Disconnect
Sorry but this subject drives me crazy.
I have problems again on disconnect detection using & D/41PCI. through PBX so to make sure that this is not linked with the PBX I have tried using direct analog line.
Please find all the log files attached of course I have put the right values in the xml file but it seems that dialogic is waiting for à loop drop off and this seems to come later after the hang up.
Could you pleas help me analysing the log files and help me in my reccurent problem.
Trace shows that the Dialogic card detected a loop current drop on the line about 15 seconds after module [ecouter] started playing. System hung up when the loop current drop was reported.
It all seems fine and as expected, what is the problem?
123857,03 1 state [ecouter] Playing
123857,05 1 state [ecouter] Playing (C:\gol2.wav)
123857,05 1 timer clear
123857,06 1 play start ok, lPlayId=921125
123911,88 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_LCOF,,
123911,88 1 event DE_LCOF, iCode=134 state=1100
123911,88 1 LsPlayMsg EV_UNKNOWN_134,DE_LCOF
123911,89 1 path {DE_LCOF} not found
123911,89 1 HangupCall start (Loop Current Off (non-xfer vgm))
123911,89 1 rv add [Hangup Time]{24/04/2007 12:39:11}
My point is that 15s (how do you calculate that ?) is too much (maybe provider dependant) and I would expect the system to detect the disconnect tones to detect hang-up earlier. Otherwise I dont'understand why we have to specify the disconnect tones ..
Thkx
So you hung up the call at the time when the [ecouter] module started playing?
Instead of a Play module try using a Record mofule to record what tones are played on the line after hangup, then see if those tones match what is specified in ConfigLine.xml file.
the "123857,03" in "123857,03 1 state [ecouter] Playing" is a timestamp, read it as: 12:38:57.03
the "123911,88" in "123911,88 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_LCOF,," is a timestamp, read it as 12:39:11.88
