Guest pascalganesh Report post Posted 04/18/2007 01:51 PM Hi, Caller Id in dialogic D/4PCI is not detected. O/S : XP Pro Necessary drivers and Service pack (ver 5.1.1 ) has benn installed Caller ID on the line is available and verified using a caller ID telephone. Exeletel's Telescope also deos not detect caller Id on this dialogic card. Any other special setting that need to be done? Ganesh Share this post Link to post
SupportTeam Report post Posted 04/18/2007 09:06 PM Do you know in what format the telephone company is sending the CallerID? Are you using "VoiceGuide for Dialogic"? Share this post Link to post
Guest pascalganesh Report post Posted 04/19/2007 06:40 AM We are using Intel dialgic card We are *not* using VG for Dialogic but the the standard VG evaluation copy Here is the log.... 115223.22 8 devstate NUMCALLS 0 0 115223.22 8 tapi callstate OFFERING 66339 0 4 115223.23 8 ev Lev_CallerID [,,0000] 115223.23 8 callinfo CALLEDID 115223.23 8 callinfo ORIGIN 115223.23 8 ring 0 115224.14 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|8:hc>0| 115229.22 8 ring 2 115229.22 8 rv clear 115229.22 8 answer the call at 19/04/2007 11:52:29:AM 115229.23 8 lineAnswer(66339) => 66356 115229.78 8 tapi callstate CONNECTED 66339 1 0 115229.78 8 callstate CONNECTED 66339,1,0 115229.80 8 WorkingModeTAPI@Connected= 115229.80 8 WorkingModeScript@Connected= 115229.80 8 Inband detection not enabled 115229.80 8 startLoadedVgs at 19/04/2007 11:52:29:AM, script interpretor VgMulti v5.2.5049 0 115229.81 8 rv ns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\test\} 115229.81 8 rv ns add [scriptPath]{C:\Program Files\VoiceGuide\Scripts\test} 115229.81 8 rv lg add [$RV_STARTTIME]{19/04/2007 11:52:29:AM} 115229.83 8 rv lg add [$RV_DEVICEID]{8} 115229.83 8 rv lg add [$RV_CIDNAME]{} 115229.83 8 rv ns add [PathApp]{C:\Program Files\VoiceGuide\} 115229.84 8 rv lg add [$RV_CIDNUMBER]{} 115229.84 8 rv lg add [$RV_DNIS]{0000} 115229.84 8 rv lg add [DNIS]{0000} 115229.86 8 tapi Reply (LineEvReply) ok 66356 0 LineCallState=CONNECTED 115229.86 8 timer clear 115229.86 8 state [Database Query 1] DB Query 115229.88 8 callinfo MONITORMODES 115229.88 8 db ODBC mode used 115229.94 8 rv replace start: [insert into XYZ values ($RV_CIDNUMBER)] 115229.94 8 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\test\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\test}[$RV_STARTTIME]{19/04/2007 11:52:29:AM}[$RV_DEVICEID]{8}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[$RV_DNIS]{0000}[DNIS]{0000} 115229.94 8 rv replace end: [insert into XYZ values ()] 115229.95 8 db About to execute a Modify type operation [insert into XYZ values ()] 115229.97 8 ERROR 5.2.5049 DB Execute: 3146,ODBC--call failed. 115229.97 8 rv lg add [Database Query 1_RowCount]{0} 115229.97 8 db DBEngine.Error nbr:[170] desc:[37000: [Microsoft][ODBC SQL Server Driver] Line 1: Incorrect syntax near ')'.] src:[ODBC.Database] 115229.98 8 db DBEngine.Error nbr:[8180] desc:[37000: [Microsoft][ODBC SQL Server Driver][sql Server]Statement(s) could not be prepared.] src:[ODBC.Database] 115229.98 8 db DBEngine.Error nbr:[3146] desc:[ODBC--call failed.] src:[DAO.Database] 115230.00 8 path {0} not found 115230.00 8 path {} not found 115230.00 8 rv lg add [Hangup Time]{19/04/2007 11:52:30:AM} 115230.02 8 state Hanging up call... [GoNextVgm_Boolean fail] 115230.02 8 RecSoundStop ok 115230.03 8 PlaySoundStop err=0 115230.03 8 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 115230.05 8 fnHangupCall end 115231.81 8 devstate NUMCALLS 0 0 115231.83 8 tapi callstate IDLE 66339 0 0 115231.83 8 WorkingMode@Idle= 115231.84 8 timer clear 115231.84 8 WriteToLogFiles_CurrScriptOnly start 115231.84 WriteToLogFiles_DoWrite start (C:\Program Files\VoiceGuide\Scripts\test\cID) 115231.86 8 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 115231.86 8 tapi Reply (LineEvReply) ok 66305 0 LineCallState=IDLE 115232.89 8 timer fired EV_TIMEOUT_TIMETOREINITLINE 115232.89 8 ScriptEventCode 9008 iLineState=900 115232.89 8 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 115232.91 8 ReinitTelephony due to IDLE 115232.91 8 tapic lineDeallocateCall(MainCall:66339) 0 115233.00 8 lineOpen(8)=> 115233.00 8 state Waiting for a call... 115233.00 8 LineHandle=66322 115233.02 8 ClearCallHandle called from ReinitAtIdle 115233.02 8 amchk set AMdet=False in Reinit@idle 115233.02 8 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 115233.28 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|8:rdy=0| 115236.31 8 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 115236.31 8 ScriptEventCode 9013 iLineState=900 115236.36 dial start any summary:|5:idx=0|6:idx=0|7:idx=0|8:idx=0| Share this post Link to post
SupportTeam Report post Posted 04/19/2007 07:45 AM Quote We are using Intel dialgic card We are *not* using VG for Dialogic If you are using a Dialogic card then you should be using VoiceGuide for Dialogic... If you can post the "tw" trace from VoiceGuide for Dialogic then we can have a look at it to see if it shows anything... Can you ask the telephone company in what format they are sending the CallerID? Share this post Link to post
