ahaggard Report post Posted 08/11/2003 05:41 AM Hello, I need some flexibility to design call log reports and print them out. Specifically, I would like to have the following: Date Caller Name Caller Number GetNumbersCode Duration of Call I then need totals of all minutes by date of caller time on system. Finally, I would like to run monthly time totals for all calls. Can I do this? Thanks Share this post Link to post
SupportTeam Report post Posted 08/11/2003 08:56 AM Some simple customization is required to create this (takes less then 5 minutes)... To have VoiceGuide save "Date Caller Name Caller Number GetNumbersCode Duration of Call" in a file readable by Excel: Create a new script which has just one module - a Run Program type module and have it run this command (specify all on one line): command.com /c echo $RV_DD, $RV_MM, $RV_CIDNAME, $RV_CIDNUMBER, $RV[GetNumbersCode], $RV_CALLLENGTH >> c:\CallLog$RV_YY$RV_MM.csv Then specify this script to be the "Script to run when call is finished". (See the Edit->Script Properties menu in the Script Designer) That’s it… The file c:\CallLogYYMM.csv can then be opened in Excel and the number of seconds for each call will be visible in the column "F". Note that we have indicated that each month the information will be saved in a differently named file - so when the month is finished just open the right file eg: November 2003 will be C:\CallLog0311.csv and then just sum the numbers in Column F to give you the total for this month... You can get more complicated and save data in a database and then have it generate reports (or use Crystal Reports) etc, but the principle is the same - save what you want to save from the "Script to run when call is finished" script... Share this post Link to post
ahaggard Report post Posted 08/12/2003 03:44 AM Well, I did exactly this and it doesn't cut the call log. The debug shows that it goes to the script, but no log. Share this post Link to post
SupportTeam Report post Posted 08/12/2003 04:20 AM Can you poast the Trace Log please? I just tried it here and it worked fine, here is the log: 141450.53 16 callstate IDLE 65946 0 0 141450.53 16 WorkingMode@Idle= 141450.53 16 TimeoutClear 141450.55 16 After Hangup script:[C:\Projects\vg32\Scripts\Voicemail Server\LogStuff.vgs] 141450.55 0 Script Load C:\Projects\vg32\Scripts\Voicemail Server\LogStuff.vgs 141450.55 16 Loaded VbsAtHangup into:1 141450.55 16 TimeoutClear 141450.55 16 [Run Program 7] Run Program 141450.55 16 RVreplace start (strlen>100) 141450.56 16 RVreplace end: [command.com /c echo 12, 08, , , , 20 >> c:\Log0308.csv] 141450.56 16 running:[command.com /c echo 12, 08, , , , 20 >> c:\Log0308.csv] WindowMode:[NormalFocus] 141450.69 16 Run Program continuing... The command used was: command.com /c echo $RV_DD, $RV_MM, $RV_CIDNAME, $RV_CIDNUMBER, $RV[GetNumbersCode], $RV_CALLLENGTH >> c:\Log$RV_YY$RV_MM.csv and the file c:\Log0308.csv was created with the right data in it... Share this post Link to post
ahaggard Report post Posted 08/12/2003 10:50 PM Here's the log. I probably have something set up wrong. You'll need to give any additional settings to me as I am not an expert. Thanks 175838.86 6 linedevstate 2048 0 0 175838.89 6 callstate OFFERING 66083 0 4 175838.91 6 Lev_CallerID [9725672583,WIRELESS CALLER] 175838.92 6 callinfo CALLEDID 175838.92 6 callinfo ORIGIN 175838.92 6 ring 0 175844.86 6 ring 2 175844.86 6 Answer the call at 8/12/2003 5:58:44 PM 175844.86 6 lineAnswer(66083) => 66066 175845.41 6 callstate CONNECTED 66083,1,0 175845.41 6 WorkingModeTAPI= 175845.41 6 WorkingModeScript= 175845.42 6 Inband detection not enabled 175845.44 6 StartLoadedVgs at 8/12/2003 5:58:45 PM 175845.44 6 tapi Reply 66066 0 175845.44 6 [Welcome to DNP] Playing 175845.44 6 [Welcome to DNP] Playing (C:\WINNT\data\VmWelc\Main_Greeting.wav) 175845.48 6 PlaySoundStart ok [C:\WINNT\data\VmWelc\Main_Greeting.wav] 175845.48 6 RunModule PLAY end 175847.53 6 dtmf 1 (49,2) 175847.53 6 LsPlayMsg 1 175848.55 6 PlaySoundStop ok 175848.56 6 [Get3Numbers] Number Input 175848.56 6 [Get3Numbers] Playing (C:\WINNT\data\VmWelc\Get_Numbers.wav) 175848.58 6 PlaySoundStart ok [C:\WINNT\data\VmWelc\Get_Numbers.wav] 175850.64 6 dtmf 4 (52,2) 175850.64 6 LsGetNbrsPlayWelcMsg 4 175851.66 6 PlaySoundStop ok 175851.66 6 [Get3Numbers] Number Input 4 175851.66 6 dtmf 5 (53,2) 175851.66 6 LsGetNbrsRxDigits 5 175851.66 6 [Get3Numbers] Number Input 45 175851.91 6 dtmf 0 (48,2) 175851.91 6 LsGetNbrsRxDigits 0 175851.91 6 [Get3Numbers] Number Input 450 175851.91 6 [GetAdCode] Number Input 175851.91 6 [GetAdCode] Playing () 175851.91 6 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED 175852.44 6 dtmf 8 (56,2) 175852.44 6 LsGetNbrsRxDigits 8 175852.44 6 [GetAdCode] Number Input 8 175852.44 6 [LogEnteredCode] Evaluate ["$RV[Get3Numbers]$RV[GetAdCode]"] 175852.44 6 RVreplace start: ["$RV[Get3Numbers]$RV[GetAdCode]"] 175852.44 6 RVreplace end: ["4508"] 175852.44 6 .Eval(Cstr("4508")) 175852.47 6 Eval Expr result:[4508] stored in $RV[4DigitCode] 175852.47 6 RVreplace start: [on {true} goto [Voicemail Box $RV[Get3Numbers]] ] 175852.47 6 RVreplace end: [on {true} goto [Voicemail Box 450] ] 175852.47 6 RVreplace start: [Voicemail Box $RV[Get3Numbers]] 175852.47 6 RVreplace end: [Voicemail Box 450] 175852.48 0 Script Load C:\WINNT\system\vm\VmLm.vgs 175852.56 6 Loaded C:\WINNT\system\vm\VmLm.vgs into:2 175852.58 6 [VmLmStart] Running vb script:[VmLmHangup.vgs] 175906.11 0 Script Load C:\WINNT\system\vm\VmLmHangup.vgs 175906.13 6 Loaded VbsAtHangup into:3 175906.13 6 tapi Reply 66049 0 175906.14 6 [VmLmHangup_ForwardLastMsg] Running VB Script... 175906.14 6 RVreplace start (strlen>100) 175906.16 6 VBScript Run continuing... 175906.16 6 Hanging up call... [Run module : no success path defined] 175906.16 6 HangupCall_Common Mode=AfterHangupRun 175906.16 6 ReinitTelephony due to IDLE start 175906.16 6 tapic lineDeallocateCall(MainCall:66083) 0 175906.27 6 lineOpen(6) => 0 175906.27 6 Waiting for a call... 175906.27 6 lineOpen(6)LineHandle=66032 175906.28 6 cl Vm_ForwardMsg 6, 450, C:\WINNT\data\VmSave\450_0812175857_1_6_9725672583_.wav 175906.28 6 vm frwrd vmb 450 175906.28 6 vm frwrd 450->999 175906.30 6 vm copy C:\WINNT\data\VmSave\450_0812175857_1_6_9725672583_.wav -> C:\WINNT\data\VmSave\999_0812175857_1_6_9725672583_.wav 175906.31 6 vm frwrd vmb 999 175906.31 6 RVreplace start (strlen>100) 175906.31 6 RVreplace end: [From WIRELESS CALLER, 9725672583, 450, 8 at 17:59 8/12] Share this post Link to post
SupportTeam Report post Posted 08/13/2003 05:17 AM I see that the call was hung up in a Voicemail script... So the caller was in a different script to that which had the logging script set up as the "Script to run when call is finished" script... To ensure that calls that hangup while in the voicemail script also log information to the special log file, the logging module will need to be added to the script which is the "Script to run when call is finished" for the voicemail script... The voicemail script used was C:\WINNT\system\vm\VmLm.vgs (you can see this when you read the trace log..) If you open that script and look at it's properties you will see that it has set script "VmLmHangup.vgs" as it's "Script to run when call is finished" script. So "VmLmHangup.vgs" needs to be edited to also log information to the special log file... I've modified one as a demo- you can use the attached file to replace the VmLmHangup.vgs on your machine (in C:\WINNT\system\vm\VmLmHangup.vgs). Basically it all boils down to ensuring that whichever script is being ran, that scripts "Script to run when call is finished" script will log the information at hangup... Share this post Link to post
SupportTeam Report post Posted 08/13/2003 05:18 AM here is that new VmLmHangup.vgs VmLmHangup.vgs Share this post Link to post
ahaggard Report post Posted 08/13/2003 02:19 PM Sounds good. However, I need a VGS type file - not the HTML provided. Thanks.. Share this post Link to post
ahaggard Report post Posted 08/13/2003 02:47 PM Forget my last post....I did a copy and paste with the old file and converted it. It does work now...thanks a lot for the script. The only odd thing is that it truncates the log file name to 8 characters. Any idea why? Share this post Link to post
SupportTeam Report post Posted 08/13/2003 11:46 PM The posted file was a .vgs file - as the description shows.. Left clicking on the link will just show contents of the file in a new window... The save the file to local hard disk you need to right-click on the link and select "Save Target As..." The filename will be truncated to 8 characters as the command is ran in a DOS window - DOS only allows 8 character filenames... Share this post Link to post
Guest Robert Report post Posted 10/27/2003 10:40 AM Hello i want this to Date Caller Name Caller Number GetNumbersCode Duration of Call. but i want it to have in microsoft access. can you give me a script for it. thanks robert Share this post Link to post
jimpeduto Report post Posted 10/27/2003 02:58 PM We are trying to insert the data into an Access database named response. We are using the database module. The table that should accept the data is named calls. This is the statement that we wrote (actually we stripped out everything just to try to make the connection: INSERT INTO Calls (Phone) VALUES ('$RV[GetPhoneNumber]'). I am sure the path is correct but the database is not being updated. Where have we gone wrong? Share this post Link to post
SupportTeam Report post Posted 10/27/2003 10:54 PM Could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong. (When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call.) Share this post Link to post
jimpeduto Report post Posted 10/27/2003 10:55 PM I can establish a connection with the database but as you can see from the log the rv are blank. Where is my error? 174354.42 0 Tapi device 3 is: Analog Line 4(dxxxB1C4) 174354.44 0 Tapi device 2 is: Analog Line 3(dxxxB1C3) 174354.44 0 Tapi device 1 is: Analog Line 2(dxxxB1C2) 174354.45 0 Tapi device 0 is: Analog Line 1(dxxxB1C1) 174354.53 0 Inband Signaling Config file not specified 174354.54 0 Loading VMB data begin 174354.56 0 Loading VMB data - about to delete old entries 174354.58 0 Loading VMB data - sorting/ordering 174354.59 0 Loading VMB data end 174354.67 0 Initialising... 174354.68 1 Initialising... 174354.68 2 Initialising... 174354.69 3 Initialising... 174354.69 0 Script Load C:\Program Files\VoiceGuide\Scripts\Employment\Job Line.vgs 174354.77 0 Calling .lineOpen on device 1 174354.85 0 Calling .GetLineHandle on LineId 0 174354.85 0 hLine=11939448 174354.85 0 Calling .GetProviderInfo on LineId 0 174354.87 0 Line 0 Provider: D41MT.TSP: Dialogic D41 Service Provider 174354.87 0 Calling lineSetNumRings on lLineHandle 11939448 174354.88 0 Waiting for a call... 174354.88 0 Calling .lineOpen on device 2 174354.95 0 Calling .GetLineHandle on LineId 1 174354.95 1 hLine=11939224 174354.95 0 Calling .GetProviderInfo on LineId 1 174354.95 1 Line 1 Provider: D41MT.TSP: Dialogic D41 Service Provider 174354.96 0 Calling lineSetNumRings on lLineHandle 11939224 174354.96 1 Waiting for a call... 174354.96 0 Calling .lineOpen on device 3 174355.04 0 Calling .GetLineHandle on LineId 2 174355.04 2 hLine=11940736 174355.04 0 Calling .GetProviderInfo on LineId 2 174355.04 2 Line 2 Provider: D41MT.TSP: Dialogic D41 Service Provider 174355.04 0 Calling lineSetNumRings on lLineHandle 11940736 174355.04 2 Waiting for a call... 174355.04 0 Calling .lineOpen on device 4 174355.11 0 Calling .GetLineHandle on LineId 3 174355.11 3 hLine=11939000 174355.11 0 Calling .GetProviderInfo on LineId 3 174355.13 3 Line 3 Provider: D41MT.TSP: Dialogic D41 Service Provider 174355.13 0 Calling lineSetNumRings on lLineHandle 11939000 174355.13 3 Waiting for a call... 174422.58 0 linedevstate 2048 0 0 174422.59 0 callstate OFFERING 11940016 0 4 174422.59 0 callinfo CALLEDID 174422.59 0 callinfo ORIGIN 174422.59 0 ring 0 174422.59 0 Answer the call at 10/27/03 5:44:22 PM 174422.59 0 lineAnswer(11940016) => 1 174423.14 0 callstate CONNECTED 11940016,1,0 174423.14 0 WorkingModeTAPI@Connected= 174423.14 0 WorkingModeScript@Connected= 174423.15 0 Inband detection not enabled 174423.15 0 StartLoadedVgs at 10/27/03 5:44:23 PM 174423.16 0 tapi Reply (LineEvReply) ok 1 0 174423.16 0 [Welcome] Playing 174423.16 0 [Welcome] Playing (Welcome.wav) 174423.20 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Welcome.wav] 174423.20 0 RunModule PLAY end 174440.09 0 wb(85817400) 174441.10 0 Play End line[0] (id=858174) 174441.10 0 LsPlayMsg EV_PLAY_FINISHED 174441.10 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 174441.13 0 [say Your Name Preface] Playing 174441.13 0 [say Your Name Preface] Playing (Say Your Name Preface.wav) 174441.15 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Say Your Name Preface.wav] 174441.15 0 RunModule PLAY end 174444.89 0 wb(87614000) 174445.90 0 Play End line[0] (id=876140) 174445.90 0 LsPlayMsg EV_PLAY_FINISHED 174445.90 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 174445.93 0 [Name] Recording 174445.95 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\beep1.wav] 174446.15 0 wb(88094700) 174447.15 0 Play End line[0] (id=880947) 174447.15 0 LsRecPlayBeep EV_PLAY_FINISHED 174447.16 0 RVreplace start: [$RV_CIDNUMBER_$RV_CIDNAME_$RV_MM$RV_DD_$RV_HH$RV_NN$RV_SS.wav] 174447.16 0 RVreplace end: [__1027_174447.wav] 174447.17 0 RecSoundStart file[C:\Program Files\VoiceGuide\Scripts\Employment\__1027_174447.wav] ok 174447.17 0 RecFile[C:\Program Files\VoiceGuide\Scripts\Employment\__1027_174447.wav] 174448.07 0 LsRecRecording EV_TIMEOUT_GOTOMODULE 174449.07 0 RecSoundStop ok 174449.07 0 Name_RecLen100ms = 8 174449.10 0 [PhoneNumber] Number Input 174449.10 0 [PhoneNumber] Playing (Enter Phone Number.wav) 174449.12 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Enter Phone Number.wav] 174454.82 0 wb(88411100) 174455.83 0 Play End line[0] (id=884111) 174455.83 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED 174455.89 0 dtmf 6 (11940016,54,2) 174455.89 0 LsGetNbrsRxDigits 6 174455.89 0 [PhoneNumber] Number Input 6 174455.89 0 path {6} not found 174456.27 0 dtmf 6 (11940016,54,2) 174456.28 0 LsGetNbrsRxDigits 6 174456.28 0 [PhoneNumber] Number Input 66 174456.28 0 path {66} not found 174456.33 0 sys cleanup Start 174456.33 0 sys cleanup End 174456.66 0 dtmf 6 (11940016,54,2) 174456.66 0 LsGetNbrsRxDigits 6 174456.66 0 [PhoneNumber] Number Input 666 174456.66 0 path {666} not found 174458.32 0 dtmf 1 (11940016,49,2) 174458.32 0 LsGetNbrsRxDigits 1 174458.34 0 [PhoneNumber] Number Input 6661 174458.34 0 path {6661} not found 174458.71 0 dtmf 2 (11940016,50,2) 174458.71 0 LsGetNbrsRxDigits 2 174458.71 0 [PhoneNumber] Number Input 66612 174458.71 0 path {66612} not found 174459.10 0 dtmf 3 (11940016,51,2) 174459.10 0 LsGetNbrsRxDigits 3 174459.10 0 [PhoneNumber] Number Input 666123 174459.11 0 path {666123} not found 174459.48 0 dtmf 4 (11940016,52,2) 174459.48 0 LsGetNbrsRxDigits 4 174459.48 0 [PhoneNumber] Number Input 6661234 174459.48 0 path {6661234} not found 174500.77 0 dtmf 5 (11940016,53,2) 174500.77 0 LsGetNbrsRxDigits 5 174500.77 0 [PhoneNumber] Number Input 66612345 174500.77 0 path {66612345} not found 174501.27 0 dtmf 6 (11940016,54,2) 174501.27 0 LsGetNbrsRxDigits 6 174501.27 0 [PhoneNumber] Number Input 666123456 174501.27 0 path {666123456} not found 174501.65 0 dtmf 7 (11940016,55,2) 174501.65 0 LsGetNbrsRxDigits 7 174501.65 0 [PhoneNumber] Number Input 6661234567 174501.65 0 path {6661234567} not found 174501.66 0 path {6661234567} not found 174501.66 0 [CurrentAssociate] Playing 174501.66 0 [CurrentAssociate] Playing (Current Associate.wav) 174501.67 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Current Associate.wav] 174501.68 0 RunModule PLAY end 174502.07 0 dtmf 8 (11940016,56,2) 174502.08 0 LsPlayMsg 8 174502.08 0 path {8} not found 174504.26 0 dtmf 1 (11940016,49,2) 174504.26 0 LsPlayMsg 1 174505.27 0 PlaySoundStop ok 174505.29 0 [PastAssociate] Playing 174505.30 0 [PastAssociate] Playing (Past Associate.wav) 174505.30 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Past Associate.wav] 174505.32 0 RunModule PLAY end 174507.07 0 dtmf 1 (11940016,49,2) 174507.07 0 LsPlayMsg 1 174508.07 0 PlaySoundStop ok 174508.11 0 [Age] Playing 174508.11 0 [Age] Playing (18 or older.wav) 174508.13 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\18 or older.wav] 174508.13 0 RunModule PLAY end 174509.88 0 dtmf 1 (11940016,49,2) 174509.89 0 LsPlayMsg 1 174510.89 0 PlaySoundStop ok 174510.92 0 [Felony] Playing 174510.92 0 [Felony] Playing (Felony.wav) 174510.94 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Felony.wav] 174510.94 0 RunModule PLAY end 174512.96 0 dtmf 1 (11940016,49,2) 174512.96 0 LsPlayMsg 1 174513.98 0 PlaySoundStop ok 174513.00 0 [Transport] Playing 174513.00 0 [Transport] Playing (Transportation.wav) 174514.02 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Transportation.wav] 174514.02 0 RunModule PLAY end 174515.78 0 dtmf 1 (11940016,49,2) 174515.78 0 LsPlayMsg 1 174516.78 0 PlaySoundStop ok 174516.81 0 [Region] Playing 174516.81 0 [Region] Playing (Region.wav) 174516.83 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Region.wav] 174516.83 0 RunModule PLAY end 174518.46 0 dtmf 1 (11940016,49,2) 174518.46 0 LsPlayMsg 1 174519.48 0 PlaySoundStop ok 174519.50 0 [interviewTime] Playing 174519.50 0 [interviewTime] Playing (Call Back Time.wav) 174519.54 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Call Back Time.wav] 174519.54 0 RunModule PLAY end 174521.41 0 dtmf 1 (11940016,49,2) 174521.41 0 LsPlayMsg 1 174522.41 0 PlaySoundStop ok 174522.44 0 [Thank You] Playing 174522.45 0 [Thank You] Playing (Thank You No.wav) 174522.46 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Employment\Thank You No.wav] 174522.46 0 RunModule PLAY end 174527.53 0 wb(91745900) 174528.53 0 Play End line[0] (id=917459) 174528.53 0 LsPlayMsg EV_PLAY_FINISHED 174528.53 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 174528.55 0 [updateDatabase] DB Query 174528.55 0 Jet mode used (To use ODBC mode specify ODBC Connect string) 174528.64 0 RVreplace start: [iNSERT INTO Calls (Phone, Age) VALUES ('$RV[GetPhoneNumber]', '$RV[GetAge]')] 174528.64 0 RVreplace end: [iNSERT INTO Calls (Phone, Age) VALUES ('', '')] 174528.64 0 About to execute Action Query 174528.66 0 Hanging up call... [Hangup Module] 174528.66 0 RecSoundStop ok 174528.66 0 PlaySoundStop ok 174528.66 0 fnHangupCall end 174528.70 0 linedevstate 2048 0 0 174528.70 0 callstate IDLE 11940016 0 0 174528.70 0 WorkingMode@Idle= 174528.71 0 After Hangup script:[C:\Program Files\VoiceGuide\Scripts\Employment\Update Db.vgs] 174528.71 0 Script Load C:\Program Files\VoiceGuide\Scripts\Employment\Update Db.vgs 174528.72 0 Loaded VbsAtHangup into:2 174528.72 0 [updateDatabase_1] DB Query 174528.72 0 tapi Reply (LineEvReply) ok 2 0 174528.72 0 Jet mode used (To use ODBC mode specify ODBC Connect string) 174528.75 0 RVreplace start: [iNSERT INTO Calls (Felony) VALUES ('$RV[GetFelony]')] 174528.75 0 RVreplace end: [iNSERT INTO Calls (Felony) VALUES ('')] 174528.75 0 About to execute Action Query 174528.76 0 Hanging up call... [srlib 282] 174528.76 0 HangupCall_Common Mode=AfterHangupRun 174528.76 0 ReinitTelephony due to IDLE start 174528.77 0 tapic lineDeallocateCall(MainCall:11940016) 0 174528.86 0 lineOpen(0) => 0 174528.86 0 Waiting for a call... 174528.86 0 lineOpen(0)LineHandle=11940944 Share this post Link to post
SupportTeam Report post Posted 10/27/2003 11:14 PM I see that in the SQL query a Result Variable $RV[GetPhoneNumber] is used, but this RV has not been defined at during the call by any module, and is not the title of any prevuiously executed module in the script... I see that there is however a module called [PhoneNumber] .... I suspect you should be using $RV[PhoneNumber] in the SQL query similarly $RV[GetAge] should be $RV[Age] and $RV[GetFelony] should be $RV[Felony] Share this post Link to post
Guest joostica Report post Posted 11/25/2003 11:35 AM Hello i want to have a call log every day. at the time at 16.00 houres command.com /c echo $RV_DD, $RV_MM, $RV_CIDNAME, $RV_CIDNUMBER, $RV[GetNumbersCode], $RV_CALLLENGTH >> c:\CallLog$RV_YY$RV_MM.csv can you help me thanks joost Share this post Link to post
SupportTeam Report post Posted 11/25/2003 12:37 PM The question above was not a continuation of the thread and as such was split into a new thread. Plz see: http://voiceguide.com/forums/index.php?showtopic=872 Share this post Link to post
