Line Selection Problem
I'm using an external MSSQL 2k Database where I add my outgoing calls.
I need to make sure that I dial out on the right line but VG will only dial out when the db field "LineSelection" = "NULL".
When I try to specify the line id (dxxxB1C2 or 2) the call just sits in the que and nothing happens (as soon as I update the field to "NULL" the call starts.
Pointers?
I have a 4 line version 6.0.3243 Enterprise with dialer for Dialogic.
Here is my MSSQL 2k db schema:
CREATE TABLE [dbo].[CallQue] (
[iD] [int] IDENTITY (1, 1) NOT NULL ,
[PhoneNumber] [nvarchar] (50) COLLATE SQL_Latin1_General_CP1_CI_AS NULL ,
[ActivateTime] [int] NULL ,
[DayTimeStart] [int] NULL ,
[DayTimeStop] [int] NULL ,
[DaysCallAllowed] [nvarchar] (50) COLLATE SQL_Latin1_General_CP1_CI_AS NULL ,
[LineSelection] [nvarchar] (1000) COLLATE SQL_Latin1_General_CP1_CI_AS NULL ,
[Priority] [int] NULL ,
[AnnounceMessage] [nvarchar] (500) COLLATE SQL_Latin1_General_CP1_CI_AS NULL ,
[script] [nvarchar] (500) COLLATE SQL_Latin1_General_CP1_CI_AS NULL ,
[OnAnswerMachine] [nvarchar] (500) COLLATE SQL_Latin1_General_CP1_CI_AS NULL ,
[RV] [nvarchar] (1000) COLLATE SQL_Latin1_General_CP1_CI_AS NULL ,
[AnswerTimeout] [int] NULL ,
[CallRetriesLeft] [int] NULL ,
[DelayBetweenRetries] [int] NULL ,
[OnNotConnected] [nvarchar] (1000) COLLATE SQL_Latin1_General_CP1_CI_AS NULL ,
[Options] [nvarchar] (1000) COLLATE SQL_Latin1_General_CP1_CI_AS NULL ,
[EscalationCalls] [nvarchar] (4000) COLLATE SQL_Latin1_General_CP1_CI_AS NULL
) ON [PRIMARY]
GO
Try:
,dxxxB1C2,
or
,2,
(Have a look at how the Telephone Number Loader saves similar information in the defalt MSAccess database.)
