simonq2 Report post Posted 04/27/2007 03:16 AM How do I go to a menu option from a VB Script module? What I am trying to do is add a # onto the end of an input to go down a particular path. Currently I have a menu selection using a Get Numbers. If you press 1 it goes down 1 path, 2 goes down another path. This is fine except if you press 1# or 2# it fails and replays menu selection WAV. What I want is a way to either ignore # for that selection or failing that, have it always go to a VB Script module and in that check the $RV[] of the previous menu input (eg. 1# or 2#). Then go down a different path for each. Hope you can help. Ideally ignoring the # would be easiest. Simon Share this post Link to post
SupportTeam Report post Posted 04/27/2007 03:26 AM Currently I have a menu selection using a Get Numbers. If you press 1 it goes down 1 path, 2 goes down another path. This is fine except if you press 1# or 2# it fails and replays menu selection WAV. If you have a "1" path defined then that path will be taken as soon as the 1 is pressed. The "#" would then be received by the following module. If you still have problems then please post the script which you are using, and a trace capturing the call. What I want is a way to either ignore # for that selection Is the next module a Get Numbers module as well? You have to make sure the next module ignores the "#". Ideally ignoring the # would be easiest. A Get Numbers module uses # to indicate end of number being entered. If you just require to get a single digit then using a Play module may be more appropriate. Share this post Link to post
