Dialogic Presents Busy Tone
This system was working well until I unplugged the On Ramp and then went to plug it back in again. Seems to be that either Dialogic Card or the On-Ramp aren't all that stable if disconnected from one another.
VoiceGuide Status Monitor also informs me that Device 1 is "Blocked" but the remaining lines are Waiting for a Call. Any ideas?
I made a call from the system using ISDIAG and then tried to call the system using ISDIAG. When I call into the system it gives me a busy tone.
Log from ISDIAG.
PROTOCOL TYPE : PRI NET5
TRACE START TIME (MM/DD/YYYY) : 3/29/2007, 15:57:50.656
Time Stamp : 3/29/2007, 15:58:18.696
TRANSMIT
Command=0 SAPI=0x00
TEI=0x00
0x7f Set Asynchronous Balanced Mode
Time Stamp : 3/29/2007, 15:58:19.696
TRANSMIT
Command=0 SAPI=0x00
TEI=0x00
Time Stamp : 3/29/2007, 15:58:20.696
TRANSMIT
Command=0 SAPI=0x00
TEI=0x00
Time Stamp : 3/29/2007, 15:58:21.696
TRANSMIT
Command=0 SAPI=0x00
TEI=0x00
Most likely the communications D channel has not been established.
When you open ISDIAG do you see the D channel indicator as showing that the D channel is present? (it's one of the status indicators in top right corner)
All status indicators should be 0.
Consult the ISDIAG documentation on these report flags.
If D channel is not present then you should contact the E1 line supplier and ask them why is the E1 disabled...
