Guest titu Report post Posted 02/28/2007 11:32 AM I have downloaded VoiceGuide trial version for testing telebanking. I have some queries. Please provide me some information. 1. Is it possibe to use Bangla (our language) Language ? 2. Can we do set a voice against digit / amount ? 3. What kinds of license should I purchase ? A.K.M. Shahidul Alam Share this post Link to post
SupportTeam Report post Posted 02/28/2007 12:08 PM 1. Is it possibe to use Bangla (our language) Language ?Yes. Just record the prompts in your language. 2. Can we do set a voice against digit / amount ?You will have to re-record some sound files in VG's \system\voice\ subdirectory, see: http://www.voiceguide.com/vghelp/html/SoundFiles.htm and possibly change the script used by the Say Numbers module if the numbers/amounts/dates are spoken differently in your language. See bottom of http://www.voiceguide.com/vghelp/html/modSayNumber.htm 3. What kinds of license should I purchase ?If you are doing telebanking type application then most likely you will need the Enterprise license. Share this post Link to post
