Unable To Save Settings
I thought this was because I was testing on a trial version - but now that I have registered it is still a problem.
When I shutdown VG my settings are lost. On the next start, it attempts to dial out on all 4 lines (I only want to use 1-2), and the script it uses when someone calls in reverts back to one of the demo scripts.
How can I save my settings so that they are restored the next time the program starts?
Are you using VoiceGuide for Dialogic? The script and which lines are used for Dialing out is settable in Config.xml file - you need to change the settings there as these are the settings that are read in on startup.
