Microsoft Access Error Messages
I'm using a simple database query of the form "SELECT fieldname FROM tablename WHERE keyfield='somevalue'", referencing an Access database. So, in the database module I'm just specifying an mdb file, no connect string.
I'm using various queries in my script, most of which work fine. One particular query, no more complicated than any of the others is resulting in a FAIL path being taken ... but I have no idea why!!
Is there some way to obtain the error message that is associated with the query? I'm thinking that something really simply is going wrong, but have not been able to figure it out :( At the very least, is there some way of knowing the exact query string that is being sent to Access?
Thanks,
[Log]
VoiceGuide=10
Thank you, Gentlemen.
Turning on the log info to 10 gave me all the information I needed to find the problem, and actually revealed other latent issues yet to be found the hard way :)
Now if only I can get the TTS stuff working :) :)
Quilpole.
