Retrive Telehone Numbers
Hi Support Team,
We want to upgrade our telephone service.
Callers can dial a number and they can ask the operator for someone's number.
This is the only service which is running on our server.
We want to integrate our telephone service.
It must be possible for callers to dial into the system and get information of a subscriber.
For example:
CALLER:
Caller is dialing: 133
System
Please enter the name of the person from who you want the telephone number and press #
CALLER:
The caller is pressing: J.Hobblerrs#
System
Please wait a moment..........
The telephone number of J.Hobblerrs is 454545.
To reapeat press 1
If you want to connect with the person press 2.
If you want to search for another telephone number press*
If you want to end the call press#
I have all ready:
A) A server with Windows 2000
B) VG for Dialogic Enterprise License 8 lines
C) A MySQL and a Access database with the information of the subscribers.
I have some questions:
1) Is this possible to setup such a system with VG?
2) What do I need to add to my server to use voice recognition for this service?
Thank you in advanced.
Gulano
You would need to perform a search of what names match the entered digit sequence and then play back the telephone number (or other details) of the matched entry.
To do this you should have each name in the database converted to its digit equivalent and then just search the DB for entries who's "digit equivalents" match the number entered by caller.
Hi Support,
Thank you for your reply.
It is very simple if you know the initials of the person which number you are looking for.
I know that it is possible to query all subscribers with the name of Hobblerrs instead of searching for J.Hobblerrs
because the name could be instead of J.Hobblerss also J.A.Hobblerss so it could be a problem. By searching the name Hobblerss it is possible that the system finds
more than 50 names. I want it to be possible that the system presents me (speaks) the name of the persons, their telephone number and their address.
I must setup a telephone Service System where you can dial into and get the telephone number of the person you are looking for.
In my previous post I asked a question but you did not give me an answer.
Can you please give me the answers I need to setup this system?
Questions:
1)
Have someone all ready setup a telephone number service with VG?
2)
Can this telephone system be setup with VG for Dialogic Enterprise License or do I need more than only the software?
3)
a) Are there any known problems this system could have?
B) Are there any known problems callers could have by using this system?
If I want to setup the telephone number service with voice recognition.
4)
What do I need if I want to setup this service with voice recognition if I all ready have:
- a computer running windows 2000
- VG for Dialogic 8 lines Enterprise License
1) Have someone all ready setup a telephone number service with VG?
The Automated Attendant part of the voicemail system shows how this can be done. See the aaFindUser.vgs script in VoiceGuide's \system\vm\ subdirectory.
2) Can this telephone system be setup with VG for Dialogic Enterprise License or do I need more than only the software?
Enterprise license will be sufficient.
3) a) Are there any known problems this system could have?
Not that we know of. It's a pretty straightforward system: name is entered and the script matches it against an existing list, that's it.
You would need to have Nuance ASR licenses as well. You should contact sales@vocieguide.com regarding that.
Hi Support,
I am very satisfied with your answers.
Thank u.
Regards.
Hi Support,
I tried the script but I have some problems.
I test the script in the directory: C:\Program Files\VoiceGuide\Scripts\Directory Search
Name:Directory Search.vgs
In the txt file I put:
Adam,4522
Ada,4522
Mollenberg,4522
Mollendam,4522
Rustenbergg,4522
Kolendam,4522
If I am looking for the name: "Adam", the system is transfering me to extention: 4522
When I am pressing the name: "Mollendam", the system is telling me that the name can't be found.
Questions:
1) Is there a problem with VG searching names like "Mollendam" en "Rustenbergg"?
2) How can I enter the name: "Kolendam"?
I think by pressing
key5 2 times
key6 3 times
key5 3 times
key3 2 times
key6 2 times
key3 1 time
key2 1 time
key6 1 time
But I down't know if I am doing something wrong.
I am looking forward for your help in this.
Regards
No. Any name is fine.
I think by pressing
key5 2 times
key6 3 times
key5 3 times
key3 2 times
key6 2 times
key3 1 time
key2 1 time
key6 1 time
Only press the key once per letter.
So for "Kolendam":
key5 1 time
key6 1 time
key5 1 time
key3 1 time
key6 1 time
key3 1 time
key2 1 time
key6 1 time
If you still have problems:
Please post a copy of VoiceGuide's Trace Logs which captures the call, this will allow us to see what happened.
[Log]
VoiceGuide=10
Then restart VG and make a test cal.
Have you had a look at the aaFindUser.vgs script in VoiceGuide's \system\vm\ subdirectory?
Hi Support,
I tried it the way you told me to do.
I can't belive it. It is working real smooth.
After looking the way the Directory search script is working I realize that the data of our subscribers are stored in a database and that is a lot of data.
If I use this way to retrieve the telephone numbers it means that I have to put all the data of the subscribers in a txt file and how can I setup the txt
Questions:
1) Is there an option to retrieve the data from an Access database or a MySQL Database using the Directory Search script?
I think I should add a module to query the database and return the data to the script. I don't know if I am on the good way.
I have had a look at the aaFinduser.vgs script in VoiceGuide's \system\vm\ subdirectory.
It is also working but this script is using a xml file.
The name of every subscriber must be in the xml file (using the Voicemail Manager)
I should have to type all the name of the subscibers (more than 450.000)
Questions:
2) Is it posible to retrieve the data from a database using this script (aaFindUser.vgs)?
If not, then I will try to customize the Search Directory script to work with a database.
Thank you and regards.
You will need to modify the script to search for a match in a database instead of the text file. This basically just involves using a "Database Query" module to perfom the search.
Yes. That's it.
