Isdn Pri Settings
Having problem on how i can correct the settings of the ISDN PRI to sync with the Dialogic. Please Help. Tnx
What are the problems that you are having?
Have you read the Help file's section on configuring the T1/E1 ISDN systems?
You should be using "VoiceGuide for Dialogic"... there is no need to install any TAPI/Wave drivers - just install the Dialogic System Release drivers, that's all.
with SR511all installation i can find the oemsetup at the dialogic/lib but with the dialogic system driver i cant finsd it. what shall i do?
OemSetup is not needed for correct Dialogic driver operation. You will be able to use the Dialogic card after running the System Release driver setup.
I'm just following the installation guide in the site. where can i find the complete installtion guide? im using a D/600jct. tnx
the vg and the dialogic was already installed. but if i call the number i just get a busy signal. how can i fixed it? tnx
Have you read the page of the VoiceGuide Help file titled: "T1/E1 ISDN Configuration"?
In particular you shold look at the section titled: "Testing ISDN Line".
If you are unable to receive/make calls and play/record sound files with isdiag then you will need to contact your local Dialogic supplier to establish why the hardware they provided does not work on the T1/E1 lines from your telephone company. Sometimes modified drivers are required for the Dialogic card in order for it to be able to work with local Telco's ISDN lines and your local Dialogic supplier should be familiar with all the local telephone companies' ISDN protocols and know what should be done in order for the Dialogic cards to be able to work with the ISDN lines in your local area.
Why is it if I make a test call using vg it says that i have to register? asking for the registration id
The evaluation version limitations are listed at the bottom of this page: http://www.voiceguide.com/vgFeatures.htm
With the Evaluation version of VoiceGuide you can just restart VoiceGuide again and use it again for another hour.
Once you have evaluated VoiceGuide and are ready to purchase then the licenses can be purchased from our online order page. (see the "Buy Now" link).
