Script Starting
Hi
I have 3 questions today :
1. I'm doing outbound calls and If I let the phone ring more that 4 or 5 time, the script starts even without any answer. I'm wondering where I forget something ?
2. Is there any simple way to hide the VG application and show it only in the systray
Thanks you.
Mh
That's only 2 questions.... But I can answer the second. Check the file menu for "Minimize To System Tray Ctrl+M" on the voice guide main window.
You'd need to set the ringback tone detection parameters to match the ringback tone p-played when the number is called so that the Dialogic card properly detects the ringback tone.
If you are calling many different numbers and are likely to come across many different ringback tones then you'd really require a T1/E1 ISDN connection to make this work.
