Fritz!card Not Outgoing Call, But Incomming Call Ok!
Hello!
I'm useing XP with AVM Fritz!Card + ComISDN Tsp Capi + Vg!
My problem is the following: when i want to start an outgoing call,this always fails! but the incoming calls are OK!
After clicking call button in Telephone Number loader,the original "waiting for a call" changes to "dialing:..."
after a second, it changes back to the original "waiting for a call" without happening (doing) something!
What's the problem!?
Probably,someone who is using Fritz!Card could tell me: what Is the version of the AVM Driver Update which you use or what special configurations do you use in ComISDN
Thank you!
[Log]
VoiceGuide=10
TapiWrapOcx=10
Then restart VG and attampt the outgoing call.
Please post the traces.
Trace shows that the ComISDN driver layer is sending us the DISCONNECTED message just a fraction of a second after it confirms it is dialing.
You will need to speak to ComISDN to ask them why is this happening.
163848,39 9 MakeCall => 65981
163848,39 9 script interpretor: VgMulti v5.2.5049
163850,87 9 callinfo DEVSPECIFIC
163850,87 9 tapi callstate DIALTONE 65777 1 0
163850,87 9 tapi callstate DIALING 65777 0 0
163851,15 9 callinfo DEVSPECIFIC
163851,17 9 tapi callstate DISCONNECTED 65777 256 0
