Inserting To Db
i tried a simple query to insert values into a database, i am getting no errors but the script doesn't update the database, i have attached the script please help.
datascript.vgs
I think your issue is the connection string. Granted, I don't use MDB files, I use SQL through ODBC. If you set up a DSN for this connection through, it should work the same.
My data source name is the name of the DSN.
The connection string is: ODBC;UID=userid;PWD=password;
See the examples in Help file which show how to connect to various databases.
For a simple MS Access connection just specify the filename and leave the 'Connect' string blank.
How do i connect to SQL server Express Editon 2005
is it
DASH3\SQLEXPRESS for the database
and
Driver={SQL Native Client};Server=DASH3\SQLEXPRESS;Database=Eskom;Trusted_Connection=yes;
for the connection string
i am trying this and its not working
You should consult the particular database's manual for information on what Connect string the particular database accepts.
