Guest pascalganesh Report post Posted 03/25/2007 06:47 AM Hi, I am connected to the sound card through EPBAX. From an extenstion number I am dialing into the card and keying in 3 digits. The digits I key in are 135 whereas the script records the digits as 113. Should I change any setting on my card? I have attached the VG log and the configuration file for my sound card is as follows. -------------------------------------------------------------------------------------------------------------------- @tonetable,V200@ *DIALTONE #pstndialtone$F:375$F:400$F:425# #pabxdialtone$F:400# * *BUSYTONE #pstnbusytone$F:400$C1:750$C2:750# #pabxbusytone$F:415$C1:350$C2:350$C3:350$C4:350# #connectionrestrictiontone$F:400$C1:200$C2:200$C3:200$C4:400# #CongestionTone$F:400$C1:250$C2:250# * *RINGBACKTONE #PSTNRingBackTone$F:375$F:400$F:425$C1:400$C2:200$C3:400$C4:2000# #PABXringbacktone$F:375$F:400$F:425$C1:1000$C2:2000# * -------------------------------------------------------------------------------------------------------------------- Thanks Ganesh call_log.txt Share this post Link to post
SupportTeam Report post Posted 03/25/2007 12:00 PM Looks like the device you are using is very poor at correctly detecting a DTMF tone. You should look at using a Dialoigc card on your system. Share this post Link to post
