Zoltan Report post Posted 03/15/2007 03:05 PM I would like to access the same database with VG and also througth the internet. The database is on my home PC that runs on Win XP and I use Apache webserver. My IP dynamically changes. Is it possible to send the current IP to VG? How? In this case, the caller could listen to the current IP address on the phone and connect to my pc through the internet by entering my IP in a web browser. Share this post Link to post
SupportTeam Report post Posted 03/15/2007 08:22 PM Guess from VG you could retrieve IP info from http://www.whatismyip.org/ or similar and play that over the phone. Some examples of how to 'screen scrape' web pages are provided in Help file's entry on the Run VBScript module. Share this post Link to post
Zoltan Report post Posted 03/25/2007 04:21 AM Yes. Thank you. But in this case I would depend on a third party's internet service. Can VoiceGuide directly retrieve my own IP from my computer with a VBscript modul. When I type ipconfig in the DOS command promt I can see my IP address. So if I could make a script in VG to capture this IP address info directly from my pc into a VG variable, I could announce it through another VG modul. I just need this script sample. Share this post Link to post
SupportTeam Report post Posted 03/25/2007 04:50 AM A quick search on Google turned up the sample code below. We tried it and it does report the IP addresses on the system. arAddresses = GetIPAddresses() msgbox ubound(arAddresses)+1 & " IP Address(es) found" for each ip in arAddresses msgbox ip next Function GetIPAddresses() '===== ' Returns array of IP Addresses as output by ipconfig or winipcfg... ' ' Note: The PPP Adapter (Dial Up Adapter) is ' excluded if not connected (IP address will be 0.0.0.0) ' and included if it is connected. '===== set sh = createobject("wscript.shell") set fso = createobject("scripting.filesystemobject") workfile = fso.gettempname sh.run "%comspec% /c ipconfig > " & workfile,0,true set sh = nothing set ts = fso.opentextfile(workfile) data = split(ts.readall,vbcrlf) ts.close set ts = nothing fso.deletefile workfile set fso = nothing arIPAddress = array() index = -1 for n = 0 to ubound(data) if instr(data(n),"IP Address") then parts = split(data(n),":") if trim(parts(1)) <> "0.0.0.0" then index = index + 1 ReDim Preserve arIPAddress(index) arIPAddress(index)= trim(cstr(parts(1))) end if end if next GetIPAddresses = arIPAddress End Function Share this post Link to post
Zoltan Report post Posted 03/26/2007 05:44 AM Thank you for your help. It works. Do you have a special depository on your web site where people can submit their VB scripts, snippets, VG designs and other solutions that they think can be useful for others? That would be a great help for VG users and a good marketing tool for your business, too. Share this post Link to post
SupportTeam Report post Posted 03/26/2007 06:11 AM If you would like to submit a script we could add it to the Example Scripts section. We would also accept scripts which are saved as Protected (.vgp) or are limited in some other way and other users after evaluating the solution could contact the script supplier to obtain the full working version or a version modified to suit their requirements. Share this post Link to post
