Retry Counter
I would like to be able to know how many times the caller has entered the incorrect information and then transfer to a customer service representative after 2 tries.
I have the Evaluate Expression set up for validation, but am not sure how to know if this is the first or second validation.
Is this possible in VoiceGuide?
Validation can be setup in the GetNumbers module itself. Then you could use the GetNumbers module's retry counter to limit number of retries.
Alternatively you can setup a Result Variable based counter. A demo of that is provided in the Help file's section on the Evaluate Expression module. See Example 10 here: http://www.voiceguide.com/vghelp/html/modEvalExpr.htm
