Necser Report post Posted 08/11/2003 02:14 AM Has anyone managed a call transfer on voice modem? I am using Creative Modem Blaster V92. The transfer actually procedes, but when it prompts to press 1 to accept a call or any other number to reject on the transfered client it drops the call even if you press 1. Any idea on how to fix this? Share this post Link to post
SupportTeam Report post Posted 08/11/2003 07:24 AM Looks like your phone system requires a special signal to be sent by VoiceGuide complete an 'announced call transfer'. (on most systems if VoiceGuide just hangs up then the call transfer will proceed - and this is what VoiceGuide does by default - but it looks like your system needs something else...) What PBX are you using? What does the original caller hear while VoiceGuide plays "Please press1 to accept the call..." to the recipient of the transfer? Do they hear any 'on-hold' music played by the PBX? How do you do such transfers manually on this PBX? please give us a step -by-step description, and I can advise how to config VoiceGuide to match this... Could you please send us a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong. (When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call.) Share this post Link to post
Necser Report post Posted 08/12/2003 07:45 PM I have logged the event: 15437 0 tapie callstate OFFERING 65928 0 4 15437 0 Answer the call 15437 0 lineAnswer(65928) => 65911 15437 0 tapie ring 1 15453 0 tapie callstate ACCEPTED 65928 0 0 20796 0 tapi Reply 65911 0 20796 0 tapie callstate CONNECTED 65928,0,0 20796 0 WorkingModeTAPI= 20796 0 WorkingModeScript= 20796 0 Inband detection not enabled 20796 0 [select Query] Playing 20812 0 [select Query] Playing (C:\Documents and Settings\SN\Desktop\Sounds\welcome1.wav) 20859 0 PlaySoundStart ok [C:\Documents and Settings\SN\Desktop\Sounds\welcome1.wav] 20859 0 RunModule PLAY end 25187 0 tapie monitordigits 53 2 25187 0 LsPlayMsg [5] 26125 0 PlaySoundStop ok 26562 0 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER 26562 0 [Transfer Mobile Serge] Announced Transfer to 8094690 (Generate) 26562 0 tapic lineGenerateDigits(65928,!) => 0 27328 0 tapie generate LINEGENERATETERM_DONE 28421 0 LsXferStart EV_TAPI_GENERATE 29515 0 LsXferPlayVts EV_HOOKFLASHFINISHED 29515 0 tapic lineGenerateDigits(65928,8094690) => 0 31593 0 tapie generate LINEGENERATETERM_DONE 32687 0 LsXferPlayVts EV_TAPI_GENERATE 32687 0 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, , Digits 32687 0 twcal PlaySayNumber C:\Program Files\ivg\system\voice\TsfrCallFrom.wav, C:\Program Files\ivg\system\voice\TsfrAskAccept.wav, , , 1 32750 0 PlaySoundStartNumbers ok 39687 0 Play End line[0] (id=932687) 39687 0 LsXferPlayAnn EV_PLAY_FINISHED 39687 0 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG 39687 0 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, , Digits 39703 0 twcal PlaySayNumber C:\Program Files\ivg\system\voice\TsfrCallFrom.wav, C:\Program Files\ivg\system\voice\TsfrAskAccept.wav, , , 1 39750 0 PlaySoundStartNumbers ok 46703 0 Play End line[0] (id=939703) 46718 0 LsXferPlayAnn EV_PLAY_FINISHED 46718 0 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG 46718 0 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, , Digits 46718 0 twcal PlaySayNumber C:\Program Files\ivg\system\voice\TsfrCallFrom.wav, C:\Program Files\ivg\system\voice\TsfrAskAccept.wav, , , 1 46781 0 PlaySoundStartNumbers ok 53734 0 Play End line[0] (id=946718) 53734 0 LsXferPlayAnn EV_PLAY_FINISHED 53734 0 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG 53734 0 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, , Digits 53750 0 twcal PlaySayNumber C:\Program Files\ivg\system\voice\TsfrCallFrom.wav, C:\Program Files\ivg\system\voice\TsfrAskAccept.wav, , , 1 53812 0 PlaySoundStartNumbers ok 56218 0 tapie monitordigits 49 2 56218 0 LsXferPlayAnn [1].......................I pressed 1 here to accept the call 58750 0 PlaySoundStop ok 59734 0 LsXferPlayAnn EV_PLAY_FINISHED 59734 0 tapic lineGenerateDigits(65928,!!) => 0 61265 0 tapie generate LINEGENERATETERM_DONE 62359 0 LsXferPlayAnn EV_TAPI_GENERATE 62359 0 PlayFinishCause=CallAccepted 62359 0 Success path not defined - hanging up (iXferType=1)..............This line confuses me. 63453 0 LsXferPlayAnn EV_TIMEOUT_HANGUP 63453 0 PlaySoundStop ok 63453 0 HangupCall called from [] 63453 0 Hanging up call... 63453 0 PlaySoundStop ok 63468 0 fnHangupCall end 63703 0 tapie callstate DISCONNECTED 65928,1,0 63703 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT 63703 0 PlaySoundStop ok 63703 0 HangupCall called from [] 63703 0 Hanging up call... 63718 0 PlaySoundStop ok 63718 0 fnHangupCall end 63718 0 tapie callstate IDLE 65928 0 0 63718 0 WorkingMode@Idle= 63734 0 set EV_TIMEOUT_TIMETOREINITLINE 2 63734 0 tapi Reply 65843 0 63734 0 tapi Reply 65826 0 64734 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 64734 0 ReinitTelephony due to IDLE start 64734 0 tapic lineDeallocateCall(MainCall:65928) 0 65671 0 lineOpen(0) => 0 65671 0 Waiting for a call... 65671 0 lineOpen(0)LineHandle=65809 Everything goes ok, untill I press 1 to accept the call. The log replies with the "path not defined". Should I setup the path somewhare? Thanks in advance. Share this post Link to post
SupportTeam Report post Posted 08/13/2003 05:25 AM Looks like your phone system requires a special signal to be sent by VoiceGuide complete an 'announced call transfer'. (on most systems if VoiceGuide just hangs up then the call transfer will proceed - and this is what VoiceGuide does by default - but it looks like your system needs something else...) How do you do such transfers manually on this PBX? Please give us a step-by-step description, and I can advise how to config VoiceGuide to match this... (see menu Edit->PBX Command Strings) There is not need to set up the success path (unless you want VG to do something after the call has been accepted) As mentioned above - on most PBXs if VG (or anybody for that matter) hangs up the call after the destination extension has picked up results in the transfer to be made - but it looks like you phone system is different... Please give us a step-by-step description of how do you do such transfers manually on this PBX and I can advise how to configure VoiceGuide to match this... (you can change the settings yourself using the Edit->PBX Command Strings menu) Share this post Link to post
