Dialer Lines Hanging
We dialed out over 1300 calls starting at 4:00pm today. We had allocated 12 lines to do this <LineSelection>35,36,37,38,39,40,41,42,43,44,45,46</LineSelection>. As I watched the script running, some of the lines I specified were in the "waiting for a call.." status even though the queue was not empty. The lines would hang for over 10 minutes until I manually hung up on the lines on the VG application with the Hang Up button. After I "Hung Up" the line it began to dial again as it did before. Do you know why these lines would not dial out immediately after the previous disconnect?
Could you please post a copy of VoiceGuide's 'vgm' Trace Logs which capture the problem, this will allow us to see what happened.
I ran about 700 calls today and experienced the same line freeze problem. As you can see from the logs, before I restarted the VoiceGuide application at 2:30, it was at its worst. The dialer was only dialing using lines 40 and 43. Even though I specified in the OutDial_New.xml to use lines 35-46. After the restart, all of the lines were dialing correctly.
They all start the way that they should. After 5 - 10 min some of the lines start to freeze (staying in the "Waiting for a call.." state).
I clipped the log file at 3:05. As you can see towards the end of the log, lines 37, 38, 40, 41, 42, 43, 45,and 46 not being released to dial a new call.
logs.zip
Thank you for providing the traces.
Please update your system with attached files. Place the vgMulti file in VG's main directory, and place the ktTel file in Windows' System32 directory - overwriting existing files.
Then start VG again and see if the problem still exists.
Please post traces as before if problem still exists.
VgMulti_3312.zip
ktTel_070322.zip
Good to hear.
Please let us know if there is anything else we can assist in in the future.
