stetson Report post Posted 01/26/2007 05:54 PM Hello, I began a new campaign three days ago ans everything was working fine. I use a Dialogic D120-JCT and I have an Enterprise License 8 channels for VG I began with 4 lines Today I decided to open two more lines because of the success of the calls ! But the 5th and 6th lines never answered the calls !! Calls are seen in the VG logs but not answered Hereafter are the logs when ringing. (tw log and vgw log) . Whay is this call not answered Thanks for your help ! Jean-Paul DAYAN TW log 184437.968 gc gc_GetMetaEventEx() failed 184437.968 006 ev TDX_CST (CST Event Received) 184437.968 006 ev TDX_CST DE_RINGS data=0 ringcount=1 (hli=0x99077f8, hli->chdev=6, hli->linedev=6) 184437.968 006 CLIDINFO_CMPLT error [128]:[Caller ID info/sub-msg not available] 184437.968 006 CLIDINFO_GENERAL error [128]:[Caller ID info/sub-msg not available] 184437.984 006 CLIDINFO_CALLID error [128]:[Caller ID info/sub-msg not available] 184437.984 006 CLIDINFO_FRAMETYPE error [128]:[Caller ID info/sub-msg not available] 184437.984 006 dlgc caller id frame type: UNKNOWN [0x00] 184437.984 006 pbx display not supported on this card 184437.984 006 pbx display not supported on this card 184437.984 006 info ktTel v2.3.8, Dec 18 2006 10:00:28 184437.984 006 te LINE_CALLSTATE(6, 0x6, 0x2, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_OFFERING 184438.000 006 te LINE_LINEDEVSTATE(6, 0x6, 0x2, 0x0, 0x1) (dwIdx=1053) 184438.000 006 ocxev DoFireDialogic(dwIdx=1054, 6, 134, [TDX_CST], 0, 0, 0, [DE_RINGS], [ET_RON], []) (dwIdx=1054) 184438.015 006 ocxev DoFireDialogic completed 184445.968 006 lTimer_RingsGoAway=0 => WM_FIRE_TIMER_RINGGOESAWAY (hli=0x99077f8) 184445.968 006 ev OnFireTimer_RingGoesAway (hli=0x6) 184445.968 006 te LINE_CALLSTATE(6, 0x6, 0x1, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_IDLE 184447.062 006 ocxfn RingsBeforeAnswer(lLineId=6, lRings=2, lParam1=0, strParam2=) VGM log 184437,98 6 event callstate OFFERING 6 2,0,0 184437,98 6 script interpretor: VgMulti v6.0.3179 184437,98 6 fired OFFERING event to listeners 184437,98 6 set LineState().hCall = 6 in LINECALLSTATE_OFFERING 184437,98 6 cid CallerID vars set (in 'offering' event) [,,] 184438,00 6 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 184438,00 6 rings=0, min rings before answer=2 (iCallerIdHasArrived=0) 184438,00 6 tw ring 1 184438,00 6 ring time since last ring event (sec): 0,00 184438,00 6 rings=1, min rings before answer=2 (iCallerIdHasArrived=0) 184438,00 6 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 184438,02 6 event TDX_CST, iCode=134 state=0 184445,97 6 event callstate IDLE 6 1,0,0 184445,97 6 WorkingMode@Idle= 184445,97 6 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 184445,98 6 timer clear 184445,98 6 LineState(iLineId).iVgsIdx = 0 184445,98 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 184447,06 6 timer fired EV_TIMEOUT_TIMETOREINITLINE 184447,06 6 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=0 184447,06 6 init atidle reinit : start 184447,06 6 init atidle reinit iConferenceOtherLegLid=-1 184447,06 6 init atidle reinit : reset all LineState variables 184447,06 6 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 184447,08 6 state Waiting for a call... 184449,27 6 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 184449,27 6 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=0 184449,27 6 setting iDialoutReadyToDialout=1 Share this post Link to post
SupportTeam Report post Posted 01/26/2007 09:52 PM Traces show that the Dialogic reports that the incoming call only rung the line once. To answer calls which only ring once you should set VG to answer calls after one ring. You may want to test how the different lines ring by attaching a normal telephone handset to them. Share this post Link to post
