Guest Diana Report post Posted 04/25/2007 04:54 PM Hi VG team, I want to give my callers 3 informations 1) Today there is a communication problem (info.wav) 2) The location is quenstreet (location.wav) 3) This problem will be till 4:00 AM tomorrow. (time.wav) Whe the caller dialed into the ivr system I want the caller to hear this information. How can I configure the "Play Sound file Module" box to gife these information? Users can simply update these information because they are in a folder at my desktop I tried to puth the path (in the Play Sound file Module box) with: Sound file to play: C:\Documents and Settings\Admin\Desktop\Information\info.wav, C:\Documents and Settings\Admin\Desktop\Information\location.wav, C:\Documents and Settings\Admin\Desktop\Information\time.wav the users can update only the wav files The problem is: The system cannot play the wav files. Question: What have I did wrong? If I do it so: C:\Documents and Settings\Admin\Desktop\Information\info.wav, \location.wav, \time.wav I am hearing the last wav file (time.wav) when I press the "Play" button. thank you in advanced. Diana Share this post Link to post
SupportTeam Report post Posted 04/25/2007 11:51 PM Enable logging by setting the log levels to 10 in VG.INI as per below: [Log] VoiceGuide=10 Then restart VG and make a test call which demonstrates the problem. Debug Trace files will be created in VG's \log\ subdirectory. Please post the traces and the VoiceGuide script used. When posting traces/scripts please .ZIP them up and post them as attachments. Share this post Link to post
Guest Diana Report post Posted 04/30/2007 12:27 PM Hi Support, There was a problem to login into the computer with pcAnywhere. Today I went to the location and I tried it again with 2 options: 1) C:\Documents and Settings\Admin\Desktop\Information\info.wav, C:\Documents and Settings\Admin\Desktop\Information\location.wav 2) C:\Documents and Settings\Admin\Desktop\Information\info.wav, Documents and Settings\Admin\Desktop\Information\location.wav When I tried it with option 2 it starts working. I read the help information but is was not clear. In the help infomation there was an example how to to that but it is not clear. Maybe I am wrong but it is should not work with the example: Voiceguide help Multiple sound files can be selected to be played by separating the successive files by commas. eg: prompts\1.wav, prompts\2.wav would result in two files from the script's prompts subdirectory being played (1.wav and 2.wav) one after another. Ok regards, Diana Share this post Link to post
