Guest SalC Report post Posted 08/06/2003 07:11 PM Hi... I have installed Beta 16 on a new system to test. Running Win ME, with a Lucent Win Modem. I tried calling the system and as soon as it answeres, it hangsup. Here is the trace log: 150346.89 0 callstate OFFERING 4343200 0 4 150346.89 0 ring 1 150349.86 0 ring 2 150349.86 0 Answer the call at 8/6/2003 3:03:49 PM 150349.86 0 lineAnswer(4343200) => 7 150349.86 0 tapi Reply 7 0 150349.86 0 callstate ACCEPTED 4343200 0 0 150349.97 0 callstate CONNECTED 4343200,0,0 150349.97 0 WorkingModeTAPI= 150349.97 0 WorkingModeScript= 150349.97 0 Inband detection not enabled 150349.97 0 StartLoadedVgs at 8/6/2003 3:03:49 PM 150350.02 0 [Welcome] Playing 150350.02 0 tts generate start[Welcome to JMI Software Consultants, Support Line. Please Press 1, to leave a detailed message. Or press 2, to retrieve messages.] 150350.63 0 tts generate end 150350.63 0 [Welcome] Playing (C:\PROGRAM FILES\IVG\system\tts0.wav) 150350.96 0 PlaySoundStart ok [C:\PROGRAM FILES\IVG\system\tts0.wav] 150351.01 0 RunModule PLAY end 150420.34 0 Play End line[0] (id=17158) 150420.34 0 LsPlayMsg EV_PLAY_FINISHED 150431.22 0 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG 150431.22 0 tts generate reuse 150431.22 0 [Welcome] Playing (C:\PROGRAM FILES\IVG\system\tts0.wav) 150431.44 0 PlaySoundStart ok [C:\PROGRAM FILES\IVG\system\tts0.wav] 150440.77 0 wb(5775000) 150440.77 0 Play End line[0] (id=57750) 150440.77 0 LsPlayMsg EV_PLAY_FINISHED 150451.65 0 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG 150451.70 0 tts generate reuse 150451.70 0 [Welcome] Playing (C:\PROGRAM FILES\IVG\system\tts0.wav) 150451.87 0 PlaySoundStart ok [C:\PROGRAM FILES\IVG\system\tts0.wav] 150501.21 0 Play End line[0] (id=78211) 150501.21 0 LsPlayMsg EV_PLAY_FINISHED 150512.14 0 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG 150512.14 0 tts generate reuse 150512.14 0 [Welcome] Playing (C:\PROGRAM FILES\IVG\system\tts0.wav) 150512.30 0 PlaySoundStart ok [C:\PROGRAM FILES\IVG\system\tts0.wav] 150521.64 0 Play End line[0] (id=98673) 150521.64 0 LsPlayMsg EV_PLAY_FINISHED 150532.57 0 LsPlayMsgFinished EV_TIMEOUT_HANGUP 150532.57 0 Hanging up call... 150532.62 0 RecSoundStop ok 150532.62 0 PlaySoundStop ok 150532.62 0 fnHangupCall end 150534.82 0 Hanging up call...(2) 150534.87 0 RecSoundStop ok 150534.87 0 PlaySoundStop ok 150534.87 0 fnHangupCall end 150534.87 0 LsAwaitingCalls EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 150534.87 0 tapi Reply 9 LINEERR_INVALCALLSTATE [8000001C] 150537.73 0 callstate IDLE 4343200 0 0 150537.79 0 WorkingMode@Idle= 150537.84 0 tapi Reply 8 0 150538.83 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 150538.88 0 ReinitTelephony due to IDLE start 150538.88 0 tapic lineDeallocateCall(MainCall:4343200) 0 150544.54 0 lineOpen(0) => 0 150544.54 0 Waiting for a call... 150544.54 0 lineOpen(0)LineHandle=4342040 Share this post Link to post
SupportTeam Report post Posted 08/07/2003 12:36 AM It all looks OK, so I suspect that the Wave drivers for this modem are not working well... so the sound file is not getting played through the modem wave device but through somewhere else (usually when wave drivers are messed up it ends up being played through the PC speaker...) Can you try removing all the wave drives on your system (including any sound card drivers) and then re-installing the wave drivers for your telephony device first. Try calling in after doing this, and if the sound can be heard over the phone you can then try to re-install your sound card drivers. To remove other wave drivers got to Control Panel, double clock on System, select the Device Manager tab and go to Sound/Video/Game Controllers entry - then delete all other wave drivers. Share this post Link to post
