Guest henrik@abcgroup.dk Report post Posted 04/24/2007 10:41 AM Hi, I have tried to use your script on the webpage to place new calls in the outdialque.mdb. It seems to work as the data ends up in the correct way in the outdialque.mdb. Unfortunately the script always takes the path "fail" after completing the VBscript. the VBscript used is: set vg = CreateObject("VoiceGuide.CommandLink") vg.Dialer_OutDialQueAdd "5551234", 704230324, 0700, 0800, "", "", 1, "none", "d:\basis\basis_0.3.vgs", "none", "", 0, 2, 5, "", "" set vg = Nothing I tried the trick with erasing the outdialque and let voiceguide create a new one, but it kept using the "fail" path. I've attached the logfile, which I unfortunately don't get much out of. Do you see the problem? I thank you in advance. Henrik log.zip Share this post Link to post
Guest henrik@abcgroup.dk Report post Posted 04/24/2007 11:02 AM Sorry, will just add my specs: - windows XP - Voiceguide for Dialogic, 6.0.3243Enterprise, 4 line version - Dialogic cards D/41JCT-LS-eu BR Henrik Share this post Link to post
SupportTeam Report post Posted 04/24/2007 11:34 PM The reason why the fail path is taken is because the explicit "Success" result was not set or returned by the script. The VBScript needs to call Run_ResultReturn() COM function or create a Result File. You can also select the next module to run by using the COM functions Script_Gosub(), Script_Goto() or Script_Return(). You also need to have the Dialer add-on enabled in order for the outgoing call to be made. Share this post Link to post
