Give Information To The Caller
Hi VG team,
I want to give my callers 3 informations
1) Today there is a communication problem (info.wav)
2) The location is quenstreet (location.wav)
3) This problem will be till 4:00 AM tomorrow. (time.wav)
Whe the caller dialed into the ivr system I want the caller to hear this information.
How can I configure the "Play Sound file Module" box to gife these information?
Users can simply update these information because they are in a folder at my desktop
I tried to puth the path (in the Play Sound file Module box) with:
Sound file to play:
C:\Documents and Settings\Admin\Desktop\Information\info.wav, C:\Documents and Settings\Admin\Desktop\Information\location.wav, C:\Documents and Settings\Admin\Desktop\Information\time.wav
the users can update only the wav files
The problem is: The system cannot play the wav files.
Question: What have I did wrong?
If I do it so:
C:\Documents and Settings\Admin\Desktop\Information\info.wav, \location.wav, \time.wav
I am hearing the last wav file (time.wav) when I press the "Play" button.
thank you in advanced.
Diana
[Log]
VoiceGuide=10
Debug Trace files will be created in VG's \log\ subdirectory.
Hi Support,
There was a problem to login into the computer with pcAnywhere.
Today I went to the location and I tried it again with 2 options:
1) C:\Documents and Settings\Admin\Desktop\Information\info.wav, C:\Documents and Settings\Admin\Desktop\Information\location.wav
2) C:\Documents and Settings\Admin\Desktop\Information\info.wav, Documents and Settings\Admin\Desktop\Information\location.wav
When I tried it with option 2 it starts working.
I read the help information but is was not clear.
In the help infomation there was an example how to to that but it is not clear.
Maybe I am wrong but it is should not work with the example:
Voiceguide help
Multiple sound files can be selected to be played by separating the successive files by commas. eg:
prompts\1.wav, prompts\2.wav
would result in two files from the script's prompts subdirectory being played (1.wav and 2.wav) one after another.
Ok regards,
Diana
