Guest Hugh Report post Posted 08/10/2003 11:02 PM In the UK it is possible to have two different numbers assigned to a single line. If a phone is connected to the line different ring tones identify which number the caller is calling. I am using a D/4PCI card, is it possible to detect the called number (ie not CLI) and run a script accordingly, ie if called number is x use script x or if called number is y, use script y Share this post Link to post
SupportTeam Report post Posted 08/11/2003 04:22 AM Not at this stage. The TAPI drivers which VoiceGuide uses do not pass this information. This may be possible when a special "VoiceGuide for Dialogic" version comes out - it will be written specifically for Dialogic API and should be able to react to different ringtones and run different scripts.. Share this post Link to post
hugh Report post Posted 08/12/2003 09:45 AM >> This may be possible when a special "VoiceGuide for Dialogic" version comes out That sounds like a product announcement, any idea on timescale (even a very rough one?) Share this post Link to post
SupportTeam Report post Posted 08/12/2003 10:04 AM no times are available at this stage, sorry. Share this post Link to post
