What Are The Other Software To Install Pls Someone
hello what other software do i need to install on my pc to start using this solution after i have install the VG software,voice card modern?
any other software like VB,.net composiry, i use an XP pc instal.
If you are using a voice modem then you would most likely be using v 5.x of VoiceGuide.
Nothing else needs to be installed if you install the v5.x of VoiceGuide.
v6.x of VoiceGuide needs .NET 2.0
davids: You might find a VBS editor (vbsedit - adersoft) useful or an audio/wav editor such as Cool-Edit-Pro or Adobe Audition.
