Script Desgner
Hello,
How do I tell the version # of the Script Designer I am running ?
What is the latest version ?
I R E A L L Y need to be able to search thru my vb code .... in a single module and throughout the whole script.
thanks,
kevin bamonte
The version number is indicated when you select "About VoiceGuide" option from the Help menu.
The latest version is shipped with VoiceGuide for Dialogic.
the script designer is such an integral part of using the voiceguide software ... are there ANY plans to upgrade this tool ? when is the last time it has been upgraded ?
again a search/replace feature would be very helpful
thanks
If you would like to perform a global search and replace command you could open the .vgs file in a text editor and perform a global search and replace there.
There are no plans to do a global search and replace in Script Designer, although the scripts editor in the VBScript modules will be improved soon. (and will allow search/replace within the module).
