Silence Detection
I am using a record module and have a path to an email module - The problem is that when the user records a msessage it detects silence, which is great as it prevents continued recording. But in the log it shows that it is detection the silence and just hangs up and does not proceed to the email module. WHen i put a timeout of zero it works great, but i can not record anything. Is there a commend that i can put in the path for the Record Module so when it detects silence it proceeds to the ned moduel (EMail). Please help - Thank you!
82765 5 tapie linedevstate 2048 0 0
82765 5 tapie callstate OFFERING 66373 0 4
82781 5 Lev_CallerID [13103086400,]
82796 5 tapie callinfo CALLEDID
82796 5 tapie callinfo ORIGIN
82796 5 tapie ring 0
88765 5 tapie ring 2
88765 5 Answer the call
88765 5 lineAnswer(66373) => 66390
89296 5 tapie callstate CONNECTED 66373,1,0
89296 5 WorkingModeTAPI=
89296 5 WorkingModeScript=
89343 5 Inband detection not enabled
89343 5 tapi Reply 66390 0
89343 5 [Play 1] Playing
89343 5 [Play 1] Playing (Greeting.wav)
89359 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Greeting.wav]
89359 5 RunModule PLAY end
93250 5 tapie monitordigits 49 2
93250 5 LsPlayMsg [1]
93296 5 PlaySoundStop ok
93296 5 [Play 5] Playing
93296 5 [Play 5] Playing (Scott Greeting.wav)
93312 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Scott Greeting.wav]
93312 5 RunModule PLAY end
00500 5 tapie monitordigits 49 2
00500 5 LsPlayMsg [1]
00546 5 PlaySoundStop ok
00546 5 [Record 8] Recording
00562 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voicedlgc\beep1.wav]
00765 5 wb(70054600)
00812 5 Play End line[5] (id=700546)
00812 5 LsRecPlayBeep EV_PLAY_FINISHED
00828 5 RecSoundStart file[C:\Program Files\VoiceGuide\Scripts\ScottMesssage.wav] ok
00828 5 RecFile[C:\Program Files\VoiceGuide\Scripts\ScottMesssage.wav]
11046 5 tapie monitortone 1
11359 5 LsRecRecording EV_SILENCE_DETECTED
11359 5 Silence Detected while recording
11421 5 HangupCall called from [lsrec5]
11421 5 Hanging up call...
11421 5 PlaySoundStop ok
11421 5 fnHangupCall end
11468 5 tapie linedevstate 2048 0 0
11468 5 tapie callstate IDLE 66373 0 0
11468 5 WorkingMode@Idle=
11468 5 set EV_TIMEOUT_TIMETOREINITLINE 2
11468 5 tapi Reply 66339 0
12515 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
12515 5 ReinitTelephony due to IDLE start
12515 5 tapic lineDeallocateCall(MainCall:66373) 0
12656 5 lineOpen(5) => 0
12656 5 Waiting for a call...
12656 5 lineOpen(5)LineHandle=66356
From VG Help file's section on "Record Module":
Silence Detection
The recording will stop if silence is detected. Minimum silence length and volume parameters can be set by editing the VG.INI configuration file.
The following type of path can be used to tell VoiceGuide which module to go to next if a silence is detected;
On {silence} Goto [module name goes here]
