Dialogic Dm/f240-t1-pci
I have a Dialogic DM/F240-T1-PCI card. It's listed as a fax card. The software is presenting the 24 lines but the card is not answering calls.
Should this card work with the VoiceGuide system?
That card is a fax only card. It cannot play/record sound files and listen out for DTMF tones. It's unsuitable for use with IVR systems.
You need to use a D/240JCT card.
