1 event TDX_CST, iCode=134 state=0 105158,98 1 tw ring 6 105158,98 1 ring time since last ring event (sec): 0,98 105158,98 1 rings=6, min rings before answer=10 (iCallerIdHasArrived=1) 105158,98 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105158,98 1 event TDX_CST, iCode=134 state=0 105200,48 1 tw ring 7 105200,48 1 ring time since last ring event (sec): 1,50 105200,48 1 rings=7, min rings before answer=10 (iCallerIdHasArrived=1) 105200,48 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105200,48 1 event TDX_CST, iCode=134 state=0 105202,98 1 tw ring 8 105202,98 1 ring time since last ring event (sec): 2,50 105202,98 1 rings=8, min rings before answer=10 (iCallerIdHasArrived=1) 105202,98 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105202,98 1 event TDX_CST, iCode=134 state=0 105204,00 1 tw ring 9 105204,00 1 ring time since last ring event (sec): 1,02 105204,00 1 rings=9, min rings before answer=10 (iCallerIdHasArrived=1) 105204,00 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105204,00 1 event TDX_CST, iCode=134 state=0 105205,50 1 tw ring 10 105205,50 1 ring time since last ring event (sec): 1,50 105205,50 1 rings=10, min rings before answer=10 (iCallerIdHasArrived=1) 105205,50 1 should answer as number of rings reached 105205,50 1 rv clear all 105205,50 1 init LineState ResetAtStartOfNewCall. 105205,50 1 answering the call (406,,,1) 105205,50 1 timer clear 105205,50 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105205,50 1 event TDX_CST, iCode=134 state=6001 105205,52 1 LsModuleTransition : 134, [TDX_CST] test external call 105449,05 1 event callstate OFFERING 1 2,0,0 105449,05 1 script interpretor: VgMulti v6.0.3243 105449,05 1 fired OFFERING event to listeners 105449,05 1 set LineState().hCall = 1 in LINECALLSTATE_OFFERING 105449,05 1 cid CallerID vars set (in 'offering' event) [,,] 105449,05 1 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 105449,05 1 rings=0, min rings before answer=10 (iCallerIdHasArrived=0) 105449,05 1 tw ring 1 105449,05 1 ring time since last ring event (sec): 0,00 105449,05 1 rings=1, min rings before answer=10 (iCallerIdHasArrived=0) 105449,05 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105449,05 1 event TDX_CST, iCode=134 state=0 105450,94 1 tw lev_CallerID [00877902345,,], strWorkingModeScript=[] iPopupCallerId=0 105450,94 1 cid LastCidMessage values [00877902345,,] 105450,94 1 cid CallerID vars set (in levCallerId) [00877902345,,] 105450,94 1 dnis not defined in rv set 105450,94 1 not adding dnis to rv set 105450,94 1 rings=1, min rings before answer=10 (iCallerIdHasArrived=1) 105450,94 1 tw ring 2 105450,94 1 ring time since last ring event (sec): 1,89 105450,94 1 rings=2, min rings before answer=10 (iCallerIdHasArrived=1) 105450,94 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105450,95 1 event TDX_CST, iCode=134 state=0 105455,89 1 tw ring 3 105455,89 1 ring time since last ring event (sec): 4,95 105455,89 1 rings=3, min rings before answer=10 (iCallerIdHasArrived=1) 105455,89 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105455,91 1 event TDX_CST, iCode=134 state=0 105500,91 1 tw ring 4 105500,91 1 ring time since last ring event (sec): 5,02 105500,91 1 rings=4, min rings before answer=10 (iCallerIdHasArrived=1) 105500,91 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105500,91 1 event TDX_CST, iCode=134 state=0 105505,91 1 tw ring 5 105505,91 1 ring time since last ring event (sec): 5,00 105505,91 1 rings=5, min rings before answer=10 (iCallerIdHasArrived=1) 105505,91 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105505,91 1 event TDX_CST, iCode=134 state=0 105510,89 1 tw ring 6 105510,89 1 ring time since last ring event (sec): 4,98 105510,89 1 rings=6, min rings before answer=10 (iCallerIdHasArrived=1) 105510,91 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105510,91 1 event TDX_CST, iCode=134 state=0 105515,91 1 tw ring 7 105515,91 1 ring time since last ring event (sec): 5,02 105515,91 1 rings=7, min rings before answer=10 (iCallerIdHasArrived=1) 105515,91 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105515,91 1 event TDX_CST, iCode=134 state=0 105520,91 1 tw ring 8 105520,91 1 ring time since last ring event (sec): 5,00 105520,91 1 rings=8, min rings before answer=10 (iCallerIdHasArrived=1) 105520,91 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105520,91 1 event TDX_CST, iCode=134 state=0 105525,89 1 tw ring 9 105525,89 1 ring time since last ring event (sec): 4,98 105525,89 1 rings=9, min rings before answer=10 (iCallerIdHasArrived=1) 105525,89 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105525,89 1 event TDX_CST, iCode=134 state=0 105530,91 1 tw ring 10 105530,91 1 ring time since last ring event (sec): 5,02 105530,91 1 rings=10, min rings before answer=10 (iCallerIdHasArrived=1) 105530,91 1 should answer as number of rings reached 105530,91 1 rv clear all 105530,91 1 init LineState ResetAtStartOfNewCall. 105530,91 1 answering the call (00877902345,,,1) 105530,91 1 timer clear 105530,92 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105530,92 1 event TDX_CST, iCode=134 state=6001 105530,92 1 LsModuleTransition : 134, [TDX_CST] 105531,59 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 105531,59 1 event TDX_SETHOOK, iCode=135 state=6001 105531,59 1 LsModuleTransition : 135, [TDX_SETHOOK] 105531,59 1 event callstate CONNECTED 1 256,0,0 i'm french and, i don't understand the help file Share this post Link to post
magikdo Report post Posted 01/26/2007 10:09 AM two test external : 110539,80 1 event callstate OFFERING 1 2,0,0 110539,80 1 script interpretor: VgMulti v6.0.3243 110539,80 1 fired OFFERING event to listeners 110539,80 1 set LineState().hCall = 1 in LINECALLSTATE_OFFERING 110539,80 1 cid CallerID vars set (in 'offering' event) [,,] 110539,80 1 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 110539,80 1 rings=0, min rings before answer=10 (iCallerIdHasArrived=0) 110539,80 1 tw ring 1 110539,81 1 ring time since last ring event (sec): 0,00 110539,81 1 rings=1, min rings before answer=10 (iCallerIdHasArrived=0) 110539,81 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110539,81 1 event TDX_CST, iCode=134 state=0 110541,69 1 tw lev_CallerID [00877902345,,], strWorkingModeScript=[] iPopupCallerId=0 110541,69 1 cid LastCidMessage values [00877902345,,] 110541,69 1 cid CallerID vars set (in levCallerId) [00877902345,,] 110541,69 1 dnis not defined in rv set 110541,69 1 not adding dnis to rv set 110541,69 1 rings=1, min rings before answer=10 (iCallerIdHasArrived=1) 110541,69 1 tw ring 2 110541,70 1 ring time since last ring event (sec): 1,89 110541,70 1 ring match against pattern 1, cadences=1 110541,70 1 ring template 1, cadence 1 = [100|20] edge time=189,1 110541,70 1 ring match distinct ring pattern 1 cycle 1 fail 110541,70 1 ring match against pattern 2, cadences=1 110541,70 1 ring template 2, cadence 1 = [500|20] edge time=189,1 110541,70 1 ring match distinct ring pattern 2 cycle 1 fail 110541,70 1 rings=2, min rings before answer=10 (iCallerIdHasArrived=1) 110541,70 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110541,70 1 event TDX_CST, iCode=134 state=0 110546,67 1 tw ring 3 110546,67 1 ring time since last ring event (sec): 4,97 110546,67 1 ring match against pattern 1, cadences=2 110546,67 1 ring template 1, cadence 1 = [100|20] edge time=189,1 110546,67 1 ring match distinct ring pattern 1 cycle 1 fail 110546,67 1 rings=3, min rings before answer=10 (iCallerIdHasArrived=1) 110546,67 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110546,67 1 event TDX_CST, iCode=134 state=0 110551,67 1 tw ring 4 110551,67 1 ring time since last ring event (sec): 5,00 110551,67 1 ring match against pattern 1, cadences=3 110551,67 1 ring template 1, cadence 1 = [100|20] edge time=189,1 110551,67 1 ring match distinct ring pattern 1 cycle 1 fail 110551,67 1 rings=4, min rings before answer=10 (iCallerIdHasArrived=1) 110551,67 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110551,67 1 event TDX_CST, iCode=134 state=0 110556,66 1 tw ring 5 110556,66 1 ring time since last ring event (sec): 4,98 110556,66 1 rings=5, min rings before answer=10 (iCallerIdHasArrived=1) 110556,66 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110556,66 1 event TDX_CST, iCode=134 state=0 110601,67 1 tw ring 6 110601,67 1 ring time since last ring event (sec): 5,02 110601,67 1 rings=6, min rings before answer=10 (iCallerIdHasArrived=1) 110601,67 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110601,67 1 event TDX_CST, iCode=134 state=0 110606,67 1 tw ring 7 110606,67 1 ring time since last ring event (sec): 5,00 110606,67 1 rings=7, min rings before answer=10 (iCallerIdHasArrived=1) 110606,67 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110606,67 1 event TDX_CST, iCode=134 state=0 110610,42 0 sys cleanup Start 110610,42 0 sys cleanup End 110611,66 1 tw ring 8 110611,66 1 ring time since last ring event (sec): 4,98 110611,66 1 rings=8, min rings before answer=10 (iCallerIdHasArrived=1) 110611,66 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110611,66 1 event TDX_CST, iCode=134 state=0 110616,67 1 tw ring 9 110616,67 1 ring time since last ring event (sec): 5,02 110616,67 1 rings=9, min rings before answer=10 (iCallerIdHasArrived=1) 110616,67 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110616,67 1 event TDX_CST, iCode=134 state=0 110621,67 1 tw ring 10 110621,67 1 ring time since last ring event (sec): 5,00 110621,67 1 rings=10, min rings before answer=10 (iCallerIdHasArrived=1) 110621,67 1 should answer as number of rings reached 110621,67 1 rv clear all 110621,67 1 init LineState ResetAtStartOfNewCall. 110621,67 1 answering the call (00877902345,,,1) 110621,67 1 timer clear 110621,69 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110621,69 1 event TDX_CST, iCode=134 state=6001 110621,69 1 LsModuleTransition : 134, [TDX_CST] 110622,36 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 110622,36 1 event TDX_SETHOOK, iCode=135 state=6001 110622,36 1 LsModuleTransition : 135, [TDX_SETHOOK] 110622,36 1 event callstate CONNECTED 1 256,0,0 internal 110816,95 1 event callstate OFFERING 1 2,0,0 110816,95 1 script interpretor: VgMulti v6.0.3243 110816,95 1 fired OFFERING event to listeners 110816,95 1 set LineState().hCall = 1 in LINECALLSTATE_OFFERING 110816,95 1 cid CallerID vars set (in 'offering' event) [,,] 110816,95 1 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 110816,95 1 rings=0, min rings before answer=10 (iCallerIdHasArrived=0) 110816,97 1 tw ring 1 110816,97 1 ring time since last ring event (sec): 0,00 110816,97 1 rings=1, min rings before answer=10 (iCallerIdHasArrived=0) 110816,97 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110816,97 1 event TDX_CST, iCode=134 state=0 110818,84 1 tw lev_CallerID [406,,], strWorkingModeScript=[] iPopupCallerId=0 110818,84 1 cid LastCidMessage values [406,,] 110818,84 1 cid CallerID vars set (in levCallerId) [406,,] 110818,84 1 dnis not defined in rv set 110818,84 1 not adding dnis to rv set 110818,86 1 rings=1, min rings before answer=10 (iCallerIdHasArrived=1) 110818,86 1 tw ring 2 110818,86 1 ring time since last ring event (sec): 1,89 110818,86 1 ring match against pattern 1, cadences=1 110818,86 1 ring template 1, cadence 1 = [100|20] edge time=189,1 110818,86 1 ring match distinct ring pattern 1 cycle 1 fail 110818,86 1 ring match against pattern 2, cadences=1 110818,86 1 ring template 2, cadence 1 = [500|20] edge time=189,1 110818,86 1 ring match distinct ring pattern 2 cycle 1 fail 110818,86 1 rings=2, min rings before answer=10 (iCallerIdHasArrived=1) 110818,86 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110818,86 1 event TDX_CST, iCode=134 state=0 110819,83 1 tw ring 3 110819,83 1 ring time since last ring event (sec): 0,97 110819,83 1 ring match against pattern 1, cadences=2 110819,83 1 ring template 1, cadence 1 = [100|20] edge time=189,1 110819,83 1 ring match distinct ring pattern 1 cycle 1 fail 110819,83 1 rings=3, min rings before answer=10 (iCallerIdHasArrived=1) 110819,83 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110819,83 1 event TDX_CST, iCode=134 state=0 110821,33 1 tw ring 4 110821,33 1 ring time since last ring event (sec): 1,50 110821,33 1 ring match against pattern 1, cadences=3 110821,33 1 ring template 1, cadence 1 = [100|20] edge time=189,1 110821,33 1 ring match distinct ring pattern 1 cycle 1 fail 110821,33 1 rings=4, min rings before answer=10 (iCallerIdHasArrived=1) 110821,33 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110821,33 1 event TDX_CST, iCode=134 state=0 110823,83 1 tw ring 5 110823,83 1 ring time since last ring event (sec): 2,50 110823,83 1 rings=5, min rings before answer=10 (iCallerIdHasArrived=1) 110823,83 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110823,83 1 event TDX_CST, iCode=134 state=0 110824,81 1 tw ring 6 110824,81 1 ring time since last ring event (sec): 0,98 110824,81 1 rings=6, min rings before answer=10 (iCallerIdHasArrived=1) 110824,81 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110824,83 1 event TDX_CST, iCode=134 state=0 110826,31 1 tw ring 7 110826,31 1 ring time since last ring event (sec): 1,50 110826,31 1 rings=7, min rings before answer=10 (iCallerIdHasArrived=1) 110826,31 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110826,31 1 event TDX_CST, iCode=134 state=0 110828,83 1 tw ring 8 110828,83 1 ring time since last ring event (sec): 2,52 110828,83 1 rings=8, min rings before answer=10 (iCallerIdHasArrived=1) 110828,83 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110828,83 1 event TDX_CST, iCode=134 state=0 110829,83 1 tw ring 9 110829,83 1 ring time since last ring event (sec): 1,00 110829,83 1 rings=9, min rings before answer=10 (iCallerIdHasArrived=1) 110829,83 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110829,83 1 event TDX_CST, iCode=134 state=0 110831,33 1 tw ring 10 110831,33 1 ring time since last ring event (sec): 1,50 110831,33 1 rings=10, min rings before answer=10 (iCallerIdHasArrived=1) 110831,33 1 should answer as number of rings reached 110831,33 1 rv clear all 110831,33 1 init LineState ResetAtStartOfNewCall. 110831,33 1 answering the call (406,,,1) 110831,33 1 timer clear 110831,33 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110831,34 1 event TDX_CST, iCode=134 state=6001 110831,34 1 LsModuleTransition : 134, [TDX_CST] 110832,02 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 110832,02 1 event TDX_SETHOOK, iCode=135 state=6001 110832,02 1 LsModuleTransition : 135, [TDX_SETHOOK] 110832,02 1 event callstate CONNECTED 1 256,0,0 Share this post Link to post
SupportTeam Report post Posted 01/26/2007 11:46 AM Looks like on this system the 2nd ring always arrives 1.9 seconds after start of first ring - which is affecting the cadence matching. Please modify ConfigLine.xml with these settings: <DistinctiveRings> <DistinctiveRing> <Name>RingInternal</Name> <ID>RingInternal</ID> <Description></Description> <Notes></Notes> <Cadence> <On>50</On> <OnDev>10</OnDev> <Off>140</Off> <OffDev>10</OffDev> </Cadence> <Cadence> <On>50</On> <OnDev>10</OnDev> <Off>50</Off> <OffDev>10</OffDev> </Cadence> <Cadence> <On>50</On> <OnDev>10</OnDev> <Off>100</Off> <OffDev>10</OffDev> </Cadence> <Cadence> <On>50</On> <OnDev>10</OnDev> <Off>150</Off> <OffDev>10</OffDev> </Cadence> </DistinctiveRing> <DistinctiveRing> <Name>RingExternal</Name> <ID>RingExternal</ID> <Description></Description> <Notes></Notes> <Cadence> <On>50</On> <OnDev>10</OnDev> <Off>140</Off> <OffDev>10</OffDev> </Cadence> <Cadence> <On>100</On> <OnDev>10</OnDev> <Off>400</Off> <OffDev>10</OffDev> </Cadence> </DistinctiveRing> </DistinctiveRings> Share this post Link to post
SupportTeam Report post Posted 01/26/2007 11:56 AM A better approach would probably be to ensure the timing of the second ring is ignored altogether. Use this config to effectively ignore the timing of the second ring: <DistinctiveRings> <DistinctiveRing> <Name>RingInternal</Name> <ID>RingInternal</ID> <Description></Description> <Notes></Notes> <Cadence> <On>50</On> <OnDev>40</OnDev> <Off>200</Off> <OffDev>190</OffDev> </Cadence> <Cadence> <On>50</On> <OnDev>10</OnDev> <Off>50</Off> <OffDev>10</OffDev> </Cadence> <Cadence> <On>50</On> <OnDev>10</OnDev> <Off>100</Off> <OffDev>10</OffDev> </Cadence> <Cadence> <On>50</On> <OnDev>10</OnDev> <Off>150</Off> <OffDev>10</OffDev> </Cadence> </DistinctiveRing> <DistinctiveRing> <Name>RingExternal</Name> <ID>RingExternal</ID> <Description></Description> <Notes></Notes> <Cadence> <On>50</On> <OnDev>40</OnDev> <Off>200</Off> <OffDev>190</OffDev> </Cadence> <Cadence> <On>100</On> <OnDev>10</OnDev> <Off>400</Off> <OffDev>10</OffDev> </Cadence> </DistinctiveRing> </DistinctiveRings> Share this post Link to post
magikdo Report post Posted 01/26/2007 08:16 PM Thank you for your assistance!!! Detection functions has wonder, but that does not correct our problem. Indeed, the return of call and the new calls have same rate, it is possible to detect the returns of calls? Share this post Link to post
SupportTeam Report post Posted 01/26/2007 09:56 PM the return of call and the new calls have same rate, it is possible to detect the returns of calls?If the ringing is the same then the only way to distinguish them would be if the PBX was sending some Inband Signaling at call answer time, or if you had a CTI link to the PBX and PBX provided information about the call over the CTI link. So what was causing the two different ringing patterns that we were looking at? Share this post Link to post
magikdo Report post Posted 01/26/2007 10:03 PM The models of detections function well, but I wanted to include/understand that with an aim of detecting a return of call: ( Our PABX does not have Inban signaling nor the CTI port We have to test functions "BUSY" of the transfer of call but that does not function Also, if one transfer with monitoring, it is necessary to wait 3 seconds before being able to be made hear of the correspondent Share this post Link to post
SupportTeam Report post Posted 01/26/2007 10:16 PM So under what circumstances were you seeing the two different types of ring? What type of call was causing the 'shorter' ring and what type of call was causing the 'longer' ring? Share this post Link to post
magikdo Report post Posted 01/26/2007 10:27 PM With the log, the return of call has same rates exactly: - ( Share this post Link to post
SupportTeam Report post Posted 01/26/2007 11:36 PM So how were you creating the situation where one type of call was causing the 'shorter' ring and the other type of call was causing the 'longer' ring? Share this post Link to post
magikdo Report post Posted 01/26/2007 11:44 PM thought that the return of call made the same tonality as an internal call. But a return of call make the same tonality q' a new call Here what one seeks has to make: 1/ a call is dealt with by voice guides 2/ It is transferred on a station interns 3/ This station is occupied or do not answer 4/ Voice guide take again the call and execute another script Here what currently we know to do: 1/ a call is dealt with by voice guides 2/ It is transferred on a station interns 3/ This station is occupied or do not answer 4/ Voice guide take again the call and execute SAME SCRIPT Share this post Link to post
