Problem To Play Sound File
I have recorded voice in English & Bangla (my native language) language under Windows XP SP2 OS platform for test purpose. Under Windows XP I don't find any problem, but when I run same *.vgs file under Windows 2003 Server I found a problem that is
at the same time "wav" (our pre-recorded file) & "text to speech" type metalic sounds whose are not recorded by us and also in bangla & english language.
Arif
[Log]
VoiceGuide=10
[Log]
VoiceGuide=10
log.zip
Trace shows that when the attempt is made to play a sound file the following error occurs:
103412.58 0 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>4,play pss EnsureWaveOutIsOpenAndReady=>tr 5 waveOutOpen(id=0) MMSYSERR_ALLOCATED but hWaveOut = NULL] [G:\TeleBanking System\Bangla Voice\Welcome.wav]
Are you sure the modem which you are using (SmartUSB56 Modem) is a Voice modem?
If it is a Voice modem then are it's Wave drivers properly installed?
Its a voice guide Modem. I install "Aztech UM 9100 Winxp" in Windows 2003 server. Is it ok ? If not then reply how solve this.
Where I get "Aztech UM 9100 Win 2003" driver ?
If you want to put together a professional quality IVR/Voicemail/etc system then you should get a Dialogic card. As per our Recommended Hardware information page: http://www.voiceguide.com/suppRecomHardware.htm
My main question is -----------
Voice Guide run properly in Windows XP operating system with this modem, but its not properly run in Windows 2003 Server with the same modem. Main difference is sound that also say about this.
Windows XP recorded sound run properly but Windows 2003 server sound mixed up, one is recorded and other is know sound.
Please reply. I also bought voice guide software but can't use properly.
Looks like that modem's Wave drivers do not work on Win2003. You should contact the modem manufacturer and ask them why their modem's Wave drivers do not work on Win2003.
[deleted]
Today I uninstall "Aztech Modem Driver (Windows XP)" version and install "Aztech Modem Driver (Windows 2000)".
My system Unique Id has been change to MB4EF. Plz send my new number for active this.
Plz reply
Edited by titu
Deleted registration information
Please send all license related correspondence direct to sales@voiceguide.com
Do not post any license related information in the Support Forum.
Thank for last reply. Actually, your support service is so fast. That's impress me.
I have another requirement. Now I face a problem on numeric data.
My language is Bangla. I also convert my numeric
sound in my language. But my problem is ---------
1000000 = 1 Million in English language but my language is not like this.
I want to
1000000 = 10 Lak. I want make a sound file 10 Lak.
Now how can I solve this on Bangla language ? Please reply.
From
Titu
Have you had a look at modifying the lib_num2wav.vbs file ?
As per Help file entry on Say Numbers module: http://www.voiceguide.com/vghelp/html/modSayNumber.htm
Need to change the way Say Number module speaks Amounts ?
Users can edit the way in which the numbers are spoken, or even add their own Say Number functions by editing the file: lib_num2wav.vbs located in VoiceGuide's \system\vbs\ subdirectory. This is useful if it is required to say numbers/amounts in a language other then English.
Please read the lib_num2wav.vbs file for more information.
Last time I said about sound files problem. I solve this by "Voice Guide 4.8 Demo". Its also have a problem "Say Numeric field properly but not proper in Date/DateTime field". I also bought "Voice Guide 5.2.5045". I can't solve Numeric or Date/dateTime field. Both version use same modem.
Plz reply.
Please describe in full detail exactly what it is that you need to have changed in the way that the dates are spoken.
We can then help in advising out how the lib_num2wav.vbs file can be changed to allow you to have the time/date/etc spoken in the way in which you desire.
language under Windows 2003 Server OS platform for test purpose.
Now I face two problem:
1.
When I use "Voice Guide 4.8 Demo Version" on Windows 2003 Server, I can run all numeric field. For example:
2007. It gives me recorded sound but when I use Date format field, example : 17/04/2007.
It doesn't give me full recorded sound for Date format.
When I use "Voice Guide 5.2 Full Version" on Windows 2003 Server, I can't run all numeric field. For example:
2007. It doesn't give me recorded sound, give me metalic sounds.
This is the same metalic sound file in date format.
2.
Bangla is my native language. Now I face a problem on numeric field.
I want to
1000000 = 10 Lak in Bangla language . I want make a sound file for 10 Lak.
I also change "lib_num2wav.vbs" file for my language.
I send this. Plz download this and give me proper correction.
My lib_num2wav file -
' WARNING
' You may add new and modify existing functions in
' this file, but you may not change 'name :' comments.
' VoiceGuide uses the 'name :' comments to determine
' which function to call. It's the 'name :' comments
' that appear in the dropdown box in the script designer
' which describe how the number should be spoken.
' If you need to change the 'name:' comment please just
' create a new function.
'Dec 29, 2005
' - Added functions:
' Date - MMDD - DM
' Date - DDMM - MD
' Date - MMDDYYYY - DMY
' Date - DDMMYYYY - MDY
'Jan 14, 2006
' - Fixed 12AM bug in function TimeHHNN
' - Added function DateTimeSQLLongDateTime
'name : Digits
'info : Say the digits in the number
'arg1 : Digits to be spoken :
Function Digits(byval arg1)
'returns a list of comma delimited wav files,
'with each wav file corresponding to a character
'in the supplied input string.
sDigits=Trim(arg1)
For i=1 To Len(sDigits)
sDigit = Mid(sDigits, i, 1)
If sDigit = "-" Then
sWav = "minus.wav"
Else
sWav = sDigit & ".wav"
end If
If sOut = "" Then
sOut = sWav
else
sOut = sOut & "," & sWav
End if
Next
Digits = sOut
End Function
'name : Number
'info : Say the number
'arg1 : Number to be spoken :
Function Number(byval arg1)
'any commas in the number are ignored - they are deleted before the number is spoken.
sNumberTrimmed = Trim(arg1)
sNumber = replace(sNumberTrimmed, ",", "")
Dim Place(9)
Place(2) = "thousand.wav"
Place(3) = "million.wav"
Place(4) = "billion.wav"
Place(5) = "trillion.wav"
'Position of decimal place 0 if none
iDecimalPlacePos = InStr(sNumber, ".")
If iDecimalPlacePos > 0 Then
sAfterDecimalPoint_WavList = Digits(Mid(sNumber, iDecimalPlacePos + 1, 100))
sNumber = Left(sNumber, iDecimalPlacePos - 1)
End If
If Left(sNumber, 1) = "-" Then
iNumberIsNegative = 1
sNumber = Mid(sNumber, 2, Len(sNumber-1))
else
iNumberIsNegative = 0
End If
iCount = 1
'we will create the WAV list of sound files starting from
'the back of the number.
Do While sNumber <> ""
s3_WavList = hundreds2wav(Right(sNumber, 3))
If s3_WavList <> "" Then
If iCount > 1 Then
s3_WavList = s3_WavList & "," & Place(iCount)
End If
If sNumber_WavList = "" Then
sNumber_WavList = s3_WavList
Else
sNumber_WavList = s3_WavList & "," & sNumber_WavList
End If
End If
If Len(sNumber) > 3 Then
sNumber = Left(sNumber, Len(sNumber) - 3)
Else
sNumber = ""
End If
iCount = iCount + 1
Loop
If sAfterDecimalPoint_WavList = "" Then
if sNumber_WavList = "" then
Number = "0.wav"
else
Number = sNumber_WavList
end if
Else
Number = sNumber_WavList & ",point.wav," & sAfterDecimalPoint_WavList
end if
if iNumberIsNegative = 1 then
Number = "minus.wav," & Number
end if
End Function
'name : Number - comma as decimal
Function Number_CommaAsDecimal(byval arg1)
'If there is a decimal point in the supplied number
'then the digits after the decimal point will be spelled out.
'any 'full stops' in the number are ignored - they are deleted before the number is spoken.
sNumber = replace(sNumberTrimmed, ".", "")
Dim Place(9)
' Position of decimal place 0 if none
iDecimalPlacePos = InStr(sNumber, ",")
End If
else
End If
iCount = 1
If iCount > 1 Then
End If
Else
End If
End If
Else
sNumber = ""
End If
iCount = iCount + 1
Loop
Number = "0.wav"
else
end if
Else
end if
end if
End Function
'name : Amount - Dollars
'info : Say the amount in dollars only
'arg1 : Amount :
Function AmountDollars(ByVal arg1)
'ignore everything after any decimal points
'if someone wants to hear cents they should use "Dollars and Cents"
AmountToSay = Trim(arg1)
iDecimalPlacePos = InStr(AmountToSay, ".")
if iDecimalPlacePos = 0 then
'see if maybe a comma is used for the decimal place instead.
iDecimalPlacePos = InStr(AmountToSay, ",")
end if
AmountToSay = Left(AmountToSay, iDecimalPlacePos - 1)
End If
sDollars_WavList = Number(AmountToSay)
Select Case sDollars_WavList
Case ""
sDollars_WavList = "0.wav,dollars.wav"
Case Else
sDollars_WavList = sDollars_WavList & ",dollars.wav"
End Select
AmountDollars = sDollars_WavList
End Function
'name : Amount - Dollars And Cents
'info : Say the amount in dollars and cents
'arg1 : Amount :
Function AmountDollarsAndCents(ByVal arg1)
end if
'Convert sCents_WavList and set AmountToSay to dollar amount
sCents_WavList = tens2wav(Left(Mid(AmountToSay, iDecimalPlacePos + 1) & "00", 2))
AmountToSay = Trim(Left(AmountToSay, iDecimalPlacePos - 1))
End If
sDollars_WavList = AmountDollars(AmountToSay)
Select Case sCents_WavList
Case ""
sCents_WavList = "0.wav,cents.wav"
Case Else
sCents_WavList = sCents_WavList & ",cents.wav"
End Select
AmountDollarsAndCents = sDollars_WavList & ",and.wav," & sCents_WavList
End Function
'name : Amount - Cents
'info : Amount to say is given in cents.
'arg1 : Amount in cents :
Function AmountCents(ByVal arg1)
'just insert the decimal point in the right place,
'and pass to AmountDollarsAndCents function
'if there is a decimal point in there already then just use that decimal point..
iDecimalPlacePos = InStr(arg1, ".")
iDecimalPlacePos = InStr(arg1, ",")
end if
AmountCents = AmountDollarsAndCents(arg1)
End If
Select case Len(arg1)
Case 0
AmountCents = AmountDollarsAndCents("0.00")
Case 1
AmountCents = AmountDollarsAndCents("0.0" & arg1)
Case 2
AmountCents = AmountDollarsAndCents("0." & arg1)
Case Else
AmountCents = AmountDollarsAndCents(Left(arg1, len(arg1)-2) & "." & Right(arg1, 2))
End Select
End Function
'name : Date - MMDD
'info : Say month and day of month
'arg1 : MMDD or MM/DD:
Function DateMMDD(ByVal arg1)
arg1 = replace(arg1, "/", "")
If Len(arg1) < 4 Then
Exit Function
End If
DateMMDD = "month" & Left(arg1,2) & ".wav,place" & Right(arg1,2) & ".wav"
End Function
'name : Date - MMDD - DM
'info : Say day of month and month
Function DateMMDD_DM(ByVal arg1)
Exit Function
End If
DateMMDD_DM = "place" & Right(arg1,2) & ".wav,month" & Left(arg1,2) & ".wav"
End Function
'name : Date - DDMM
'arg1 : DDMM or DD/MM:
Function DateDDMM(ByVal arg1)
Exit Function
End If
DateDDMM = "place" & Left(arg1,2) & ".wav,month" & Right(arg1,2) & ".wav"
End Function
'name : Date - DDMM - MD
Function DateDDMM_MD(ByVal arg1)
Exit Function
End If
DateDDMM_MD = "month" & Right(arg1,2) & ".wav,place" & Left(arg1,2) & ".wav"
End Function
'name : Date - MMDDYYYY
'info : Say month, day, year
'arg1 : MMDDYYYY or MM/DD/YYYY:
Function DateMMDDYYYY(ByVal arg1)
If Len(arg1) < 8 Then
Exit Function
End If
DateMMDDYYYY = "month" & Left(arg1,2) & ".wav,place" & mid(arg1,3,2) & ".wav," & Number(right(arg1,4))
End Function
'name : Date - MMDDYYYY - DMY
'info : Say day, month, year
Function DateMMDDYYYY_DMY(ByVal arg1)
Exit Function
End If
DateMMDDYYYY_DMY = "place" & mid(arg1,3,2) & ".wav,month" & Left(arg1,2) & ".wav," & Number(right(arg1,4))
End Function
'name : Date - DDMMYYYY
'arg1 : DDMMYYYY or DD/MM/YYYY:
Function DateDDMMYYYY(ByVal arg1)
Exit Function
End If
DateDDMMYYYY = "place" & Left(arg1,2) & ".wav,month" & mid(arg1,3,2) & ".wav," & Number(right(arg1,4))
End Function
'name : Date - DDMMYYYY - MDY
Function DateDDMMYYYY_MDY(ByVal arg1)
Exit Function
End If
DateDDMMYYYY_MDY = "month" & mid(arg1,3,2) & ".wav,place" & Left(arg1,2) & ".wav," & Number(right(arg1,4))
End Function
'name : Time am/pm - HHNN
'info : Say the hour and minute in am/pm format
'arg1 : Time in format HHNN or HH:NN
Function TimeHHNN(ByVal arg1)
arg1 = replace(arg1, ":", "")
Exit Function
End If
sHH = Left(arg1,2)
sNN = Right(arg1,2)
'MsgBox(sHH & sNN)
sHH = sHH Mod 24
If sHH >= 12 Then
sHH = sHH - 12
if sHH = 0 then
sHH = "12"
end if
if sHH < 10 then
sHH = "0" & sHH
end if
sAMPM = "pm.wav"
Else
if sHH = 0 then
sHH = 12
end if
sAMPM = "am.wav"
end if
if left(sHH, 1) = "0" or sHH < 10 Then
sHH_WavList = Right(sHH, 1) & ".wav"
'MsgBox("zero:" & sHH_WavList)
Else
sHH_WavList = tens2wav(sHH)
'MsgBox("tens:" & sHH_WavList)
end if
if left(sNN, 1) = "0" or sNN < 10 Then
if Right(sNN, 1) = "0" then
'do not play anything for minutes,
sNN_WavList = ""
else
sNN_WavList = "0.wav," & Right(sNN, 1) & ".wav"
end if
Else
sNN_WavList = tens2wav(sNN)
end if
if sNN_WavList <> "" then
TimeHHNN = sHH_WavList & "," & sNN_WavList & "," & sAMPM
else
'could add an "o'clock' sound file here...
TimeHHNN = sHH_WavList & "," & sAMPM
end if
End Function
'name : Time 24 hour - HHNN
'info : Say the hour and minute in 24 hour format
'arg1 : HHNN or HH:NN
Function TimeHHNN24(ByVal arg1)
Exit Function
End If
'no AM/PM - just say the hour in 24-hour format.
sHH = Left(arg1,2)
sNN = Right(arg1,2)
if left(sHH, 1) = "0" Then
Else
end if
if left(sNN, 1) = "0" Then
Else
end if
TimeHHNN24 = sHH_WavList & "," & sNN_WavList
End Function
'name : Date & Time - MMDDHHNN
'info : Say the Month, day then hour and minute AM/PM
'arg1 : MMDDHHNN or MM/DD, HH:NN:
Function DateTimeMMDDHHNN(ByVal arg1)
arg1 = replace(arg1, ",", "")
arg1 = replace(arg1, " ", "")
Exit Function
End If
sMMDD = Left(arg1,4)
sHHNN = Right(arg1,4)
DateTimeMMDDHHNN = DateMMDD(sMMDD) & "," & TimeHHNN(sHHNN)
End Function
'name : Date & Time - DDMMHHNN
'arg1 : DDMMHHNN or DD/MM, HH:NN:
Function DateTimeDDMMHHNN(ByVal arg1)
Exit Function
End If
sDDMM = Left(arg1,4)
DateTimeDDMMHHNN = DateDDMM(sDDMM) & "," & TimeHHNN(sHHNN)
End Function
'name : Date & Time - MSSQL format
'arg1 : YYYY-M-D HH:NN:SS
Function DateTimeMSSQL(ByVal arg1)
If Len(arg1) < 15 Then
Exit Function
End If
'2004-7-14 18:32:18
Dim sArray
sArray = Split(arg1, "-")
sM = sArray(1)
if len(sM) = 1 then
sM = "0" & sM
end if
sD = left(sArray(2),2)
sArray = Split(arg1, ":")
sHH = right(sArray(0), 2)
if len(sHH) = 1 then
sHH = "0" & sHH
end if
sNN = sArray(1)
if len(sNN) = 1 then
sNN = "0" & sNN
end if
sMMDD = sM & sD
sHHNN = sHH & sNN
DateTimeMSSQL = DateMMDD(sMMDD) & "," & TimeHHNN(sHHNN)
End Function
'name : Date & Time - SQL Long Date & Time
'arg1 : M/D/YYYY H:NN:SS AM/PM
Function DateTimeSQLLongDateTime(ByVal arg1)
Exit Function
End If
'3/25/2005 7:30:00 AM
'3/5/2005 10:30:00 PM
Dim sArray
sArray = Split(arg1, "/")
if len(sArray(1)) = 1 then
sD = "0" & sArray(1)
else
sD = sArray(1)
end if
if len(sArray(0)) = 1 then
sM = "0" & sArray(0)
else
sM = sArray(0)
end if
sH = right(sArray(0),2)
if len(sH) = 1 then
sH = "0" & sH
end if
sNN = sArray(1)
if strcomp(right(arg1,2), "PM", 1) = 0 then
sH = sH + 12
end if
sH = Trim(sH)
sMMDD = sM & sD
sHHNN = sH & sNN
'TimeHHNN will say AM/PM as well.
DateTimeSQLLongDateTime = DateMMDD(sMMDD) & "," & TimeHHNN(sHHNN)
End Function
'name : Date & Time - Mid Date, Long Time
'arg1 : D-MMM-YY HH:NN:SS AM/PM
Function DateTimeMidDateLongTime(ByVal arg1)
Exit Function
End If
'14-Jul-04 3:07:00 PM
'14-07-04 3:07:00 PM
Dim sArray
if len(sArray(1)) >= 3 then
'looks like date is "D-MMM-etc" format
sD = sArray(0)
sM = sArray(1)
else
'assume date is "MMM-D-etc" format
sM = sArray(0)
sD = sArray(1)
end if
if len(sD) = 1 then
sD = "0" & sD
end if
if len(sM) = 1 then
sM = "0" & sM
end if
if len(sM) >= 3 then
'we need to convert for a 3 letter month to a 2 digit month.
if strcomp(left(sM,3), "Jan", 1) = 0 then
sM = "01"
end if
if strcomp(left(sM,3), "Feb", 1) = 0 then
sM = "02"
end if
if strcomp(left(sM,3), "Mar", 1) = 0 then
sM = "03"
end if
if strcomp(left(sM,3), "Apr", 1) = 0 then
sM = "04"
end if
if strcomp(left(sM,3), "May", 1) = 0 then
sM = "05"
end if
if strcomp(left(sM,3), "Jun", 1) = 0 then
sM = "06"
end if
if strcomp(left(sM,3), "Jul", 1) = 0 then
sM = "07"
end if
if strcomp(left(sM,3), "Aug", 1) = 0 then
sM = "08"
end if
if strcomp(left(sM,3), "Sep", 1) = 0 then
sM = "09"
end if
if strcomp(left(sM,3), "oct", 1) = 0 then
sM = "10"
end if
if strcomp(left(sM,3), "Nov", 1) = 0 then
sM = "11"
end if
if strcomp(left(sM,3), "Dec", 1) = 0 then
sM = "12"
end if
end if
sNN = sArray(1)
sHH = sHH + 12
end if
sHH = Trim(sHH)
sHH = "0" & sHH
end if
sMMDD = sM & sD
sHHNN = sHH & sNN
DateTimeMidDateLongTime = DateMMDD(sMMDD) & "," & TimeHHNN(sHHNN)
End Function
'name : Time - HH:NN:SS AM/PM
'info : Say hour and minute AM/PM
'arg1 : HH:NN:SS AM/PM
Function DateTimeLongTime(ByVal arg1)
Exit Function
End If
Dim sArray
sNN = sArray(1)
sHH = sHH + 12
end if
sHH = Trim(sHH)
sHH = "0" & sHH
end if
sMMDD = sM & sD
sHHNN = sHH & sNN
DateTimeLongTime = TimeHHNN(sHHNN)
End Function
' Converts a number from 100-999 into .Wavs *
Function hundreds2wav(ByVal AmountToSay)
on error resume next
If Cint(AmountToSay) = 0 Then
Exit Function
End If
AmountToSay = Right("000" & AmountToSay, 3)
'Convert the hundreds place
If Mid(AmountToSay, 1, 1) <> "0" Then
Result = digit2wav(Mid(AmountToSay, 1, 1)) & ",hundred.wav"
End If
'Convert the tens and ones place
If Mid(AmountToSay, 2, 1) <> "0" Then
s2_WavList = tens2wav(Mid(AmountToSay, 2))
Else
s2_WavList = digit2wav(Mid(AmountToSay, 3))
End If
If Result = "" Then
Result = s2_WavList
Else
Result = Result & "," & s2_WavList
End If
hundreds2wav = Result
End Function
' Converts a number from 10 to 99 into .Wavs *
Function tens2wav(TensText)
Result = "" 'null out the s3_WavListorary function value
If CInt(Left(TensText, 1)) = 1 Then
' If value between 10-19
Select Case CInt(TensText)
Case 10: Result = "10.wav"
Case 11: Result = "11.wav"
Case 12: Result = "12.wav"
Case 13: Result = "13.wav"
Case 14: Result = "14.wav"
Case 15: Result = "15.wav"
Case 16: Result = "16.wav"
Case 17: Result = "17.wav"
Case 18: Result = "18.wav"
Case 19: Result = "19.wav"
Case Else
End Select
Else
' If value between 20-99
Case 20: Result = "20.wav"
Case 21: Result = "21.wav"
Case 22: Result = "22.wav"
Case 23: Result = "23.wav"
Case 24: Result = "24.wav"
Case 25: Result = "25.wav"
Case 26: Result = "26.wav"
Case 27: Result = "27.wav"
Case 28: Result = "28.wav"
Case 29: Result = "29.wav"
Case 30: Result = "30.wav"
Case 31: Result = "31.wav"
Case 32: Result = "32.wav"
Case 33: Result = "33.wav"
Case 34: Result = "34.wav"
Case 35: Result = "35.wav"
Case 36: Result = "36.wav"
Case 37: Result = "37.wav"
Case 38: Result = "38.wav"
Case 39: Result = "39.wav"
Case 40: Result = "40.wav"
Case 41: Result = "41.wav"
Case 42: Result = "42.wav"
Case 43: Result = "43.wav"
Case 44: Result = "44.wav"
Case 45: Result = "45.wav"
Case 46: Result = "46.wav"
Case 47: Result = "47.wav"
Case 48: Result = "48.wav"
Case 49: Result = "49.wav"
Case 50: Result = "50.wav"
Case 51: Result = "51.wav"
Case 52: Result = "52.wav"
Case 53: Result = "53.wav"
Case 54: Result = "54.wav"
Case 55: Result = "55.wav"
Case 56: Result = "56.wav"
Case 57: Result = "57.wav"
Case 58: Result = "58.wav"
Case 59: Result = "59.wav"
Case 60: Result = "60.wav"
Case 61: Result = "61.wav"
Case 62: Result = "62.wav"
Case 63: Result = "63.wav"
Case 64: Result = "64.wav"
Case 65: Result = "65.wav"
Case 66: Result = "66.wav"
Case 67: Result = "67.wav"
Case 68: Result = "68.wav"
Case 69: Result = "69.wav"
Case 70: Result = "70.wav"
Case 71: Result = "71.wav"
Case 72: Result = "72.wav"
Case 73: Result = "73.wav"
Case 74: Result = "74.wav"
Case 75: Result = "75.wav"
Case 76: Result = "76.wav"
Case 77: Result = "77.wav"
Case 78: Result = "78.wav"
Case 79: Result = "79.wav"
Case 80: Result = "80.wav"
Case 81: Result = "81.wav"
Case 82: Result = "82.wav"
Case 83: Result = "83.wav"
Case 84: Result = "84.wav"
Case 85: Result = "85.wav"
Case 86: Result = "86.wav"
Case 87: Result = "87.wav"
Case 88: Result = "88.wav"
Case 89: Result = "89.wav"
Case 90: Result = "90.wav"
Case 91: Result = "91.wav"
Case 92: Result = "92.wav"
Case 93: Result = "93.wav"
Case 94: Result = "94.wav"
Case 95: Result = "95.wav"
Case 96: Result = "96.wav"
Case 97: Result = "97.wav"
Case 98: Result = "98.wav"
Case 99: Result = "99.wav"
Case Else
End Select
sDigitWav = digit2wav(Right(TensText, 1)) 'Retrieve ones place
If sDigitWav <> "" Then
If Result = "" Then
Result = sDigitWav
Else
Result = Result
'Result = Result & "," & sDigitWav
End If
End If
End If
tens2wav = Result
End Function
' Converts a number from 1 to 9 into .Wavs *
Function digit2wav(Digit)
Select Case CInt(Digit)
Case 1: digit2wav = "1.wav"
Case 2: digit2wav = "2.wav"
Case 3: digit2wav = "3.wav"
Case 4: digit2wav = "4.wav"
Case 5: digit2wav = "5.wav"
Case 6: digit2wav = "6.wav"
Case 7: digit2wav = "7.wav"
Case 8: digit2wav = "8.wav"
Case 9: digit2wav = "9.wav"
Case Else: digit2wav = ""
End Select
End Function
Are you specifying this "2007" in a Play module or in a Say Numbers module? In play module specifying just numbers will play DTMF sounds...
[Log]
VoiceGuide=10
I want to
I think best approach where would be to pre-process the number in some other module and split out the last 5 digits from it.
ie. split 100000 into a "10" and a "00000".
Then you can use two separate Say Number modules to play the first and second parts of the number respectively.
[Log]
VoiceGuide=10
I want to
[Log]
VoiceGuide=10
These system also done this but not solve.
2.
Last time I send log file.
You reply -
How can this error generated ? What's the problem ?
Now another time I send these.
Plz reply. After buying Voice Guide software I can't run this properly.
log.zip
[Log]
VoiceGuide=10
I want to
[Log]
VoiceGuide=10
2.
You reply -
Plz don't mind
I say other things.
My recorded sound file format - 8000Hz, 16bit Mono. I use Cool Edit 2000 software for record.
Is it correct ?
reply
It's because you are using a modem instead of a Dialogic card. Many modems have such problems with their Wave drivers.
You will need to fix the wave drivers so that they work (try re-installing, maybe that will be sufficient).
I say other things.
My recorded sound file format - 8000Hz, 16bit Mono. I use Cool Edit 2000 software for record. I user Aztech Voice Modem.
Is it correct ?
reply plz
