Dialer Not Working And Missing Logs
Hello guys, suddenly the dialer stopped to work and the logs are not being generated in the log folder (still can't find if they are in other folder)
It's the same at the production system and in the development one :ph34r:
I reinstalled the App with same results.
Any idea?
Thanks in advance.
Fidencio Monroy.
P.S. nice new forum look
Could you please post a copy of VoiceGuide's Trace Logs which captures the startup of VG and the laodingof new calls, this will allow us to see what happened.
[Log]
VoiceGuide=10
Then restart VG.
Please post the traces.
Are you using your own database to hold the outgoing calls? Or are you letting VoiceGuide store the outgoing calls which it's to make in it's own database?
After setting the log value at VG.INI I got this error:
201808.41 6 ERROR 5.2.5049 DialogicScUnroute => Non-Dialogic version of TapiWrap.ocx
201808.41 6 cti tapi cti link device not specified
Reinstalling the TAPI and WAVE drivers solved the problem.
Thank you very much.
