Run Program Module
I am using a Run Program Module to execute a batch file, but for some reason the Run Program Module is not working. The batch file creates a new file that would be in the directory if VG was working. The Batch file works perfectly when lauched through DOS, so it has to be on the VG side. Below is the log, please note the line in red below as it seems VG is looking for some TXT files that have no relation to me or are anywhere on my system - Please help - Thanks
94968 5 tapie linedevstate 2048 0 0
94968 5 tapie callstate OFFERING 66375 0 4
94984 5 Lev_CallerID [13103086400,]
94984 5 tapie callinfo CALLEDID
95000 5 tapie callinfo ORIGIN
95000 5 tapie ring 0
00968 5 tapie ring 2
06984 5 tapie ring 3
06984 5 Answer the call
06984 5 lineAnswer(66375) => 66392
07515 5 tapie callstate CONNECTED 66375,1,0
07515 5 WorkingModeTAPI=
07515 5 WorkingModeScript=
07562 5 Inband detection not enabled
07562 5 tapi Reply 66392 0
07562 5 [Play 1] Playing
07562 5 [Play 1] Playing (Greeting.wav)
07921 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Greeting.wav]
07921 5 RunModule PLAY end
15000 5 tapie monitordigits 49 2
15000 5 LsPlayMsg [1]
15046 5 PlaySoundStop ok
15046 5 [Play 5] Playing
15046 5 [Play 5] Playing (Scott Greeting.wav)
15062 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Scott Greeting.wav]
15062 5 RunModule PLAY end
23140 5 wb(41504600)
23203 5 Play End line[5] (id=415046)
23203 5 LsPlayMsg EV_PLAY_FINISHED
24203 5 tapie monitordigits 49 2
24203 5 LsPlayMsgFinished [1]
24203 5 [Record 8] Recording
24218 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voicedlgc\beep1.wav]
24406 5 wb(42420300)
24468 5 Play End line[5] (id=424203)
24468 5 LsRecPlayBeep EV_PLAY_FINISHED
24468 5 RecSoundStart file[C:\converter\sm.wav] ok
24468 5 RecFile[C:\converter\sm.wav]
32750 5 tapie monitortone 1
33515 5 LsRecRecording EV_SILENCE_DETECTED
33515 5 Silence Detected while recording
33578 5 [Run Program 2] Run Program
33593 5 Run Program waiting...
34671 5 Could not find VGRUNRESULT_5.TXT or SHLRESLT.TXT
34671 5 HangupCall called from [rwtf 3777]
34671 5 Hanging up call...
34671 5 PlaySoundStop ok
34671 5 fnHangupCall end
34703 5 tapie linedevstate 2048 0 0
34718 5 tapie callstate IDLE 66375 0 0
34718 5 WorkingMode@Idle=
34750 5 set EV_TIMEOUT_TIMETOREINITLINE 2
34750 5 tapi Reply 66341 0
35765 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
35765 5 ReinitTelephony due to IDLE start
35765 5 tapic lineDeallocateCall(MainCall:66375) 0
35906 5 lineOpen(5) => 0
35906 5 Waiting for a call...
35906 5 lineOpen(5)LineHandle=65538
Are you using
command.com /c
on the command line before specifying your batch file?
Run Program entry it should look like this:
command.com /c mybatchfile.bat
The "Could not find VGRUNRESULT_5.TXT or SHLRESLT.TXT" is just a note saying that the batch file did not return any information back to VoiceGuide - it's not an error.
That does not seem to be working, i have tried several different ways:
command.com /c scon.bat
command.com /c c:\converter\scon.bat
command.com c:\converter\scon.bat
None have worked, what am i doing wrong?
Below is the log!
66937 5 tapie linedevstate 2048 0 0
66937 5 tapie callstate OFFERING 65997 0 4
66953 5 Lev_CallerID [13103086400,]
66968 5 tapie callinfo CALLEDID
66968 5 tapie callinfo ORIGIN
66968 5 tapie ring 0
72937 5 tapie ring 2
72937 5 Answer the call
72937 5 lineAnswer(65997) => 65827
73484 5 tapie callstate CONNECTED 65997,1,0
73484 5 WorkingModeTAPI=
73484 5 WorkingModeScript=
73515 5 Inband detection not enabled
73515 5 tapi Reply 65827 0
73515 5 [Play 1] Playing
73515 5 [Play 1] Playing (Greeting.wav)
73531 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Greeting.wav]
73531 5 RunModule PLAY end
77109 5 tapie monitordigits 49 2
77109 5 LsPlayMsg [1]
77156 5 PlaySoundStop ok
77156 5 [Play 5] Playing
77156 5 [Play 5] Playing (Scott Greeting.wav)
77171 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Scott Greeting.wav]
77187 5 RunModule PLAY end
80390 5 tapie monitordigits 49 2
80390 5 LsPlayMsg [1]
80453 5 PlaySoundStop ok
80453 5 [Record 8] Recording
80468 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voicedlgc\beep1.wav]
80671 5 wb(8045300)
80718 5 Play End line[5] (id=80453)
80718 5 LsRecPlayBeep EV_PLAY_FINISHED
80734 5 RecSoundStart file[C:\converter\sm.wav] ok
80734 5 RecFile[C:\converter\sm.wav]
85093 5 tapie monitordigits 35 2
85093 5 LsRecRecording [#]
85140 5 RecSoundStopTruncBytes ok
85140 5 [Run Program 2] Run Program
85156 5 Run Program waiting...
86140 5 Could not find VGRUNRESULT_5.TXT or SHLRESLT.TXT
86140 5 HangupCall called from [rwtf 3777]
86140 5 Hanging up call...
86140 5 PlaySoundStop ok
86140 5 fnHangupCall end
86187 5 tapie linedevstate 2048 0 0
86187 5 tapie callstate IDLE 65997 0 0
86187 5 WorkingMode@Idle=
86187 5 set EV_TIMEOUT_TIMETOREINITLINE 2
86187 5 tapi Reply 65810 0
87234 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
87234 5 ReinitTelephony due to IDLE start
87234 5 tapic lineDeallocateCall(MainCall:65997) 0
87375 5 lineOpen(5) => 0
87375 5 Waiting for a call...
87375 5 lineOpen(5)LineHandle=65861
I've just tried this: In Run Program Module:
command.com /c c:\doecho.bat
contents of c:\doecho.bat:
echo This is a test from VoiceGuide > c:\myout.txt
and file c:\myout.txt was created with "This is a test from VoiceGuide" in it, confirming that VoiceGuide is calling the batch files. Test was done with current 5.0 Beta - but there was no work done on that module between 4.9 and current 5.0
Can you post the batch file which you are trying to run?
Do you perhaps have an "On {Timeout 0}..." path in the Run Program module?
Can you please post the .vgs script file and I can try to reproduce problem here.
OK, apparently batch files can run differently from system to system depending on how paths etc are set up...
I'm told that a sure way to get them to run is to create a shortcut to the batch file (a .LNK file) and run that instead... do a DIR in DOS to see what is the exact filename of the shortcut.
I'm not too sure how passing parameters to the batch file would work in this case...
Ok we have made serious progress with this process but there are a few other kinks:
1) The command.com xpression locks up with VG, but cmd.exe works fine, so I can stick with that for now.
2) VG is finaly running the batch file successfully using the following command line in your Run Program Module (c:\winnt\system32\cmd.exe /c c:\scon.lnk), but for whatever reason VG will not move onto the email module, the only way i got it to successful move to the Email module was to add a Fail path in the Run Command Module.
3) in my batch file last line i have a "close" command, when i execute the batch command outside of VG it runs everything and then executes the close command hence closes the DOS window. WHen the batch file gets executed from VG i get this error:
'close' is not recognized as an internal or external coomand, operable program or batch file. Why is this? Below is what is in my batch file:
del c:\converter\sm2.wav %1
c:\converter\audiocv.exe -of 48000 sm.wav sm2.wav %2
c:\converter\BladeEnc.exe -quit c:\converter\sm2.wav %3
close %4
Here is also my log - Thanks
45046 5 tapie linedevstate 2048 0 0
45062 5 tapie callstate OFFERING 65812 0 4
45062 5 Answer the call
45078 5 lineAnswer(65812) => 66119
45078 5 Lev_CallerID [13103086400,]
45078 5 tapie callinfo CALLEDID
45078 5 tapie callinfo ORIGIN
45078 5 tapie ring 0
45609 5 tapie callstate CONNECTED 65812,1,0
45609 5 WorkingModeTAPI=
45609 5 WorkingModeScript=
45656 5 Inband detection not enabled
45656 5 tapi Reply 66119 0
45656 5 [Play 1] Playing
45656 5 [Play 1] Playing (Greeting.wav)
45671 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Greeting.wav]
45671 5 RunModule PLAY end
48703 5 tapie monitordigits 49 2
48703 5 LsPlayMsg [1]
48750 5 PlaySoundStop ok
48750 5 [Play 5] Playing
48750 5 [Play 5] Playing (Scott Greeting.wav)
48765 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Scott Greeting.wav]
48765 5 RunModule PLAY end
50343 5 tapie monitordigits 49 2
50343 5 LsPlayMsg [1]
50406 5 PlaySoundStop ok
50406 5 [Record 8] Recording
50421 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voicedlgc\beep1.wav]
50609 5 wb(45040600)
50671 5 Play End line[5] (id=450406)
50671 5 LsRecPlayBeep EV_PLAY_FINISHED
50687 5 RecSoundStart file[C:\converter\sm.wav] ok
50687 5 RecFile[C:\converter\sm.wav]
59437 5 tapie monitortone 1
59734 5 LsRecRecording EV_SILENCE_DETECTED
59734 5 Silence Detected while recording
59781 5 [Run Program 2] Run Program
59781 5 Run Program waiting...
60875 5 Could not find VGRUNRESULT_5.TXT or SHLRESLT.TXT
60875 5 [send Email 10] Send Email
60875 0 Queue Email (SMTP) 4 scott.thibodeau@adelphia.net
60875 5 Send Email OK
60875 5 HangupCall called from [Run module 3098]
60875 5 Hanging up call...
60875 5 PlaySoundStop ok
60875 5 fnHangupCall end
60921 5 tapie linedevstate 2048 0 0
60921 5 tapie callstate IDLE 65812 0 0
60921 5 WorkingMode@Idle=
60921 5 set EV_TIMEOUT_TIMETOREINITLINE 2
60921 5 tapi Reply 66102 0
60984 0 Email (SMTP) send start idx=4 scott.thibodeau@adelphia.net
60984 0 smtp Status Connecting to SMTP Server (xstreammedia.net)...
61234 0 smtp Status Initializing Communications...
61359 0 smtp Status Sending Sender Information...
61359 0 smtp Progress 0%
61609 0 smtp Status Sending Recipient Information...
61828 0 smtp Status Sending Message...
61968 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
61968 5 ReinitTelephony due to IDLE start
61968 5 tapic lineDeallocateCall(MainCall:65812) 0
62125 5 lineOpen(5) => 0
62125 5 Waiting for a call...
62125 5 lineOpen(5)LineHandle=66153
62125 0 smtp Status Sending Attachment, sm2.mp3...
62140 0 smtp Progress 15%
62609 0 smtp Progress 30%
63062 0 smtp Progress 44%
63546 0 smtp Progress 59%
64000 0 smtp Progress 74%
64578 0 smtp Progress 89%
65140 0 smtp Progress 100%
66156 0 smtp Progress 100%
66156 0 smtp Status Transmission Complete...
66156 0 smtp Status Closing Connection...
66390 0 smtp SendSuccesful
66390 0 Email (SMTP) send end
Have you tried using "exit" instead of "close" ?
Have you tried using v5.0 Beta ?
The email module setup is much better in v5.0 then it was in v4.9
Yes i have used "exit" as well, and the DOS Window stays open (Only when executing in VG).
I am not having any email issues, - The problem is related to i believe is that because VG is unable to close the DOS window it thinks the process has falied, so the expression on Success goto email module does not work and when i include on fail goto email module - it proceeds and everything works. But that is not a satifacory solution as the dos window must close otherwise i will have a 1000 dos windows open everyday.
As for the ability to close the dos window it works fine when i run the batch by itself, I only have a problem when VG exzecutes it.
Please help - Thank
Have you tried setting up a shortcut to the batch file (link file - .LNK suffix) and running that instead?
Yes i have and that is how i actualy got the batch file to actualy run, now i need it to close the DOS window.
Please try building a batch file and have it run through the VG RUn Program Module and see if you can get it to close after it is done running the batch file. It is critical that i get this problem resolved - Thanks
Well it looks like that every version of Windows will start the batch files differently and each version of Windows uses different methods of deciding whether or not the DOS windows close after running the batch files.
More info can be gleaned from : http://www.google.com.au/groups
Run a search on: closing DOS window after running batch file
and read the many suggestions and see which one works for you...
Generally, for Win95/98/ME systems:
Put CLS before EXIT.
and for NT:
use START /B instead of COMMAND.COM /C  use "Start /?" command to lean more about Start.
At our offices we use Win2000 or XP and all the DOS windows which were running batch files from VG's Run Program module just close themselves without anything special being required...
Another Approach:
In Run Program module select "Wait until Program Finishes" and then specify a Timeout path - when the timeout is reached VoiceGuide will forcibly shutdown the called program and continue on to the Module specified in the Timeout path. The timeout value should be large enough to ensure that any processing done by the batch file completes before VoiceGuide forcibly closes it down...
I'd probably suggest getting something simple to work first - like the test that was described a few posts before:
and file c:\myout.txt was created with "This is a test from VoiceGuide" in it, confirming that VoiceGuide is calling the batch files. (the windows did close afterwards as well on our system)
Thanks for all your help, but i finaly isolated what the problem is as i had tested opening up MS Word and the dos windows closed successfully, I also duplicated your ECHO test which also worked fine, then i went line by line in my batch file trying to isloate which command or application VG was conflicting with. On your guys recommendation i used SOX audio app to covert the incoming recorded sound, this is the confilct that has been giving me so much trouple.
I am assuming since you recommended SOX audio that you would probably have it on your machine. Can you please duplicate my scenario and see if your system automaticaly closes the DOX Prompt upon completeion of the task. If you come across the same problem is there a fix?
Thank you for all your help and let me know your thoughts - Thanks
To add additional information to my last post - I just noticed that the issue arrises only when i use freq or bit rate conversion SW. In addtion to trying SOX i have tired two other DOS based conversion apps. As i mentioned running other applications like WORD or WAV to MP3 converters everything works fine. The Freq and Bit rate Conversion SW is critical as the audio files must be converted to a form that the WAV to MP3 converter can take to convert to a MP3.
Please HELP - Thank you
I'd recommend searching the web for another software which you can use instead of the one which is causing problems in the batch file, we can only really spend time assisting on issues directly related to VoiceGuide...
