jbanciu Report post Posted 03/29/2007 05:39 PM I have a Dialogic DM/F240-T1-PCI card. It's listed as a fax card. The software is presenting the 24 lines but the card is not answering calls. Should this card work with the VoiceGuide system? Share this post Link to post
SupportTeam Report post Posted 03/29/2007 10:02 PM That card is a fax only card. It cannot play/record sound files and listen out for DTMF tones. It's unsuitable for use with IVR systems. You need to use a D/240JCT card. Share this post Link to post
