Disconnection Detection
Another Disconnection issue for you guys ....
I am running XP and a Dialogic D41/E
I followed the instructions, recorded the hangup, analyzed the data, determined what the setting should be, and still....... no disconnection until the system timesout.
Here is my hangup wave and the settings I recently tried using:
Freq 1: 480
Freq 1 dev: 50
Freq 2: 619
Freq 2 dev: 50
On Time: 50
On Time Dev: 5
Off time: 48
Off time dev: 5
Repetition count: 2
Thanks for the assistance.
Jeff
hangup.zip
The attached recording only contained one disconnect tone signal, so it's not possible to find out the "OFF" time cadence, but the ON timing and frequencies are fine.
As the recording was ended soon after the disconnect tone started playing then it appears like the disconnect one was detected... if the disconnect tone was not detected the recording would not have ended and we would have more of the disconnect tone recorded.
Here is the new wav file with multiple tones and the changes I made... still no disconecting until the call times out.
Freq 1: 479
Freq 1 dev: 50
Freq 2: 619
Freq 2 dev: 50
On Time: 50
On Time Dev: 5
Off time: 49
Off time dev: 5
Repetition count: 2
hang.zip
Not sure why it would not work.
Please try reducing the repetition to 1 and increasing the cadence deviation times, eg:
Freq 1: 480
Freq 1 dev: 30
Freq 2: 620
Freq 2 dev: 30
On Time: 50
On Time Dev: 20
Off time: 50
Off time dev: 20
Repetition count: 1
Can you post the tw trace showing application startup so that we can see that the settings are read in correctly.
[Log]
VoiceGuide=10
ktTel=10
SapiWrapOcx=0
Then restart VG.
Please post the traces.
