Guest HenryMc Report post Posted 08/08/2003 02:57 AM How can I place a call on hold ? The phone system doc states that using a std handset a call can be placed on hold by pressing the 'Recall' button. Thanks Henry Share this post Link to post
SupportTeam Report post Posted 08/08/2003 04:02 AM To issue "Recall" (Flash) just use a Play module - and specify it to play ! (just an exclamation mark) More info on this can be found in the Help file's section on the Play module. Share this post Link to post
Guest HenryMc Report post Posted 08/08/2003 05:18 AM To begin with all I want is a simple script to answer the call and put it on hold... When I call in the call is answered but hung up on immediately. Below is the debug trace... 151147.42 4 linedevstate 2048 0 0 151147.42 4 callstate OFFERING 9458368 0 4 151147.44 4 callinfo CALLEDID 151147.44 4 callinfo ORIGIN 151147.44 4 ring 0 151153.66 4 ring 2 151153.66 4 Answer the call at 8/08/03 15:11:53 151153.66 4 lineAnswer(9458368) => 45 151154.20 4 callstate CONNECTED 9458368,1,0 151154.20 4 WorkingModeTAPI= 151154.20 4 WorkingModeScript= 151154.23 4 Inband detection not enabled 151154.27 4 StartLoadedVgs at 8/08/03 15:11:54 151154.27 4 tapi Reply 45 0 151154.27 4 [Play 1] Playing 151154.28 4 tapic lineGenerateDigits(9458368,!,0) => 0 151154.28 4 RunModule PLAY end 151154.97 4 generate LINEGENERATETERM_DONE 151156.09 4 LsPlayMsg EV_TAPI_GENERATE 151202.05 4 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG 151202.06 4 tapic lineGenerateDigits(9458368,!,0) => 0 151202.80 4 generate LINEGENERATETERM_DONE 151203.84 4 LsPlayMsg EV_TAPI_GENERATE 151209.78 4 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG 151209.80 4 tapic lineGenerateDigits(9458368,!,0) => 0 151210.47 4 generate LINEGENERATETERM_DONE 151211.55 4 LsPlayMsg EV_TAPI_GENERATE 151211.56 4 Hanging up call... [No Paths leaving Play module [Play 1]] 151211.56 4 RecSoundStop ok 151211.56 4 PlaySoundStop ok 151211.58 4 fnHangupCall end 151211.63 4 linedevstate 2048 0 0 151211.63 4 callstate IDLE 9458368 0 0 151211.63 4 WorkingMode@Idle= 151211.64 4 tapi Reply 46 0 151212.84 4 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 151212.89 4 ReinitTelephony due to IDLE start 151212.89 4 tapic lineDeallocateCall(MainCall:9458368) 0 151213.23 4 lineOpen(4) => 0 151213.23 4 Waiting for a call... 151213.23 4 lineOpen(4)LineHandle=9458472 Thanks Henry Share this post Link to post
SupportTeam Report post Posted 08/08/2003 07:45 AM Currently looks like your script is reaching the end without being told what to do next - in these cases it will hang up: 151211.56 4 Hanging up call... [No Paths leaving Play module [Play 1]] The easiest way to tell the script to hang around is to have a long timeout path leaving from the module eg: on {Timeout 3600} goto [Play Finish Call Warning] the above path will cause VG to wait in the module for 1 hour, then go to [Play Finish Call Warning] module... BTW: it's playing hookflash OK: 151154.28 4 tapic lineGenerateDigits(9458368,!,0) => 0 151154.28 4 RunModule PLAY end 151154.97 4 generate LINEGENERATETERM_DONE Share this post Link to post
Guest HenryMc Report post Posted 08/08/2003 08:07 AM What I am trying to achieve as our 1st stage of implmentation of the product is to have VG answer all calls, play a simple wav then place the call on hold and release the call so an operator may pick up the call when available. When I answer a call using a std handset I can achieve this by picking up the receiver when the phone rings, welcome the caller and place them on hold then replace the receiver and wait for the next incoming call. Thanks Henry Share this post Link to post
Guest HenryMc Report post Posted 08/08/2003 08:34 AM Thaks for the previous reply, I've now implemented the timout 3600 as advised. Now when I call in The call is answered and hung up immediately as per before however now the Line is still being held by VG and it still reports the line status as [Play 1] Playing What I want VG to do is answer the call with a greeting, place the caller on hold and then release the call. This way the call on hold can be picked up by an operator and VG is available to answer another incoming call. The debug script is below: 182122.86 4 linedevstate 2048 0 0 182122.86 4 callstate OFFERING 9456176 0 4 182122.89 4 callinfo CALLEDID 182122.89 4 callinfo ORIGIN 182122.89 4 ring 0 182128.89 4 ring 2 182129.03 4 Answer the call at 8/08/03 18:21:29 182129.05 4 lineAnswer(9456176) => 70 182129.59 4 callstate CONNECTED 9456176,1,0 182129.59 4 WorkingModeTAPI= 182129.59 4 WorkingModeScript= 182129.64 4 Inband detection not enabled 182129.64 4 StartLoadedVgs at 8/08/03 18:21:29 182129.64 4 tapi Reply 70 0 182129.64 4 [Play 1] Playing 182129.66 4 tapic lineGenerateDigits(9456176,!,0) => 0 182129.66 4 RunModule PLAY end 182130.33 4 generate LINEGENERATETERM_DONE 182131.45 4 LsPlayMsg EV_TAPI_GENERATE 182137.16 4 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG 182137.20 4 tapic lineGenerateDigits(9456176,!,0) => 0 182137.92 4 generate LINEGENERATETERM_DONE 182139.06 4 LsPlayMsg EV_TAPI_GENERATE 182145.05 4 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG 182145.08 4 tapic lineGenerateDigits(9456176,!,0) => 0 182145.78 4 generate LINEGENERATETERM_DONE 182146.94 4 LsPlayMsg EV_TAPI_GENERATE Share this post Link to post
Guest HenryMc Report post Posted 08/08/2003 09:12 AM I just realised that I have omitted to mention that we are using the product with a phone system utilising 4 incoming lines and 6 extentions, Dialogic handles 4 entensions where the incoming calls ring, then the other two are used by human operators who take the call once it has been answered by VG and placed on hold. Thanks Henry Share this post Link to post
SupportTeam Report post Posted 08/08/2003 12:37 PM If issuing a hookflash hangs up the call this means that the hookfalsh length is too long. Pleas see "Call Transfers and Conferencing" section of VG help file. Share this post Link to post
Guest HenryMc Report post Posted 08/11/2003 07:06 AM I've tried 10, 20, 30, 40 & 50 as the settings for the Dialogic hookflash and restated after every change but it still hangs up... Any further suggestions ? Thanks Share this post Link to post
SupportTeam Report post Posted 08/11/2003 07:33 AM We're using 5 on our PBX... even a setting of 10 is too high... also - I just noticed in your trace that the play module [Play 1] is actually 'replaying' ie: re-issuing the hookflash many times (3?) Please also change the "Replay Count" of that module to zero (0), and then try again with various values for the hookflash length, including 2, 5 and 7 in your set of values to test... Share this post Link to post
HenryMc Report post Posted 08/12/2003 07:56 AM All I require VoiceGuide to do is: answer incoming calls play a welcome message place the call on hold and release the call so an operator can pick up the call from another extension. This should be the same as me answering the call at any extension, welcoming the caller, pressing recall to place the call on hold and hanging up the receiver so the call can be picked op from another extension. I have tried to accomplish this using a simply 3 module script: 1 play - answers call and plays a greeting 2 play - places the call on hold 3 hangup - hangs up the call as it should now be on hold This works until it attempts to place the call on hold then it simply hangs up and drops the line. Debug as follows: 170612.42 4 linedevstate 2048 0 0 170612.42 4 callstate OFFERING 9452624 0 4 170612.44 4 callinfo CALLEDID 170612.44 4 callinfo ORIGIN 170612.44 4 ring 0 170618.42 4 ring 2 170618.42 4 Answer the call at 12/08/03 17:06:18 170618.42 4 lineAnswer(9452624) => 37 170619.05 4 callstate CONNECTED 9452624,1,0 170619.05 4 WorkingModeTAPI= 170619.06 4 WorkingModeScript= 170619.08 4 Inband detection not enabled 170619.08 4 StartLoadedVgs at 12/08/03 17:06:19 170619.08 4 tapi Reply 37 0 170619.09 4 [Welcome] Playing 170619.09 4 [Welcome] Playing (F:\Utils\voice PCM 11kHz 8bit Mono\voice 11kHz 8bit Mono\10.wav) 170619.11 4 PlaySoundStart ok [F:\Utils\voice PCM 11kHz 8bit Mono\voice 11kHz 8bit Mono\10.wav] 170619.11 4 RunModule PLAY end 170619.86 4 wb(22909300) 170620.95 4 Play End line[4] (id=229093) 170620.95 4 LsPlayMsg EV_PLAY_FINISHED 170620.95 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 170620.95 4 [Place on hold] Playing 170620.97 4 tapic lineGenerateDigits(9452624,!,0) => 0 170620.97 4 RunModule PLAY end 170621.67 4 generate LINEGENERATETERM_DONE 170622.84 4 LsPlayMsg EV_TAPI_GENERATE 170622.84 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 170622.84 4 Hanging up call... [Hangup Module] 170622.84 4 RecSoundStop ok 170622.84 4 PlaySoundStop ok 170622.86 4 fnHangupCall end 170622.89 4 linedevstate 2048 0 0 170622.89 4 callstate IDLE 9452624 0 0 170622.89 4 WorkingMode@Idle= 170622.91 4 tapi Reply 38 0 170623.97 4 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 170624.17 4 ReinitTelephony due to IDLE start 170624.17 4 tapic lineDeallocateCall(MainCall:9452624) 0 170624.53 4 lineOpen(4) => 0 170624.53 4 Waiting for a call... 170624.53 4 lineOpen(4)LineHandle=62160368 Share this post Link to post
SupportTeam Report post Posted 08/12/2003 09:02 AM The approach is fine, looks like the only thing that needs to be set correctly is the length of the hookflash... What happens immediately after the hookflash is issued? Is the caller placed on hold, or is the call hung up at the same time? Have you tried settings of below 10 for hookflash length? What PBX are you using ans do you know what hookflash length it expects? It'd be a good idea to alter the script during this testing to hangup some time after the hookflash is issued to help determine whether the hookflash itself works or not... Share this post Link to post
HenryMc Report post Posted 08/12/2003 10:35 PM I've tried values as low as two without success. The line is hung up immediately after the hookflash is issued there is no indication that the hold music is being played etc. The PBX model is a Commander Vision as sold by Commander in Australia. see: www.commander.com/Content/index2.asp?ContentID=35 Do you mean to change the delay to maybe 60 after the hookflash module... I'll make the change and try. 082554.31 4 linedevstate 2048 0 0 082554.31 4 callstate OFFERING 9458664 0 4 082554.33 4 callinfo CALLEDID 082554.33 4 callinfo ORIGIN 082554.33 4 ring 0 082600.41 4 ring 2 082600.41 4 Answer the call at 13/08/03 8:26:00 082600.41 4 lineAnswer(9458664) => 50 082601.08 4 callstate CONNECTED 9458664,1,0 082601.08 4 WorkingModeTAPI= 082601.08 4 WorkingModeScript= 082601.08 4 Inband detection not enabled 082601.08 4 StartLoadedVgs at 13/08/03 8:26:01 082601.08 4 tapi Reply 50 0 082601.08 4 [Welcome] Playing 082601.09 4 [Welcome] Playing (F:\Utils\voice PCM 11kHz 8bit Mono\voice 11kHz 8bit Mono\10.wav) 082601.11 4 PlaySoundStart ok [F:\Utils\voice PCM 11kHz 8bit Mono\voice 11kHz 8bit Mono\10.wav] 082601.11 4 RunModule PLAY end 082601.86 4 wb(41109300) 082602.92 4 Play End line[4] (id=411093) 082602.92 4 LsPlayMsg EV_PLAY_FINISHED 082602.92 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 082602.92 4 [Place on hold] Playing 082602.94 4 tapic lineGenerateDigits(9458664,!,0) => 0 082602.94 4 RunModule PLAY end 082603.63 4 generate LINEGENERATETERM_DONE 082604.83 4 LsPlayMsg EV_TAPI_GENERATE 082717.52 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 082717.52 4 Hanging up call... [Hangup Module] 082717.52 4 RecSoundStop ok 082717.52 4 PlaySoundStop ok 082717.52 4 fnHangupCall end 082717.56 4 linedevstate 2048 0 0 082717.56 4 callstate IDLE 9458664 0 0 082717.56 4 WorkingMode@Idle= 082717.58 4 tapi Reply 52 0 082718.78 4 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 082718.86 4 ReinitTelephony due to IDLE start 082718.86 4 tapic lineDeallocateCall(MainCall:9458664) 0 082719.22 4 lineOpen(4) => 0 082719.22 4 Waiting for a call... 082719.22 4 lineOpen(4)LineHandle=62160688 The difference here is that the line was hung up immediately after playing the wav however the ext that answered the call remained busy for 60 seconds. Thanks Share this post Link to post
HenryMc Report post Posted 08/13/2003 10:13 PM I've set the dialogic hookflash to 10 (100ms) as recommended by Commander and altered the script with a timeout 60 after the first two play modules. After the first timeout the hookflash is issued then the call is dropped but the line is held open by VG for the 60 seconds. I have tried using an analog handset to answer the call and place the call on hold immediately which also worked perfectly. Debug is as follows the two attempts are first one dialing out and backin from an internal ext and secondly dialing in from a mobile, both failed... 161241.84 4 linedevstate 2048 0 0 161241.84 4 callstate OFFERING 9456224 0 4 161241.86 4 callinfo CALLEDID 161241.86 4 callinfo ORIGIN 161241.88 4 ring 0 161247.86 4 ring 2 161247.86 4 Answer the call at 13/08/03 16:12:47 161247.86 4 lineAnswer(9456224) => 3 161248.41 4 callstate CONNECTED 9456224,1,0 161248.41 4 WorkingModeTAPI= 161248.41 4 WorkingModeScript= 161248.44 4 Inband detection not enabled 161248.44 4 StartLoadedVgs at 13/08/03 16:12:48 161248.44 4 tapi Reply 3 0 161248.44 4 [Welcome] Playing 161248.44 4 [Welcome] Playing (F:\Utils\voice PCM 11kHz 8bit Mono\voice 11kHz 8bit Mono\10.wav) 161248.47 4 PlaySoundStart ok [F:\Utils\voice PCM 11kHz 8bit Mono\voice 11kHz 8bit Mono\10.wav] 161248.47 4 RunModule PLAY end 161249.22 4 wb(68543700) 161250.25 4 Play End line[4] (id=685437) 161250.25 4 LsPlayMsg EV_PLAY_FINISHED 161355.77 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 161355.77 4 [Place on hold] Playing 161355.78 4 tapic lineGenerateDigits(9456224,!,0) => 0 161355.78 4 RunModule PLAY end 161356.45 4 generate LINEGENERATETERM_DONE 161357.53 4 LsPlayMsg EV_TAPI_GENERATE 161503.16 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 161503.16 4 Hanging up call... [Hangup Module] 161503.16 4 RecSoundStop ok 161503.16 4 PlaySoundStop ok 161503.16 4 fnHangupCall end 161503.20 4 linedevstate 2048 0 0 161503.20 4 callstate IDLE 9456224 0 0 161503.20 4 WorkingMode@Idle= 161503.22 4 tapi Reply 4 0 161504.25 4 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 161504.25 4 ReinitTelephony due to IDLE start 161504.25 4 tapic lineDeallocateCall(MainCall:9456224) 0 161504.39 4 lineOpen(4) => 0 161504.39 4 Waiting for a call... 161504.39 4 lineOpen(4)LineHandle=9456328 161551.50 4 linedevstate 2048 0 0 161551.50 4 callstate OFFERING 9456656 0 4 161551.52 4 callinfo CALLEDID 161551.52 4 callinfo ORIGIN 161551.52 4 ring 0 161557.50 4 ring 2 161557.50 4 Answer the call at 13/08/03 16:15:57 161557.50 4 lineAnswer(9456656) => 5 161558.05 4 callstate CONNECTED 9456656,1,0 161558.08 4 WorkingModeTAPI= 161558.08 4 WorkingModeScript= 161558.09 4 Inband detection not enabled 161558.09 4 StartLoadedVgs at 13/08/03 16:15:58 161558.11 4 tapi Reply 5 0 161558.11 4 [Welcome] Playing 161558.13 4 [Welcome] Playing (F:\Utils\voice PCM 11kHz 8bit Mono\voice 11kHz 8bit Mono\10.wav) 161558.14 4 PlaySoundStart ok [F:\Utils\voice PCM 11kHz 8bit Mono\voice 11kHz 8bit Mono\10.wav] 161558.14 4 RunModule PLAY end 161558.94 4 wb(87512500) 161559.95 4 Play End line[4] (id=875125) 161559.95 4 LsPlayMsg EV_PLAY_FINISHED 161705.53 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 161705.53 4 [Place on hold] Playing 161705.55 4 tapic lineGenerateDigits(9456656,!,0) => 0 161705.55 4 RunModule PLAY end 161706.22 4 generate LINEGENERATETERM_DONE 161707.31 4 LsPlayMsg EV_TAPI_GENERATE 161812.94 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 161812.94 4 Hanging up call... [Hangup Module] 161812.94 4 RecSoundStop ok 161812.95 4 PlaySoundStop ok 161812.95 4 fnHangupCall end 161813.00 4 linedevstate 2048 0 0 161813.00 4 callstate IDLE 9456656 0 0 161813.02 4 WorkingMode@Idle= 161813.02 4 tapi Reply 6 0 161814.06 4 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 161814.06 4 ReinitTelephony due to IDLE start 161814.06 4 tapic lineDeallocateCall(MainCall:9456656) 0 161814.22 4 lineOpen(4) => 0 161814.22 4 Waiting for a call... 161814.22 4 lineOpen(4)LineHandle=9456760 I have experimented with Values for the hookflash of 1 right through to 10, restarting the server after every change and every setting results in the call being hung up after the hookflash is issued... Help... Share this post Link to post
SupportTeam Report post Posted 08/14/2003 01:58 AM (edited) It does appear that for some reason on your system the setting for the hookflash length is just not being correctly read in /used from the Control Panel's Dialogic TSP configuration... and some longer value is used which results in the call being hung up… From the trace we can see that the LINEGENERATETERM_DONE event which indicates that hookflash generation has completed takes way too long (about 650ms on your system): 161355.78 4 tapic lineGenerateDigits(9456224,!,0) => 0 161355.78 4 RunModule PLAY end 161356.45 4 generate LINEGENERATETERM_DONE here is a trace from our test machine: 121741.64 16 tapic lineGenerateDigits(65570,!,100) => 0 121741.64 16 RunModule PLAY end 121741.88 16 generate LINEGENERATETERM_DONE you should aim to get the LINEGENERATETERM_DONE response time to be lower on your system... I was told that just restarting the service does not always result in the new hookflash length values being read in from the TSP configuration screens - you need to restart the whole machine - which you seem to be doing already anyway... Please also try placing the call on hold by to using a Call Transfer module - please use the "Announced Transfer" option. Do you hear on hold music then? (When you place the call on hold using the analog handset do you hear the on-hold music?) Next please try changing in VG.INI file the "TransferControl_TelBoards" setting to "TAPI" and try using the Call Transfer module's "Announced Transfer" option again: ie, change: [PBX] ;"TAPI" : TAPI functions calls are made to driver to action transfers and conferences. ;"Generate" : tones and signals are generated using TAPI calls TransferControl_TelBoards=Generate to: [PBX] ;"TAPI" : TAPI functions calls are made to driver to action transfers and conferences. ;"Generate" : tones and signals are generated using TAPI calls TransferControl_TelBoards=TAPI ********************************************************************** There is a setting you can use in VG.INI file, in the [PBX] section, see quoted: [PBX] ;Preferred Lengths of hookflash and DTMF tones. ;will be used if Generate method is selected. In milliseconds. DurationHookflash=100 DurationDtmfTone=100 I am told Dialogic ignores these settings but it may be an idea to see if these alter the LINEGENERATETERM_DONE response times on your system... Edited 08/14/2003 03:26 AM by SupportTeam Share this post Link to post
HenryMc Report post Posted 08/14/2003 04:03 AM "you should aim to get the LINEGENERATETERM_DONE response time to be lower on your system..." OK, I agree... how ? Using an announced transfer without changing anything else the results are as follows, interestingly the incoming call is hung up on however stn 20 was dialed with the voice greeting asking the usuals etc and when accepted there was no call there... Does this shed any light on the problem ? 134850.20 4 linedevstate 2048 0 0 134850.20 4 callstate OFFERING 9456224 0 4 134850.23 4 callinfo CALLEDID 134850.23 4 callinfo ORIGIN 134850.23 4 ring 0 134856.20 4 ring 2 134856.20 4 Answer the call at 14/08/03 13:48:56 134856.22 4 lineAnswer(9456224) => 9 134856.75 4 callstate CONNECTED 9456224,1,0 134856.75 4 WorkingModeTAPI= 134856.75 4 WorkingModeScript= 134856.80 4 Inband detection not enabled 134856.81 4 StartLoadedVgs at 14/08/03 13:48:56 134856.81 4 tapi Reply 9 0 134857.17 4 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER 134857.17 4 [Transfer Call 2] Announced Transfer to 20 (Generate) 134857.19 4 tapic lineGenerateDigits(9456224,!,0) => 0 134857.88 4 generate LINEGENERATETERM_DONE 134858.94 4 LsXferStart EV_TAPI_GENERATE 134900.03 4 LsXferPlayVts EV_HOOKFLASHFINISHED 134900.05 4 tapic lineGenerateDigits(9456224,20,0) => 0 134900.33 4 generate LINEGENERATETERM_DONE 134901.36 4 LsXferPlayVts EV_TAPI_GENERATE 134901.36 4 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, , Digits 134901.36 4 twcal PlaySayNumber C:\Program Files\VoiceGuide\system\voicedlgc\TsfrCallFrom.wav, C:\Program Files\VoiceGuide\system\voicedlgc\TsfrAskAccept.wav, , , 1 134901.41 4 PlaySoundStartNumbers ok 134908.42 4 wb(43735901) 134909.45 4 Play End line[4] (id=437359) 134909.45 4 LsXferPlayAnn EV_PLAY_FINISHED 134909.45 4 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG 134909.45 4 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, , Digits 134909.45 4 twcal PlaySayNumber C:\Program Files\VoiceGuide\system\voicedlgc\TsfrCallFrom.wav, C:\Program Files\VoiceGuide\system\voicedlgc\TsfrAskAccept.wav, , , 1 134909.47 4 PlaySoundStartNumbers ok 134916.50 4 wb(44545301) 134917.52 4 Play End line[4] (id=445453) 134917.52 4 LsXferPlayAnn EV_PLAY_FINISHED 134917.52 4 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG 134917.53 4 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, , Digits 134917.53 4 twcal PlaySayNumber C:\Program Files\VoiceGuide\system\voicedlgc\TsfrCallFrom.wav, C:\Program Files\VoiceGuide\system\voicedlgc\TsfrAskAccept.wav, , , 1 134917.55 4 PlaySoundStartNumbers ok 134917.55 4 dtmf 1 (49,2) 134917.55 4 LsXferPlayAnn 1 134918.56 4 PlaySoundStop ok 134919.55 4 LsXferPlayAnn EV_PLAY_FINISHED 134919.55 4 LsXferPlayAnn EV_TAPI_GENERATE 134919.55 4 PlayFinishCause=CallAccepted 134919.55 4 Success path not defined - hanging up (iXferType=1) 134920.64 4 LsXferPlayAnn EV_TIMEOUT_HANGUP 134920.64 4 Hanging up call... 134920.64 4 RecSoundStop ok 134920.64 4 PlaySoundStop ok 134920.64 4 fnHangupCall end 134920.69 4 linedevstate 2048 0 0 134920.69 4 callstate IDLE 9456224 0 0 134920.69 4 WorkingMode@Idle= 134920.69 4 tapi Reply 10 0 134921.73 4 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 134921.73 4 ReinitTelephony due to IDLE start 134921.73 4 tapic lineDeallocateCall(MainCall:9456224) 0 134921.88 4 lineOpen(4) => 0 134921.89 4 Waiting for a call... 134921.89 4 lineOpen(4)LineHandle=9456328 Share this post Link to post
SupportTeam Report post Posted 08/14/2003 07:14 AM If the hookflash is too long then the original call would have been hung up - then the new number dialed - and message played to the new number... still all's pointing to the hookflash being too long... I can imagine how all this is frustrating for you... you're doing all the right things but it's just now working for this system at all... We're beginning to look at thing like these: Maybe the Windows service pack installed on the system is not supported by the version of System Release drivers which are installed... Are you using NT or 2000? Which service pack is installed? Which version of Dialogic's System Release drivers are you using? Do that System Release's "Release Notes" list that Windows Service pack as one of the supported service packs? What else is installed on the system? The service packs etc actually play quite an important role and call transfers in particular have been known to be affected by changing service packs in the past... (and keep in mind that when running on XP the Dialogic driver will not issue hookflashes at all... - although this is not the problem now...) For your information: our test system is running Win2000 Server with SP4 - and hookflashes work perfectly... (Win2000 Pro should work just the same with SP4) We're going to look if there are any alternative ways of controlling hookflashes on Dialogic cards - but first I'd start double checking the service packs etc on your system and making sure that they match what is supported by the Dialogic drivers... If you're willing to spend more time to give us a clearer picture of what is happening (although this will probably not fix anything...) : How long does the LINEGENERATETERM_DONE event take to return when the hookflash value is set in the Dialogic TSP config screens to a low value (say "5").? (Please ensure that you restart the computer after changing the value in the Dialogic TSP configuration.) Share this post Link to post
HenryMc Report post Posted 08/14/2003 09:44 AM I appreciate all assistance provided... The system it is running on is: Dell PowerEdge 2500 Server Windows SBS 4.5 (Effectively NT 4.0 Server SP6, Exchange 5.5 , SQL Server 7, NT 4.0 Option Pack & Proxy Server) The Dialogic software as reported in DCM is: SR5.1.1 Version DNA5, Build30, SP1 "We're going to look if there are any alternative ways of controlling hookflashes on Dialogic cards - but first I'd start double checking the service packs etc on your system and making sure that they match what is supported by the Dialogic drivers..." I'd prefer to find the core problem as opposed to an alternative as something is not working as it should be and will most likely reappear later at another time. I'm willing to give you all the time required as... I have no option large investment in the D4PCI and the VG software... now I have to get it working.... With regards to "LINEGENERATETERM_DONE" I'm not quite sure what ytou want me to do here but I'll set the Hookflash to 5 then run a trace on the script again and post it here. Thank Henry 192939.75 4 linedevstate 2048 0 0 192939.75 4 callstate OFFERING 62155992 0 4 192939.78 4 callinfo CALLEDID 192939.78 4 callinfo ORIGIN 192939.78 4 ring 0 192945.77 4 ring 2 192945.77 4 Answer the call at 14/08/03 19:29:45 192945.77 4 lineAnswer(62155992) => 1 192946.30 4 callstate CONNECTED 62155992,1,0 192946.30 4 WorkingModeTAPI= 192946.30 4 WorkingModeScript= 192946.34 4 Inband detection not enabled 192946.36 4 StartLoadedVgs at 14/08/03 19:29:46 192946.36 4 tapi Reply 1 0 192946.80 4 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER 192946.80 4 [Transfer Call 2] Announced Transfer to 20 (Generate) 192946.81 4 tapic lineGenerateDigits(62155992,!,0) => 0 192947.48 4 generate LINEGENERATETERM_DONE 192948.56 4 LsXferStart EV_TAPI_GENERATE 192949.66 4 LsXferPlayVts EV_HOOKFLASHFINISHED 192949.66 4 tapic lineGenerateDigits(62155992,20,0) => 0 192949.95 4 generate LINEGENERATETERM_DONE 192950.98 4 LsXferPlayVts EV_TAPI_GENERATE 192951.02 4 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, , Digits 192951.05 4 twcal PlaySayNumber C:\Program Files\VoiceGuide\system\voicedlgc\TsfrCallFrom.wav, C:\Program Files\VoiceGuide\system\voicedlgc\TsfrAskAccept.wav, , , 1 192951.08 4 PlaySoundStartNumbers ok 192958.11 4 wb(21304601) 192959.13 4 Play End line[4] (id=213046) 192959.13 4 LsXferPlayAnn EV_PLAY_FINISHED 192959.13 4 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG 192959.13 4 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, , Digits 192959.14 4 twcal PlaySayNumber C:\Program Files\VoiceGuide\system\voicedlgc\TsfrCallFrom.wav, C:\Program Files\VoiceGuide\system\voicedlgc\TsfrAskAccept.wav, , , 1 192959.16 4 PlaySoundStartNumbers ok 193006.16 4 dtmf 1 (49,2) 193006.16 4 LsXferPlayAnn 1 193007.17 4 PlaySoundStop ok 193008.17 4 LsXferPlayAnn EV_PLAY_FINISHED 193008.17 4 LsXferPlayAnn EV_TAPI_GENERATE 193008.17 4 PlayFinishCause=CallAccepted 193008.17 4 Success path not defined - hanging up (iXferType=1) 193009.27 4 LsXferPlayAnn EV_TIMEOUT_HANGUP 193009.27 4 Hanging up call... 193009.27 4 RecSoundStop ok 193009.27 4 PlaySoundStop ok 193009.28 4 fnHangupCall end 193009.31 4 linedevstate 2048 0 0 193009.31 4 callstate IDLE 62155992 0 0 193009.31 4 WorkingMode@Idle= 193009.36 4 tapi Reply 2 0 193010.38 4 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 193010.38 4 ReinitTelephony due to IDLE start 193010.39 4 tapic lineDeallocateCall(MainCall:62155992) 0 193010.53 4 lineOpen(4) => 0 193010.53 4 Waiting for a call... 193010.55 4 lineOpen(4)LineHandle=62156288 Regardless of the setting the time between the hookflash & LINEGENERATETERM_DONE is 670/690... Share this post Link to post
SupportTeam Report post Posted 08/14/2003 10:24 AM I assume that "SP6" means "SP6a" ? Things appear to be badly stuck on this system and the only avenue of action that I can see (and what I would be doing next myself) is pretty drastic. 1. Reformat. 2. Install Just WinNT 3. Install SP6a 4. Install SR 5.1.1 5. Install VoiceGuide 6. Config Dialogic TAPI/Wave, set hookflash to a low value (lets stick to 5). 7. Test hookflash 8. If does not work install SR5.1.1 SP1 9. Test hookflash The below will take a few days on our side: "We're going to look if there are any alternative ways of controlling hookflashes on Dialogic cards " Share this post Link to post
HenryMc Report post Posted 08/14/2003 11:35 PM Noooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo Ok... shit! Share this post Link to post
HenryMc Report post Posted 08/26/2003 06:25 AM Ok, done and tested as requested. Under a bare installation of Win2000 Professional it works correctly. Under a Windows2000 Server installation it doesn't work. Is there any way of testing the hookflash with Dialogic directly bypassing VoiceGuide such as the Talker32 application ? Thanks Henry Share this post Link to post
SupportTeam Report post Posted 08/26/2003 06:34 AM We found that cards work on both Win200 Pro and Server setups... Indeed one of our test machines is running Win2000 Server SP2 (did you install SP2?) In Talker32 after answering a call make sure the correct line is selected in the dropdown box below the dial keypad, and then have it dial a "!" - this will do a hookflash... Share this post Link to post
HenryMc Report post Posted 08/26/2003 07:02 AM Installed SP3, is this a problem ? Thanks Henry Share this post Link to post
SupportTeam Report post Posted 08/26/2003 07:58 AM SP3 is not supported by SR5.1.1 Please see: C:\Program Files\Dialogic\doc\release_guide.chm In System Requirements -> Software Requirements -> Operating System Support : Operating System Support The operating system requirements are: Windows NT Version 4.0 (Workstation or Server) with Service Pack 6a Windows 2000 (Professional, Server, and Advanced Server) with SP1 and SP2 Share this post Link to post
